Bay Area, California
Joined Dec 2009
Regarding the steps in the canopy, well those may have been cut out; there is quite a bit of room under the bridge. Need to do some fishing and see if the nub on the bottom of the canopy was cut because it definitely is nowhere near touching the battery. As it is now, there is one rectangle on the bottom of about 1/2" thickness (eyeballed it) and nothing else. I goofed on the maiden. Total brainfart and didn't reverse the ailerons to work the right way. It wasn't a big deal, I brought the plane down, but landed in some bumpy grass and the nose wheel mount broke. Looks like the prior owner may have broke it at one point too because it looks like it was glued in place. I saw him taxi the plane today before buying so I know it was at least strong enough for concrete. Pretty certain this part http://www.ebay.com/itm/Parkzone-Nos...item1e71297fc2 didn't break. I think whatever holds that piece is what let go. I haven't been able to take a real close look at it yet to confirm though. So what does hold that part in place, and what would I be looking at for a replacement? Guess I should find the manual online... |
Joined Dec 2009
Canada, ON, Toronto
Joined May 2012
Landing gear and engine cowl aesthetic improvements
Thank you "rgwilson" for the tip on the Robarts Landing Gear Strut Covers, and "flyindude" for the paint pen tip for detailing the engine cowl. I added these enhancements to my son's PZ T28D and I am very pleased with the outcome.
Here are some pics that show the front cowl and installed and painted landing gear strut covers. Note - I purposely installed the "elbows" on the strut covers pointed rearwards to avoid getting caught up in grass runways (we fly on soccer fields), even though the real plane has these pointing forwards. The front strut is correct with the rear facing elbow. The Robarts LG strut covers are a bit expensive (about $15 from most hobby shops), but they are a very well designed and well made product. They are a "snap and screw on" product for easy future removal in case of LG replacement, and are made of very strong but flexible plastic. For those that are interested, I will post some pics and a bit of an explanation on how I installed these on this plane under the "Parkzone T-28 Trojan Modifications" Thread. Cheers RvE |
Joined Dec 2009
Just got back from my re-maiden
. GG'd front wheel held up. Definitely need to do something about the battery situation. I felt like the plane was handling funny in the air but tried to finish the pack off, thinking it was due to the rudder being out of whack (it has a clear packing tape hinge on it right now, does the rudder normally fall off??). Finished off the flight with a nice scale landing and taxied back to me. Found the 1800mah pack towards the back of the fuse by the RX. Niceeee.
The next moderately hard landing will break it again I suspect. In my experience, glue alone (even when I used CA and some baking powder to build up the join) broke soon after the repair. I have been doing touch and goes and had several weekends of flying now with the most recent repairs and all's well so far. Note to Parkzone if you are reading this, please make the firewall a bit stronger and/or make it a service part so we can repair this more easily in future. We would be grateful. |
Didn't pull enough up elevator as I was coming in for a landing so I munched the nosegear through the firewall for the second time. The basswood reinforcement piece I had previously installed disappeared, I'll have to make a new one and use something stronger.
Ordered some replacement pushrods and a nosewheel, the existing pushrod is sort of taco'ed. So I spent too much time away from this bird (nicknamed Why So Serious since her earlier repairs make her look like her throat was slit) and lost all touch when flying her. Once I finish repairs, I think I'll move the bind from my Dx6i over to my DX7s, which will be a good time to revise throws and expo, I've got too much in the ailerons right now (50 I think) it makes it feel less responsive. What are typical low and high rates and expo you folks are using? I'm at work so I can't check the rest of my rates. |
Lots of expo can be treacherous.
Expo makes the low end of the stick movement have a reduced or mushy effect. The end point doesn't change. The result of too much expo is a stick that is mushy at first and then quick to respond at the end of the throw. Once you learn to control your thumbs will want the plane to react to your movements. After 11 months of flying I have reduced the amount of expo I use to 15% - 20%. |
| Thread Tools | |
| Article ParkZone T-28 Trojan RTF Review | Jim Walker | Electric Warbirds | 776 | May 12, 2013 02:01 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion Parkzone T-28 Trojan Thread | Edge767 | Parkflyers | 6527 | Jun 04, 2008 05:29 AM |
| Sold Parkzone T-28 Trojan, 480 960kv Motors (2) | Joe in Dublin | Aircraft - Electric - Power Systems (FS/W) | 4 | Jan 17, 2008 01:34 PM |
| Wanted Parkzone T-28 Trojan | webejpn01 | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 25, 2007 02:48 PM |
