Old Jun 06, 2012, 08:40 PM
Waverunner is offline
Find More Posts by Waverunner
Joined Aug 2009
motor replacement
Would the Parkzone 15 bolt right up to this bird. I need a replacment motor. I may need to modify the cowl.
Waverunner
Waverunner is offline Find More Posts by Waverunner
Old Jun 07, 2012, 08:10 AM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
Originally Posted by cmdl View Post
hi all. beginner here with 4 months of experience on a cub and sensei. i was told by a guy at the lhs that for the t-28, he strongly recommends a radio that has expo rates. he said linear is not advisable. is this true? do beginners tyically use expo rates while starting on the t-28?
The T28 was the first plane I ever flew. Started with a DX5e that came with my Sim then bought the DX6i. Much better TX and had the expo. I started off running 65% throw and 30% expo on low and 85% and 20% on high. It didn't take long to grow out of that though. I like my plane to respond faster. Expo is a good way to start learning and you can adjust it as you go. I'm running 65% and 20% on low and 95% and 10% on high now. You will just have to play with it and see what fits you the best. Everyone is different. Just my .02.
JoshB is offline Find More Posts by JoshB
Old Jun 07, 2012, 11:52 AM
rcninja is offline
Find More Posts by rcninja
United States, NC, Charlotte
Joined Oct 2011
You can enable expo on the DX5e by holding right aileron trim and then turning on the transmitter. You'll hear a series of ascending tones indicating that it is on. Turn it off by holding left aileron trim while turning on. The expo is fixed at 20% or so.
rcninja is offline Find More Posts by rcninja
Old Jun 07, 2012, 12:13 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
how well does the T28 fly stunts? i want to do knife dge and inverted with it but im worried it wont do well and i will crash it because the throw is not enough.
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jun 07, 2012, 12:14 PM
Joined Apr 2012
Waverunner
you would have to modify the cowl. just get another 480
Old Jun 07, 2012, 12:48 PM
accel8or is offline
Find More Posts by accel8or
Mark Beltran
accel8or's Avatar
United States, CA, Westminster
Joined Dec 2010
@Waverunner, you can remove the whole grill area, practically, if you want. Best way is a Dremel tool with assorted grinding stones and one cutting wheel. I don't recommend the stock motor mount. Get an aluminum billet motor mount from that guy...uh, Custom RC Parts online.
accel8or is offline Find More Posts by accel8or
Old Jun 07, 2012, 12:54 PM
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
It all depends on the skill of the pilot flying it and the motor. Mine can't cut it with the stock motor. For knife edge flight, I typically max out the rudder throw....put the control rod clevis on the innermost hole on the rudder control horn. Some people will do the same for the elevator.
Yeah, it will do inverted. A 3ch plane can fly inverted. All depends on pilot skill. But you'll crash. Everybody does. Even the best. I could swear that's how we learn and get better. I do.
Old Jun 07, 2012, 01:09 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I've not had a problem with the stock motor mount, and I put a bigfoot 10 in it. Just had to drill a few holes. Don't nose dive into the ground and it will be okay.
The T28 can do knife edges, but it takes a lot of correction to keep it straight. It's not a 3D plane. But put a bigfoot 10 in it with a 10x7 apc prop, and it's a lot of fun.
Also, you might want to peel the tape back and see how well (or poorly) the wing spar is attached. Mine was terrible, and I heard reports of people folding their wings, so I put some guerralla glue in, though you could probably just use hot glue. I wouldn't recommend the caulk for this aspect. PZ seems to have some sloppy assembly and quality control, at least on the PZ T-28ds I've had--nothing that can't be fixed by the end user, but annoying.
7oneWo1f is offline Find More Posts by 7oneWo1f
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
If you can fly a Sensei, you'll do fine. The T28 is a lot more responsive, so set the throws as per the manual. Expo is used even by advanced pilots. Some won't use any expo. These are the low rates I suggest to start off with:
Ailerons: 3/8" up & down, with 30-35% expo (Rate is different from expo. You
decrease the rate to get the 3/8" movement. Rate is also a percentage.)
Elevator: 1/2" up & down, with 10% expo
Rudder: 5/8" left & right, with 10% expo
Old Jun 07, 2012, 01:12 PM
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
That's right, a knife edge on a T28 takes lots of correction because of the dihedral. It is a trainer, by the way thus the dihedral. The correction is by way of down elevator (for those who are learning). I've got a Himax HC3516-1350 with a 10x7 prop...it'll do walls and hover, but not for long, because of the small control surfaces and insufficient prop wash from the 10x7. Maybe I'll get a spare T28 and mod it with large control surfaces ...yeah a 3D T28.
Old Jun 07, 2012, 01:20 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I was thinking about doing the same thing...making a T28 with larger control surfaces and better servos. We think alike. I can get mine to hover, too, but it's not pretty, and has to be high up.
Old Jun 07, 2012, 01:29 PM
accel8or is offline
Mark Beltran
accel8or's Avatar
Joined Dec 2010
Yeah, it'll hover and then pitch up during the prop hang, or yaw either way. Try blipping it when it does that and it'll hover longer. I tried an 11x5.5 but the amp draw got way over the limit. Best thing is a Bigfoot 10 or a G15-850 with at least an 11 prop. Gotta get me that spare T28.
Old Jun 07, 2012, 02:29 PM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
Didn't know that. Thanks.
Old Jun 07, 2012, 03:24 PM
fnlrun is online now
Find More Posts by fnlrun
Capitalist
fnlrun's Avatar
United States, CA, Redding
Joined Sep 2008
$12 shipped from me.
They fit the stock replacement, 3536,3542 and 3548
fnlrun is online now Find More Posts by fnlrun
Old Jun 07, 2012, 03:26 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
thanks
cmdl is offline Find More Posts by cmdl
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
