Old May 20, 2008, 04:52 AM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
High Def Video with Quad Copter FPV portable system
Here is a video composite taken with my portable Quad Copter FPV system using an HD FX-35 camera and flying FPV via the KX-171 camera:
http://www.af9y.com/HDfpvDemo.wmv
(Vimeo, even in HD, is not good enough to show the full quality so I've made this direct link)
If you can't do the download above, here is the lower quality Vimeo link:
FPV Quad Copter with HD FX-35 Video (2 min 7 sec)
A few notes about the video
- Starts with a close up of me flying FPV
- Moving up showing my Ham Radio tower
- Flying in a valley 1/2 mile away (look closely and you'll see a deer running toward the lower left corner)
- Found someone picking up Rocks in the field. He waves at the quad copter and I wave my "wings" back at him.
(A large row of trees made this non line of sight - no problems with either the FASST 2.4 Ghz R/C or 900 Mhz Video at near ground level 1/2 mile distance)
- Moving up to 500 foot altitude for the parting shot
Finally, this is the portable Quad Copter FPV system:
Old Man Mike is offline Find More Posts by Old Man Mike
Old May 20, 2008, 05:38 AM
tvdude310 is offline
Find More Posts by tvdude310
Cameras are EVERYWHERE...
tvdude310's Avatar
Los Angeles
Nice rig Mike!
I've been toying with cameras on microhelis, but your setup is fantastic! I'm thinking of doing something similar with a fixed-wing plane and an Aiptek A-HD+ (1080p) camcorder.
The video is outstanding. Interesting choice with the Quadracopter. All your gear is in the middle, out of the way of the blades and right on the CG. How does that thing yaw?
Great job, and nice tower too!
Rob
tvdude310 is offline Find More Posts by tvdude310
Old May 20, 2008, 05:45 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Cheers Mike,
I recently bolted my Canon HV20 HDV camcorder to a extensively modified EZ. Due to a severe case of dumb thumbs, I flipped the airbrake switch when I picked up my goggles from the suitcase with the planes just 100-feet up in the air. I managed to only record about 3-mins of footage with it though. Most of which is ducking cows. I snapped off the tail section and the elevator trying to get it out of the dive initiated by the airbrake. That also ripped off the antenna and made the Rx go into failsafe so I lost control seconds later
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old May 20, 2008, 07:41 AM
richgraf is offline
Find More Posts by richgraf
Joined Nov 2004
Hi Mike,
Great video system! This is really something, I thought the KQuad was terrific. I quess it was only part of what you had in mind. I think that that has been the best ezone thread I have followed. Thanks for all the great ideas. I almost have my Octo ready again, I did the pot mods. Rich
richgraf is offline Find More Posts by richgraf
Old May 20, 2008, 08:51 AM
ssassen is offline
Joined Jul 2004
Mike,
Question about the FX-35 camera, does it have an AV-output that has a AV signal on it when you're recording in video mode? And if so, is that output void of any info such as remaining storage memory, battery indicator etc?
Cheers,
Sander.
Old May 20, 2008, 09:30 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Outstanding as always Mike! I guess I'm going to have to give you some FPV competition. Beware "The Box"
Rusty (more to follow)
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old May 20, 2008, 09:54 AM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
how do you switch cameras and what's AUW ?
fmkit is offline Find More Posts by fmkit
Old May 20, 2008, 01:27 PM
Joined Sep 2007
Originally Posted by tvdude310
Nice rig Mike!
..... How does that thing yaw?
Rob
Thanks Rob. A quad has Front/Rear props that rotate in the opposite direction as the Left/Right props. Yaw is achieved by increasing the speed of one set while decreasing the speed of the other set. The quad will then yaw to conserve angular momentum.
Sander.
Yes, the FX-35 camera has an AV output while recording and I have flown FPV using that output instead of the KX-171. You can set camera so that no camera info shows.
The FX-35 works very well in SD as an FPV camera but the HD mode will show as a smaller display (like an HD signal shows on a standard TV) so it is not as good for FPV. The SD mode of the FX-35 is much higher quality than the KX-171 but the field of view is less. For now, I just fly with both cameras and use the KX-171 for FPV.
Hi Peter,
Currently I am not switching the cameras in flight but I already have the Maxim 4310 part which will allow me to design a circuit that will switch between the two videos via an R/C channel. What do you mean "AUW"? (did you receive my last PM?)
Richgraf: Thanks for the nice comments
Van Man Rusty: Bring it on, flyboy
Old May 20, 2008, 01:33 PM
ssassen is offline
Joined Jul 2004
Thanks Mike,
Odd question, but you don't have any footage from the FX-35 SD and HD output from the AV connector to compare do you? I'd hate to spend $250 on a camera only to return it a few days later.
As for AUW, that's an acronym for All Up Weight, basically the take off weight of whatever you're trying to get airborne
Cheers,
Sander.
Old May 20, 2008, 03:56 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
Really outstanding, Mike.
I even like the idea of using the foam pool noodles for gear.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old May 20, 2008, 08:30 PM
Joined Sep 2007
... what's AUW ?
All Up Weight (thanks Sander for reminding me what AUW stood for) is 45 oz and consists of the following:
Basic Quad = 23 oz
3200 mAh Battery = 9.5 oz
Payload = 12.5 oz
(FX-35 & Foam Mount, GPS & OSD, KX-171 & Microphone, 500 mw 900 Mhz Video Transmitter & Antenna, Battery Status display)
Flying time for above was 13 Minutes.
Here is a chart showing other configurations and the expected flying time for different payload weights:
(Sanders, I'll make some SD and HD recordings with the A/V outputs going thru the OSD to the TX and post the results from the RX output)
Old May 23, 2008, 05:37 AM
Joined Sep 2007
Thanks Mike,
Odd question, but you don't have any footage from the FX-35 SD and HD output from the AV connector to compare do you? I'd hate to spend $250 on a camera only to return it a few days later. ....
Sander.
Sander,
I finally had time to do a recording to show you the SD and HD output from the AV connector as it looks when transmitted via the FPV OSD system:
http://www.af9y.com/FX35inTX.wmv
You can see that the FX-35 display shows only the Recording indicator in the AV output going to the transmitter. The first half of this video is in SD and you can see a full screen. The second half of the video is in HD where the wide screen is reduced to fit inside the SD window. I think the IF OSD info could be moved so that it show in the black areas of the display which would make the HD mode not so bad for FPV.
Finally, here is what the HD recording looked like from the camera memory during the last half of the demo video above:
http://www.af9y.com/FX35HDrecord.wmv
Some day we may reasonably priced off the shelf transmitters for full HD but it will require much more power to achieve the same range as SD.
Old May 23, 2008, 06:16 AM
ssassen is offline
Joined Jul 2004
Thanks Mike,
Very much appreciated! I'm putting an order in for that camera today
Cheers,
Sander.
Old May 23, 2008, 11:27 AM
lorenkb is offline
Find More Posts by lorenkb
Knight of Ni-wom
Victorville, CA
Joined Mar 2003
Mike, that is quite the cool setup! How big of an SD card are you using in the FX35 and what kind of video length can you expect from that while recording in 720p?
Loren
lorenkb is offline Find More Posts by lorenkb
Old May 23, 2008, 02:37 PM
tvdude310's Avatar
Los Angeles
...and 4 times the bandwidth...
Discussion Quad Copter FPV Old Man Mike FPV Talk 27 Aug 15, 2009 03:40 PM
Discussion Finally!! Hummingbird 3D Pro has wireless video with no problem!! stand alone system wac Micro Helis 4 Jun 06, 2006 08:50 AM
High Def Aircobra Video Reed Slope 76 Oct 31, 2005 09:20 AM
High Def Video Camera Heli hoovdini Aerial Photography 5 Sep 06, 2005 11:59 AM
Partenavia Evening flying video, with curtek light system Patrick Plawner Electric Plane Talk 17 Sep 30, 2003 05:23 PM
