Espritmodel.com Heli Air
Closed Thread
This thread is privately moderated by blade strike, who may elect to delete unwanted replies.
Old May 18, 2008, 10:50 AM
Fly-Bar? What Fly-Bar?
blade strike's Avatar
Big Bear Ca.
Joined Jan 2006
Trader Rating: 70
Align 60A Brushless ESC (Governer and AirCraft Mode) / RCE-BL60G
Used for about 10 flights and then upgraded. Great shape, retails for $100!
Asking to get $65obo, great for 500(425mm)class heli's and also has aircraft mode.
Fearture:
*5-6V step-less adjustable BEC output allowing custom voltage setting to match servo specification.
*BEC output utilizing switching power system, suitable for 7.4-22.2V (2s-6s) Li battery, with continuous current
rating of 3A, and burst rating of 5A.
*Three programmable throttle speed settings to support quick throttle response.
*Include soft start and governor mode.
*Small and compact PCB design for lightweight and simple installation.
*Large heat sink for optimum thermal performance.
*Highly compatible to work with 98% of all brushless motors currently on the market.
*Ultra-smooth motor start designed to run with all kinds of brushless motors.
*The power inlet utilizes a Japanese made "Low ESR" capacitor in order to provide stable power source.
*The throttle has more than 200 step resolution that provides great throttle response and control.
*If the aircraft should land or crash in an unexpected location and become lost, the pilot can enable the Aircraft Locator Option. The Aircraft Locator Option is engaged by tuming off the transmitter. When the ESC does not receive a signal from the transmitter for 30 seconds, it will start to send an alarm to the motor. The sound of the alarm will aid the pilot to locate the aircraft. This option will not work with a PCM receiver that has SAVE function enabled, or with low noise resistant PM receivers.
Specification:
*Contimuous current:60Amps with porper air flow
*Surge current:70Amps
*Supporting motor types:2~10 pole in/outrunner brushless motors.
*Supporting maximum RPM:2poles=>190,000rpm;6poles=>63,000rpm
*Supporting input voltage:5.5V~25.2V
*Supporting battery types: Li-ion/ Li-poly 2~6 cells
*Output voltage: 5-6V step-less adjustment
*Continuous current 3A; Burst current 5A
*Size:65X28X12mm
*Weight:55g
blade strike is offline Find More Posts by blade strike
Old May 18, 2008, 11:33 AM
Big Bear Ca.
Joined Jan 2006
Trader Rating: 70
lets hear some offers, I have alot to ship tomorrow and would like to get this shipped same day!
Old May 18, 2008, 11:46 AM
Big Bear Ca.
Joined Jan 2006
Trader Rating: 70
sold!!!
Thx man!!!
Closed Thread
Sold Align 35A Brushless ESC (6 Volt) RCE-BL35X Orion_V Aircraft - Electric - Helis (FS/W) 0 Oct 31, 2007 10:20 PM
Sold NIB Align 35A Brushless ESC(Governer Mode) RCE-BL35G funfly Aircraft - Electric - Helis (FS/W) 0 Jun 27, 2007 06:16 AM
Sold NIB Align 25A Brushless ESC RCE-BL25A for sale billyboy Aircraft - Electric - Helis (FS/W) 0 Sep 04, 2006 07:14 PM
Sold Align 35A Brushless ESC(Governor Mode) RCE-BL35G Quags Aircraft - Electric - Helis (FS/W) 3 Apr 22, 2006 05:15 PM
Sold K10249A - Align 25A Brushless ESC RCE-BL25A $30 shipped Factory Sealed gbagley Aircraft - Electric - Helis (FS/W) 2 Mar 19, 2006 09:10 AM
