Old Mar 15, 2011, 08:40 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by pkquat View Post
A dremel or rotozip with a ceramic type cutter works great. It leaves a pretty smooth surface on the side as long as you are moving opposite the rotation (I think?). One direction leaves a smooth surface and the other a rougher one. The bottom was pretty smooth.
Dremel grinding stones make a clean cut and they come in a range of shapes and sizes. I have tried the cutting bits but they tend to tear the foam up to much. Here is a picture of one of the grinding stones that works.
Prof100 is online now Find More Posts by Prof100
Old Mar 15, 2011, 09:48 PM
pkquat is offline
Find More Posts by pkquat
Joined Jun 2008
That would work well too, though I have had some stones melt plastic / foam and stick to them if they are not coarse enough. The tile bits so far haven't torn foam.
pkquat is offline Find More Posts by pkquat
Old Mar 15, 2011, 09:56 PM
Prof100's Avatar
Joined Jul 2007
Fascinating, your experience is just the opposite of mine, but when I use the stone I don't buzz the DREMEL at max. It's pretty low speed with the stones so they only cut the foam not melt the foam. The edge is always a clean cut and almost knife like.
I also use a soldering gun for servo pockets and the like. I use a soldering gun with custom tips for various shapes that need to be cut. The trick with soldering gun is to pulse the trigger so it only gets hot enough to cut the foam. If you don't pulse the trigger it will get so hot it will vaporize the foam. Not good.
Old Mar 15, 2011, 11:22 PM
pkquat is offline
Joined Jun 2008
Yup you can't have things going too fast. It will build up heat too fast. A larger diameter or coarse solid stone helps keep the heat down as long as it isn't screaming fast. Any issues have been with the finer stones which people often think will give a smoother finish or using too small a stone.
I think the coarse teeth on the tile bits help keep the heat down. The rotozip is on it lower setting, whatever speed the original was at, and I think the dremels were between 1/4 and 1/2.
I have only tried the soldering iron method a few times and haven't mastered it yet. I wind up with some goop, strings, puddled once, and getting stuck at least once.
Old Mar 16, 2011, 01:05 PM
Twisted-heli is offline
Find More Posts by Twisted-heli
Twisted-heli's Avatar
Joined Sep 2009
I posted a fair bit ago about my fix for getting a eflight motor mounted on to the motor mount see pic...
Well last week the motor mount cracked when the prop hit the ground on a belly landing, well things where going though my mind do I get another mount or get the ally ones that have been made, then Lud who I was flying with cherp up and said make that to, so I glued some ply to the front and used the eflight motor mount with washers to get the angle correct for the motor. Test flew it today fly's great a little adjustment for the added nose weight and it will be perfect. It also has fixed the vibration at full throttle as soon as I get a picture I will post it up
Twisted-heli is offline Find More Posts by Twisted-heli
Old Mar 16, 2011, 05:07 PM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I've done quite few pockets and slots in different planes made out of Z-foam and EPO. The best results were with exacto knife, or box cutter, but with brand new blade. I tried dremel, but didn't care for the mess. Round holes are done best with sharpened piece of thin metal tubing. If it is very deep hole, I'll use thin foam cutter wire first and go again with sharp tubing on the exposed side.
Rob
robusp is offline Find More Posts by robusp
Old Mar 16, 2011, 05:09 PM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
Good idea. How do you like the Park 480 motor over stock? Notice any big difference using it?
ZackJones is offline Find More Posts by ZackJones
Old Mar 16, 2011, 07:23 PM
Prof100's Avatar
Joined Jul 2007
Rob
Rob,
I am glad you like your process for removing foam and the results are to your liking. There are, however, many effective ways of carving foam that range from hot wire; razor blades; Xacto knives; soldering guns with customer shaped tips; a Dremel with grinding stones (works great on Z foam) sharpened tubes, etc. I have even used a low watt soldering iron with a small countersunk screw in the tip that cuts a nice pocket that a 3mm piece of CF will snap right into. Also, a metal straight edge is a must to guide whatever tool you choose. This hobby is great for trying different methods to get the job done.
Bill
Old Mar 17, 2011, 12:29 AM
motoguy1 is offline
Find More Posts by motoguy1
MO, USA
Joined Jun 2010
So, I've managed to mangle the stock props I had on hand for my (stock) T28. Before I go to the LHS and pick up more of the overpriced HZ units, are there other (better?) props I may want to consider? Other than a 2.4 AR6100e Rx, plane is otherwise stock.
motoguy1 is offline Find More Posts by motoguy1
Old Mar 17, 2011, 03:58 AM
Joined Sep 2009
It was given to me with a crashed motor and never flew it with the stock, but have to say the eflight motor is very nice plenty of power and thats with the 910kv one may have to at some point try the 1020kv 480 eflight one
Old Mar 17, 2011, 06:51 AM
Max Headspeed is offline
Find More Posts by Max Headspeed
Outstanding in a gravity field
Max Headspeed's Avatar
New Haven, CT., USA
Joined Feb 2006
.... the eflight motor is very nice plenty of power and that's with the 910kv one may have to at some point try the 1020kv 480 Eflite one
I really wouldn't waste the $$ for a 1020 version because it won't make any appreciable difference in performance.
I ran an Eflite Park 480 (1020Kv) spinning the stock 2 bladed prop in my PZ F4U Corsair and found that even though it was quieter and seemed smoother, there was no discernible difference performance over the stock production motor.
It's a more than adequate, premium priced replacement but is not going to boost performance to the next level, that's for sure.
Of course, if you were to mount it in a HZ Super Cub, then you'd see it kick butt.
Max Headspeed is offline Find More Posts by Max Headspeed
Old Mar 17, 2011, 09:18 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
This I can vouch for personally. I put a Park 480 on my SC and it's ridiculously fast (and fun) now. I also added a flattened, clipped wing with ailerons and that plane flies like a dream now!
It's not nearly as agile as the T-28 (not that the T-28 is overly agile or anything) but it's still very fun to fly. It does beautiful slow rolls...
turnerm is offline Find More Posts by turnerm
Old Mar 17, 2011, 12:20 PM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
WANTED T-28 Firewall
If you have one that you would be willing to part with please let me know.
The ring portion on mine that keeps the wheel and rod from moving towards the prop and motor is busted, thanks
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Mar 17, 2011, 06:22 PM
GCplane is online now
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
I have found this comparison chart (link below) very helpful in choosing different brand motors and choosing props. For example if an airplane recommends a particular motor you can go here to find a different brand. Also if you look up the equivalent scorpion motor they tell you what range of props fit that motor and how many amps they use. Information you could also use for your particular brand.
Also look at the chart: Notice with any same size motor the higher the KV the weaker the motor. So recent posts about getting higher KV will just result in a less powerful motor. And as a trend, look at more and more powerful motors in the chart their KV trends down for all brands.
http://innov8tivedesigns.com/Scorpio...ison%20Web.htm (fixed the link)
GCplane is online now Find More Posts by GCplane
Old Mar 17, 2011, 09:00 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Why we never throw anything away.
"Junkyard Dog"
Patched up Trojan fuse, Cessna 337 balsa/covered wings, Predator LG, home made belly pan and top fuse, broken canopy cut down and bolted on, castering tail wheel with self built spring to limit travel, Rubber Maid plastic bowl cowl, Krylon paint.
Stock motor and prop, Castle 35 esc, Ultimate bec, Hitec 81 servos (ailerons are direct drive, no linkages), TP 3S2100.
Wing is 4" shorter w/s wise, but has a larger chord. According to the calcs it moved the CG back nearly 3/4".
Will it fly? Who knows. But at least it gave me something to do, and cleaned up a bunch of parts laying around. LOL!
Glacier Girl is offline Find More Posts by Glacier Girl
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
