This thread is privately moderated by raz, who may elect to delete unwanted replies.
Old May 17, 2008, 04:26 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Clipped wing Super Cub
OK so here's how I did my clipped wing. I already had made ailerons and I wanted a little bit of wing left to extend past the ailerons, mostly to help protect the ailerons from hanger rash. After determining where I was going to cut on one end I marked it and using a thin razor knife sliced through the foam cutting off one tip. I then used that tip as a pattern to know exactly where to cut the opposite tip. After cutting off both tips I used some 200 grit sand paper to smooth the tips out and repainted. You can see how much the old paint had faded already in the last picture. I was going to cut the tips at an angle but decide to leave them square. A beveled cut would have made the small piece of fixed wing by the ailerons very weak and too easy to break off. I still may cut them at an angle at a later time depending on how it flies. With the wing clipped I lost 13 grams of weight and a total of 6.5" in wing length. In the overhead shot you can see the CF flat bar to keep the wing flat and strong. With some luck I'll get to try the new wing out this evening and will report back on how (or IF) it flies.
raz is offline Find More Posts by raz
Hobby Lobby Super Cub--clipped wing dk944s2 Parkflyers 518 Jun 19, 2014 12:09 PM
Mini-Review DPM Clipped Wing Super Cub F1 Rocket Sport Planes 10 Jul 02, 2008 08:12 AM
Sold DPM Super Cub clipped wing version. gouda Aircraft - Fuel - Airplanes (FS/W) 0 Nov 11, 2006 09:24 AM
Question What set-up for a DPM 1:4 scale Clipped Wing Super Cub? JimJams Scale Kit/Scratch Built 0 Apr 03, 2006 02:39 AM
Clipped Wing Pico Cub? kansascloud Parkflyers 7 Mar 10, 2002 09:12 PM
