Old Jan 18, 2003, 02:15 PM
alvinm is offline
Find More Posts by alvinm
alvinm's Avatar
Pembroke Pines Florida
Joined Jan 2003
What prop for crazy max 4.25 gearing?
Decided to see what the cm can do with this gearing,any prop size recommendations?
alvinm is offline Find More Posts by alvinm
Old Jan 18, 2003, 05:39 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Re: What prop for crazy max 4.25 gearing?
alvinm,
Try this neat WEB site at Custom Paint Job...
http://custompaintjob.com/ezcalc/dma.asp
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Jan 18, 2003, 10:49 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
alvinm: I think it's a 9x4.7. I remember somewhere, Mike Greenshields posted the info... I have a 4.25 on order to try.
Here's Pcalc numbers:
EM300, 3.67:1, 7.5x5, 8x800AAE
14.1oz thrust, 39.1mph, 6.45a
EM300, 4.25:1, 9x4.7, 8x800AAE
15.1oz, 29.8mph, 7.14a
Not too impressive... But, testing will see!
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 19, 2003, 09:21 AM
alvinm is offline
alvinm's Avatar
Joined Jan 2003
Isn't the stock prop 7x 5.5 ?you have 7.5 unless that is what you meant.
I currently tried the 8x6 apc and got theses figures:
Prop RPM:7125
Prop Static Thrust oz:15.3
Prop In-flight Thrust oz:7..9 Prop Pitchspeed:40.5
mph
Approx Power System Weight: 8.844 oz Batteries + Motor + 10%
Full-throttle duration: minutes 7.26
Amps were around 6
Old Jan 19, 2003, 10:04 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Nope, just looked, it's marked 7.5x5.
Old Jan 19, 2003, 04:43 PM
Zoom is offline
Find More Posts by Zoom
pushing both extremes
Zoom's Avatar
San Jose, California, United States
Joined Oct 2001
Mike G. recommended the 9x6 APC-SF and that's what I tried. It has more pulling power than the stock setup, but top speed is a little lower as you would expect. It's a good gearing / prop combo for smaller fields.
- Zoom -
Zoom is offline Find More Posts by Zoom
Old Jan 19, 2003, 04:56 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Greetings,
I use a slowfly 10/4.7 on 8x800 nihms and will almost hover on a fresh charge. Also you may want to make a new set of longer landing gear for clearance.
With elevator/flap mixiing it will ROG off the grass in less than a foot. Cool mod for five bucks.
Jared
http://www.rcgroups.com/forums/showt...5&pagenumber=2
jcstalls is offline Find More Posts by jcstalls
Old Jan 19, 2003, 09:31 PM
alvinm is offline
alvinm's Avatar
Joined Jan 2003
What receiver do you use for your cm?
Old Jan 19, 2003, 10:02 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Greetings,
I used a Electron 6, a little tight, but rock solid.
jared
Discussion what prop for 1750kv on 4 cell? parkzonekid Power Systems 4 Aug 09, 2007 02:17 AM
Help! Prop for OS Max 26 4-stroke Engine helipilot Engines 11 Jun 18, 2007 11:30 AM
What prop for himax 2015 4100 25 oz plane Chuckhead1 Power Systems 3 Aug 07, 2004 09:50 PM
what prop for miniflash with b20 15l 4:1 & TP21003s pack RCZohn Power Systems 3 Sep 21, 2003 10:13 PM
What prop for a Mini AC 1215/20 & 4.1.1 gearbox hoverkid87 Power Systems 6 Feb 24, 2003 09:09 PM
