Old Jul 06, 2012, 07:02 AM
saboism is offline
Find More Posts by saboism
United States, TN, Gallatin
Joined Mar 2012
Awesome, thanks for all the detailed repair tips folks. Looks like I'm in better shape than I thought.
Another thing that broke was a servo arm on the wing. The gears do not seem stripped. Are the arms standard size? I only saw the entire servo on Horizon parts site, but just need the arm so will look for replacement elsewhere I guess.
saboism is offline Find More Posts by saboism
Old Jul 06, 2012, 02:25 PM
accel8or is offline
Find More Posts by accel8or
Mark Beltran
accel8or's Avatar
United States, CA, Westminster
Joined Dec 2010
@saboism, if the crash was hard enuf to break the servo arm, I'd be real concerned about the servo, even tho it seems to be ok. They don't cost much, so just get a new one. The servo arm is standard size.
accel8or is offline Find More Posts by accel8or
Old Jul 06, 2012, 02:55 PM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Better to spend $10 than have a failure and another crash. +1
DaxFX is online now Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old Jul 06, 2012, 05:47 PM
HapG is offline
Find More Posts by HapG
X-37B
HapG's Avatar
United States, WV, Morgantown
Joined Jan 2012
My old T28 had a similar break-off of the front fuse. I used toothpicks, g-glue, jbweld and epoxy mixed with Hobbylite. And after that, I used Hobbylite to spackle any small cracks. And when the Hobbylite dries, I soak it with thin ca. Here's the rebuild vid:
http://www.youtube.com/watch?v=TlzyeoW7J20
Nice! Thanks for taking the time to put that together.
Enjoyed the unique paint/decal scheme as well.
HapG is offline Find More Posts by HapG
Old Jul 06, 2012, 07:38 PM
whitehawk is offline
Find More Posts by whitehawk
Timmmaaaahhh!!!
whitehawk's Avatar
United States, IN, Dyer
Joined Mar 2008
Just got my t28 back together after the nose of the fuse broke off.
whitehawk is offline Find More Posts by whitehawk
Old Jul 06, 2012, 08:34 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
update - flew the t28 with both 1300 mAh and 2200 mAh. she seems to fly better nose heavy even though that means i have to keep lifting her nose up. as for the bank to the left yesterday - dunno what that was caused by so i'm putting it down to pilot idiocy,...i mean pilot error.
cmdl is online now Find More Posts by cmdl
Old Jul 07, 2012, 12:07 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Just some tips I learned the hardway, probably obvious to most of you.
1. Keep power and use elevator in turns to avoid tip stall/death spiral.
2. If you know enough to not go full throttle into the ground, a bigfoot 10 or power 10 mod can save you a lot easier than the stock motor. Say bye bye to scale flying though
3. Check the fiberglass wing spar by pulling the tape that covers it. On mine, it was not glued in very well. I used gorilla glue and then covered it with scotch extreme shipping tape tape. This tape is awesome. I also use it on the hinges as necessary. It's the tape with the cross hatch threads in it. Sadly, it doesn't blend in very well. It also seems to not only handle the sun well, but the glue seems to get stronger after being out in the sun.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 07, 2012, 01:33 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
Originally Posted by N6145k View Post
3. Check the fiberglass wing brace by pulling the tape that covers it. On mine, it was not glued in very well. I used gorilla glue and then covered it with scotch extreme shipping tape tape. This tape is awesome. I also use it on the hinges as necessary. It's the tape with the cross hatch threads in it. Sadly, it doesn't blend in very well. It also seems to not only handle the sun well, but the glue seems to get stronger after being out in the sun.
ummm,. am i supposed to leave the tape on? this is the wing brace on the fuse right? the one with the two holes in it, aft side?
i did have it on initially but the little striped tape that came on it started coming off and so i just took it off. should i put some packing tape back on?
Old Jul 07, 2012, 01:42 AM
dragonshade is offline
Find More Posts by dragonshade
dragonshade's Avatar
United States, GA, Marietta
Joined Dec 2011
No he means the wing spar itself. Runs thru a groove under the bottom of the wing, nearly wingtip to wingtip. The groove (and spar) are covered with that grey, cheapo tape. I pulled all the tape from mine and retaped with Blenderm.
dragonshade is offline Find More Posts by dragonshade
Old Jul 07, 2012, 01:45 AM
Joined Dec 2011
Dax.... if you still check in... wondering if you ever tried the 4s batteries on your T-28, and what ya thought.
Old Jul 07, 2012, 02:05 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
thanks. thats a relief.
Old Jul 07, 2012, 10:00 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
Have not yet. I have being few last weeks going to the field with my p47 and carbonz. Last week i flew my t28 and bring with me the 4s but was on 10x10e and i gorgot to bring a prop for the 4s.
Old Jul 07, 2012, 10:04 AM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Off topic for a second... but I was born in Alhambra, right down the road from you.
.quietguy is offline Find More Posts by .quietguy
Old Jul 07, 2012, 10:35 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
LOL. i actually live in alhambra - love the city. i just use rosemead on my location cause thats where my flying field is.
Old Jul 07, 2012, 02:05 PM
jeb6684 is offline
Find More Posts by jeb6684
jeb6684's Avatar
United States, PA, Gettysburg
Joined Mar 2011
Too Hot to fly today, so I decided to put lights on my T-28. Here are some pics.
jeb6684 is offline Find More Posts by jeb6684
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
