Old May 16, 2008, 07:44 AM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
new walkera 4#3a +b
Hi!
I was one of the first to get the 4#3b and have flown over 200 flights on it,so I thought I would start a new thread
differances between 4#3 and 4#3a(and b-b being metal,a being plastic):
wider main blades
mellower gearing
beefier servos
new dampened head for more stable flight
new,more durable canopy
metal flybar has divets to keep it aligned
better motors
and of course, 2.4ghz!
I love this Heli! after trying most others and having 3 of the original 4#3's. this v2(that was how my 4#3b was originally labeled on canopy-so I will refer to both 4#3a and 4#3b as V2) is an incredible flyer!
have crashed 100's of times and only broken a boom and canopy
will post specs and pix later,hopefully when people start getting them, this thread will thrive!
mk
microkites is offline Find More Posts by microkites
Old May 16, 2008, 07:48 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
Only 5 sleeps to go plus postage,but whos counting?
jasonjetski is offline Find More Posts by jasonjetski
Old May 16, 2008, 08:10 AM
Joined Sep 2007
differant version
Old May 16, 2008, 08:12 AM
Joined Sep 2007
4#3b parts list
here is chart of parts!
Old May 16, 2008, 08:18 AM
Joined Sep 2007
specs
specs for 4#3a and b:
A--http://www.walkera.com/en1/particular.jsp?pn=Z64%233A0304
http://www.walkera.com/en1/particula...n=Z64%233B0304
B--
Old May 16, 2008, 08:21 AM
stevel48 is offline
Find More Posts by stevel48
stevel48's Avatar
do the wider blades give more lift? if so will they fit the old version 1?
stevel48 is offline Find More Posts by stevel48
Old May 16, 2008, 08:23 AM
Joined Sep 2007
I would assume they give more lift, yes they fit-think it would lessen stability-usual mod on v1 is to trim the blades to up your headspeed for more stability
mk
Old May 16, 2008, 08:29 AM
stevel48 is offline
stevel48's Avatar
micro--you've been following my 4#3 dauphin build so I'm looking to add more lift since the weight of the heli has gone up a lot. Hopefully the brushless mod and a 500 mah battery will help.
Old May 16, 2008, 08:33 AM
Joined Sep 2007
wider blades should help
also the new v2 heads should add more stability-dampening should help stability on flybarless 4 blade
I have realyzes 4 blade head he made-I am going to try it with both kinds of blades and differant gearing
mk
Old May 16, 2008, 08:42 AM
stevel48 is offline
stevel48's Avatar
cool. post the reuslts on my build thread to keep us all posted.
Old May 16, 2008, 10:04 AM
Vtwin is offline
Find More Posts by Vtwin
Joined Mar 2008
Can you use your own Tx on the 2.4ghz model?
So if I put a 2.4ghz Rx in my v1, can I use my DX6i ?
Thanks!
Vtwin is offline Find More Posts by Vtwin
Old May 16, 2008, 10:05 AM
ron.khan is offline
Find More Posts by ron.khan
Joined May 2008
I can't wait to get my hands on the new 4#3 b,what a cool looking machine!!
ron.khan is offline Find More Posts by ron.khan
Old May 16, 2008, 10:09 AM
PLATINUM is offline
Find More Posts by PLATINUM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
hmm.. can ya upgrade v1 to the 3b?
PLATINUM is offline Find More Posts by PLATINUM
Old May 16, 2008, 02:25 PM
sketchaholic is offline
Find More Posts by sketchaholic
sketchaholic's Avatar
Bay Area California
Joined Apr 2007
I'm gonna do my best to try. I would like to keep the original gearing if at all possible.
sketchaholic is offline Find More Posts by sketchaholic
Old May 16, 2008, 02:36 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
With the bigger canopy, larger blades and CNC etc it would be interesting to do a flight time trial and see just how much the differance in the flight time is compaired to the original 4#3
Regards David
Hellraser is offline Find More Posts by Hellraser
Mini-Review New Walkera 4#3 Pros and Cons ApachePilot Micro Helis 23 Jun 01, 2008 05:17 AM
Discussion Sweet! new walkera 4#3 2.4g heli on ebay _HypnoToad_ Micro Helis 11 Apr 23, 2008 08:55 AM
New Walkera #4 today KDX Micro Helis 12 Jun 01, 2005 04:34 AM
New Walkera 4 Dragonlfy owner! IceWind Micro Helis 7 May 03, 2005 02:46 AM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
