Old Jun 08, 2012, 06:23 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I using bathroom/kitchen caulk to attach the wing to the fuse. It provides a good wobble free connection, and you can always peel it off if you need to.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jun 08, 2012, 06:25 PM
Capslock is offline
Find More Posts by Capslock
Big Member
Capslock's Avatar
San Francisco, CA
Joined Nov 2001
Took my T-28 out last weekend to try my new Power 10 with a 9x7 three blade prop, replacing all stock stuff. WOW! I can't imagine you'd need more power than that.
Then, after a couple great flights, I had a mid-air collision with a friend's Mustang. The Mustang won. Its prop sliced into my somewhat delicate tailfeathers and among other carnage, broke the clevis off the elevator. It went nose down straight into the pavement. Ouch. It's definitely reparable, and I think by some miracle it didn't bend the shaft. Other than a totally shattered cowl, broken prop, destroyed horizontal stabilizer and elevator, and some fuselage cracks that I can repair, it seems OK. These are durable planes - it hit HARD.
Capslock is offline Find More Posts by Capslock
Old Jun 08, 2012, 06:30 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Capslock, please say you got it on video.
Old Jun 08, 2012, 06:32 PM
Capslock is offline
Big Member
Capslock's Avatar
San Francisco, CA
Joined Nov 2001
I'm aghast to say I didn't get it on tape. I did take this, though, with my other plane soon after:
RC video in Pacifica, CA.wmv (9 min 10 sec)
Old Jun 09, 2012, 01:08 AM
rbw8818 is offline
Find More Posts by rbw8818
Landing is a controlled crash
rbw8818's Avatar
United States, TX, Amarillo
Joined Jul 2011
Ok guys I am going to buy all spare parts in order to create a kit so i can put my own electronics in my t-28 but i am wondering if a new wing will come with the landing gear mounts (the white things). Thanks!
rbw8818 is offline Find More Posts by rbw8818
Old Jun 09, 2012, 02:46 AM
Great_Goose is offline
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
Yes the main painted wing comes with the LG mounts but if you buy the bare unpainted wing then you do not get the mounts
Great_Goose is offline Find More Posts by Great_Goose
Old Jun 09, 2012, 01:01 PM
rbw8818 is offline
rbw8818's Avatar
Joined Jul 2011
Ok so I am going to buy this. http://www.horizonhobby.com/products...sm-rtf-PKZ5020 Will I get the LG mounts?
Old Jun 09, 2012, 02:43 PM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
You should get all hardware needed less servos. Pushrods, horns, servo tape, landing mount, etc
I never bought but i have bought few wing for other pz plane and they came complete.
DaxFX is offline Find More Posts by DaxFX
Old Jun 09, 2012, 10:22 PM
thndr1mj is offline
Find More Posts by thndr1mj
Yeah, I can CRA$H that!
thndr1mj's Avatar
United States, GA, Dallas
Joined Dec 2010
Couple of vids of my T-28 Trojan. I upgraded the motor to a 480 plus with a 40 amp ESC and stock prop. The 1st video is of a dead stick landing when my prop decided it would rather be some place else 34 seconds into flight. The 2nd is just me and some friend chasing each other in the park.
Parkzone T-28 Trojan Dead Stick (1 min 44 sec)
T-28 Chase (3 min 30 sec)
ParkZone T-28 Trojan (4 min 51 sec)
thndr1mj is offline Find More Posts by thndr1mj
Old Jun 10, 2012, 02:26 AM
Rangie5169 is offline
Find More Posts by Rangie5169
Rangie5169's Avatar
United States, TX, Arlington
Joined Nov 2011
Motor needed
Well it happened. My t28 lawn darted into the pavement. Airframe is back together, but my motor makes some noise like bad/cracked bearings or something. With all the modded engines, does anyone have a motor they want to get rid of "reasonably priced"?
Let me know.
Thanks.
Michael
Rangie5169 is offline Find More Posts by Rangie5169
Old Jun 10, 2012, 09:05 AM
rgwilson is offline
Find More Posts by rgwilson
rgwilson's Avatar
USA, TX, Arlington
Joined Aug 2010
Let me know.
Thanks.
Michael
If you can't find a cheap one here, you can find a bearing set for the Parkzone 480 at http://www.bocabearings.com the part number is #BMK-023 for $14.95. They are pretty easy to replace, just take the set collar and spacer off the back of the motor and the can and shaft can be removed in one piece. Tap the old bearings out with a small punch and install the new ones. You probably damaged the front bearing when you hit the pavement.
rgwilson is offline Find More Posts by rgwilson
Old Jun 10, 2012, 03:31 PM
zagiace is offline
Find More Posts by zagiace
mmm... wings....
zagiace's Avatar
United States, CA, Santa Ana
Joined May 2004
Question, only been flying my t-28 for a little while and I have put in a 2.4 rx to replace the stock setup. The servos don't move smoothly. They are very choppy.
Is this due to the 2.4 hitec rx? Should I upgrade them?
zagiace is offline Find More Posts by zagiace
Old Jun 10, 2012, 03:54 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Your gears could be stripped in the servos, coincident in time to when you changed. I wouldn't fly it. Either go back your original rx, or get a servo tester, or take apart the servos carefully and inspect the gears. Just advice from me to you.
Old Jun 10, 2012, 04:08 PM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
I'm sure its been ask before but got to ask again cause I can't find it. Is there any way to cool the ESC? With it being in that foam so tight it seems get pretty toasty on mine and my dads.
JoshB is offline Find More Posts by JoshB
Old Jun 10, 2012, 08:06 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
JohsB, do you cut the shrink wrap away from the heat shrink? That helps.
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
