Old Aug 28, 2012, 09:43 AM
jumna is offline
Find More Posts by jumna
United States, TN, Gray
Joined Nov 2010
Ten minutes with a 2200mah batt, but not WOT all the time, I like those low slow passes sometimes.
I smacked my HD keychain cam on the underside at the CG point and it did good, no "jelly-vision" at all, which I saw all the time mounted on my helicopters. I guess wing mounting is the way to go tho, unless you like see the nose gear wheel spin along in flight.
jumna is offline Find More Posts by jumna
Old Aug 28, 2012, 10:17 AM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Originally Posted by walter3rd View Post
with a stock set up what are you guys setting your tx timer for to get a good flight but give about 1 minute to get on the ground safe? thanks, walt
i was doing 8 with 2200 mAH but now i've been babying my batts and doing just 5 with each of them. mostly ~70% throttle.
cmdl is offline Find More Posts by cmdl
Old Aug 28, 2012, 01:31 PM
BlinkguY is online now
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
Dude... You can always go down to 3.8 volts a cell with no problems at all... In fact when i started this hobby with my super cub 3 years ago i went down to 3.5v a cell almost everyday flying for like a year or so... No problems with batteries at all....
BlinkguY is online now Find More Posts by BlinkguY
Old Aug 28, 2012, 02:26 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
+1
Even the ratings of the batteries for 3 cell @ 11.1 (that's 3.7 X 3) as minimum safe voltage.
4 cell 3.7 X 4 = 14.8, etc.
(Don't feel bad if you didn't know this..it took me AWHILE to figure it all out too)
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Aug 28, 2012, 03:00 PM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Originally Posted by RGS2010 View Post
+1
Russ
11.1v is the nominal voltage not the minimun safe voltage. The real deal is 9v 3.0v x 3 is the minimum safe voltage of a lipo. But people dont like to go so far down. Lipo have create the myth that can noy go down more than 3.7 but your still safe as far as 3.2v
DaxFX is offline Find More Posts by DaxFX
Old Aug 28, 2012, 03:23 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
True enough DAX but I don't want newbies to get anywhere near that until they get a feel for electrics. I always keep my packs at 3.4 to 3.7 per cell when flying and I believe it extends the life of the batteries.
Old Aug 28, 2012, 04:24 PM
DaxFX is offline
AIMDROIX
DaxFX's Avatar
Joined May 2008
For sure. I try never pass down 3.7v, in that range i have enough juice without the risk of a LVC. i like to have the reserve tank in case some crosswind start to blow and wont let me land or need to reaproach for a better align to landing. i was just posting the real deal. I do now and them give my lipo a cycle down to 3.0 or 3.2 and then put on storage.
Old Aug 28, 2012, 05:58 PM
BlinkguY's Avatar
Joined Nov 2005
sure.. indeed
Old Aug 28, 2012, 08:16 PM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
I set for 8 min, like Danny. I slow down, enter a pattern and am usually on the ground before 9.
davidterrell80 is offline Find More Posts by davidterrell80
Latest blog entry: Ace Wing Cores
Old Aug 28, 2012, 08:46 PM
cobra243 is offline
Find More Posts by cobra243
cobra243's Avatar
United States, IL, New Lenox
Joined Jan 2012
Mustang for sale
Hey guys im selling my airframe venom charger and (2) 3s 2200 gforce lipos with a lot of extras on ebay check out the listings.
http://www.ebay.com/itm/230844126191...84.m1555.l2649
http://www.ebay.com/itm/230844103239...84.m1555.l2649
http://www.ebay.com/itm/230844146783...84.m1555.l2649
cobra243 is offline Find More Posts by cobra243
Old Aug 28, 2012, 08:54 PM
BlinkguY's Avatar
Joined Nov 2005
That was fast
Old Aug 28, 2012, 10:25 PM
AeroKen is offline
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
The generally accepted wisdom is to not use more than 80% of the capacity of the battery. If you use more, you reduce the battery life. You can tell how much you used if your charger displays mAh it delivers to the battery while charging. Generally when you hit 3.7 volts per cell, you've used about 80%. I have one 3S battery I pulled down to 10.9 volts - it still seems to work fine, but now it takes noticeably longer to charge than an identical battery when I've discharged them about the same amount. Its clearly not quite as healthy as it used to be.
I have my timer set to 6 minutes, if I've been WOT a lot I land immediately. If its been a more relaxed flight I take my time, but I rarely go longer than 7 minutes.
Edit: forgot to say the 3.7 number is rest voltage after the flight. If you're talking voltage under load during a flight, then yeah the lower numbers are OK. Well, not sure about 3.0 even then.
AeroKen is offline Find More Posts by AeroKen
Old Aug 29, 2012, 11:55 AM
Oakstone is offline
Find More Posts by Oakstone
Noob
Oakstone's Avatar
Canada, BC, Victoria
Joined Apr 2011
Hey again,
Anyone using Throttle/Elevator mixing with a Dx6i?
I had read that it wasn't working, but maybe I have newer firmware, since it's working fine for me, although it was a tad confusing to set up.
Anywhoo, if you are mixing, what % of down elevator are you throwing in with WOT? I thought I'd start at 15%. It'll be on my flap switch, so I can test it at safe altitude, but I'm kind of excited to see if this is a cool mix to use.
Thanks!
Oakstone is offline Find More Posts by Oakstone
Old Aug 30, 2012, 08:10 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I'd probably start at 5%, faster you go the more effective the surface is.
robj is offline Find More Posts by robj
Old Aug 30, 2012, 11:53 PM
jumna is offline
Joined Nov 2010
I ordered HK's orangerx 3-axis gyro out of curiosity, and today smacked it into my T-28. I was hoping it would make windy landings easier, and not get knocked around as much doing acrobatics. Works alright, tho it def flies a little different. No gradual climbout at wot, goes more flat. The unit has adjustable pots, too much gain and supposedly the model gets too twitchy. More importantly, even if someone better than yourself crashes in the wind, it gives you that courage to go out there anyways, because heck there's a $15 good luck charm under the canopy, so what could happen?!?
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
