Old Jul 21, 2001, 08:15 AM
Ron D is offline
Find More Posts by Ron D
Harrisburg, PA - USA
Joined May 2001
Puzzling Question About the Multiplex Teddy and Pico Cub
I read all of Jerry Simon's Cub saga on the training forum and I don't think I saw an answer to this question.
Both planes are about the same weight, use the same wing, use the same stock 400 motor and prop, direct drive and same battery pak. However, the Teddy climbs out of sight at 1/2 throttle and soars forever, while the Cub barely makes it into the air even with a hefty hand launch, won't climb worth a bucket of spit, and soars like a brick.
Why the big difference in the two, almost identical planes, similarly configured? The only real difference is that the Teddy is a pusher.
Ron D is offline Find More Posts by Ron D
Old Jul 21, 2001, 09:51 AM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
First, the Teddy does NOT climb out of sight on 1/2 throttle, mine certainly doesn't, anyway. Second, the cub has an undercarriage and a much draggier fuselage than the Teddy, which is reltively clean.
Angelo is online now Find More Posts by Angelo
Discussion Question about Multiplex Speedies Cosmo21 Power Systems 12 Oct 24, 2006 08:38 AM
Questions about building Multiplex Pico Cub borgs Parkflyers 31 Apr 22, 2003 06:14 PM
Basic question about Multiplex Cockpit MM. Capslock Electric Plane Talk 5 May 08, 2002 11:49 PM
Multiplex's Pico Cub really zooms with 8 cells Ron D Foamies (Kits) 1 Jul 31, 2001 12:19 PM
Question about Multiplex Teddy (Wing Bolt) mrebman Foamies (Kits) 6 Jun 03, 2001 11:24 AM
