Old Nov 09, 2012, 03:50 PM
1Hammer is offline
Find More Posts by 1Hammer
Micro Helicopter Electrician
1Hammer's Avatar
Central California Coast
Joined May 2008
I had a chance to get out early this morning and shoot a short little video of my LB with lights in the dark. I shot this with one of the #16 HD cameras I purchased...these little cameras are very cool.
Ladybird Lights 2 (0 min 44 sec)
I'm in the process of building a little adjustable angle carbon fiber camera mount for my Hoten-X...then some aerial HD video.
It's great to be back here and enjoying this great hobby again.
Regards,
John
1Hammer is offline Find More Posts by 1Hammer
Old Nov 09, 2012, 04:41 PM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
lovely lights!
you going to light up your hoten too?
mk
microkites is offline Find More Posts by microkites
Old Nov 09, 2012, 05:12 PM
1Hammer is offline
1Hammer's Avatar
Joined May 2008
You bet!
I'm going with 8-Ultra Bright 3mm Water Clear LED's, 2 Red-(Port), 2 Green-(Starboard), 2 Blue-(Aft) and 2 White-(Forward). This sucker should be visible from a LONG way off.
Regards,
John
Old Nov 09, 2012, 08:56 PM
Joined Sep 2007
nice!
spot light for night filming might be sweet too.
think I am going to go fly my LB!
mk
Old Nov 11, 2012, 11:05 AM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Looks good , John.
The Hoten has enough lift, you could incorporate a sequencer ...or is that already part of the plan? I'm usually a few steps behind....
regards,
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Nov 27, 2012, 10:18 AM
1Hammer is offline
1Hammer's Avatar
Joined May 2008
Hi all,
Bill, I thought about a sequence for the lights on the Hoten but after flying it a bit I think blinking or flashing lights would be very distracting for me while flying. My main reason for wanting to install lights is so I can take some night video.
Speaking of video, I finished the CF adjustable angle camera mount for the 808 #16 HD Key Camera and thought I'd post a few pics.
It's a two piece unit, a base to mount to the Hoten's battery tray and the adjustable angle camera plate the uses a product called "Power Grip" to attach the camera to the angle plate. Power Grip uses mushroomed shaped posts to interlock and produce a very positive grip unlike velcro which uses a hook and loop system. I tapped some brass tubing to receive a couple of 2mm button head machine screws for the adjusting of the camera angle and I used a 1mm CF rod and 3mm square CF tube to create a hinge. The 1mm CF rod is a press fit into the mounting base so it won't budge during flight. I sandwiched some thin CF sheet to create a curved surface on the camera angle plate to match the surface of the #16 HD Key Camera so there would be maximum contact of the Power Grip on both surfaces.
I tried to keep it simple yet as strong as possible.
The weight of the camera mount including the Hoten battery tray as shown is 35.53 grams and the total weight including the #16 HD camera with a D lens comes in at 55.10 grams.
Waiting for the electronics for my Hoten to return so I can test everything out, but that's another story.
Hope everyone's doing well.
Regards,
John
Old Nov 27, 2012, 12:57 PM
AtTheCross is offline
Find More Posts by AtTheCross
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
nice!
AtTheCross is offline Find More Posts by AtTheCross
Old Dec 07, 2012, 07:34 PM
Air Vaca is offline
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi all,
Sheesh....I thought I was keeping up a little better.
@ John
A sequencer would be cool, but as you mentioned, very distracting. You gonna see if you can utilize the Hoten for inspection and site selection for work or are you still?
Jason,
I hope you haven't moved...
Hey Richard,
You doing OK?
We're hanging in there. Things are looking up a little financially. Not buying new helis "up"...but...
regards,
Bill
was watching commercial, and they were showing someone carving a turkey using an electric carving knife....
call me old fashioned
but, if you need a power tool to cut the bird, it ain't done...
Old Dec 07, 2012, 08:22 PM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
All good here Merry Christmas to everyone!!!
Old Dec 08, 2012, 06:56 PM
1Hammer is offline
1Hammer's Avatar
Joined May 2008
Hi all,
Yes Merry Christmas everyone!
Bill, I'm still waiting on the ESC and RX for my Hoten but that's OK as I've been able to spend some time working on a Light Kit for the Ladybird. It's an 8-0805 SMD LED set using my LDCCD for power and weighs only 1.38 grams. I'm waiting for MK to confirm his mailing address so I can send a set to him for testing and evaluation.
Regards,
John
Old Dec 08, 2012, 07:11 PM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
here's a recent video of my gasser
AirStar International Green Mongoose (1 min 53 sec)
Old Dec 09, 2012, 12:05 AM
Air Vaca is offline
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi John,
Nice light set. Better do a range check. You'll be able to see that farther at night than in the day.
Richard,
Nice wide open area. You have to share it? Some smooth flying.
regards,
Bill
Old Dec 09, 2012, 09:00 AM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
Thanks Bill . yeah it's a non sanctioned field gets crazy on Sundays but I only fly Friday mornings and usually just like two other guys out there
Old Dec 09, 2012, 09:21 AM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
Ordered a new platform yesterday will be so much easier with no vibrations!!
This is me on my old platform from a couple weeks ago, this is after two weeks of practice after a >10yr break
Speed bagging (0 min 31 sec)
Old Dec 09, 2012, 02:48 PM
Air Vaca is offline
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
very cool...
now I know why you like the larger helis...you're a big guy...
...not how I pictured you in my mind...
Discussion Walkera 4#3b blade balancing roandad Micro Helis 5 May 14, 2008 03:49 AM
For Sale Walkera #4 New-in-Box (10 units) FlyinFoSheezy Aircraft - Electric - Helis (FS/W) 1 Feb 19, 2008 10:18 PM
Discussion Walkera 4#3 in the States! RCAV8R13 Micro Helis 0 Nov 18, 2007 10:23 AM
For Sale Walkera #4 New-In-Box Electric Heli FlyinFoSheezy Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 09:37 PM
Walkera or Colco in Australia maxy333 Micro Helis 5 Jun 21, 2005 10:44 PM
