Old May 15, 2011, 07:06 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
The apprentice comes with AR600 now. Shouldn't be any need to replace rx.
bobly is offline Find More Posts by bobly
Old May 15, 2011, 07:56 PM
SandHog is offline
Find More Posts by SandHog
SandHog's Avatar
Joined Aug 2009
Even better! That's good news.
So Bobly, did you get that tail heavy issue you had with your Apprentice fixed? How about the prop adapter and set screw?
SandHog is offline Find More Posts by SandHog
Old May 15, 2011, 08:43 PM
FTA_FTW is offline
Find More Posts by FTA_FTW
FTA_FTW's Avatar
Joined Apr 2011
No they don't... I just bought one last week and it came with an AR500.
FTA_FTW is offline Find More Posts by FTA_FTW
Old May 15, 2011, 08:49 PM
FTA_FTW is offline
FTA_FTW's Avatar
Joined Apr 2011
Originally Posted by SandHog View Post
your LHS sold it to you as BNF (everything but Tx)? that's a good deal. Wise of you to replace the motor, ESC, (and hopefully the Rx) for your new Apprentice. Better electronics usually = longer lifespan.
To answer your question about the Power-Up-25 motor and similar set-ups, I'm running a Hacker A30-10XL 900kV 650W with the Eflite 40 Amp Pro ESC and 11x8 APCe prop. My Hacker's kV and Watts are very close to your Power-Up-25.
On 3s, that setup is really similar to the Eflite Power 15 950kV motor, which is decent power for training, normal flying, and mild aerobatics, but on 4s, my Apprentice has TONS of power. Around 187 watts per pound which is well into the 3D power range. Basically unlimited vertical (though it isn't balanced for it), and much faster (but it tends to climb due to the high lift of the wing)
I think you'll like that setup on your Apprentice (though I'd go with the APC 11x7, rather than the 11x5.5 which may not give you much power on 3s, but check it with your watt meter). The capability of flying 3s or 4s with the same motor and prop is nice.
Have fun!
Yup, sold it as a BNF, I was quite happy
With a 4s battery it definitely sounds more exciting, but for now I will be running on a 3s battery as I have three of them. But I am definitely tempted to get a 4s to see the difference lol
So you are saying to get a 11x7 prop so that I can use it with a 3s and 4s battery? Im worried that prop might give me a trouble with a 4s because on the site it does not list a 11x7 as a test prop...
Old May 15, 2011, 08:50 PM
SandHog is offline
SandHog's Avatar
Joined Aug 2009
Hmmmm . . .
Maybe you got one that had been sitting on a shelf for awhile. You said you bought it from your Local Hobby Store.
Actually the Power-Up-25 does list 11x7 under 3s, but not 4s. the 11x5.5 is under 3s as well, but not 4s. On my Hacker 900kV 650W it puts out just about exactly 650 watts at full throttle on 4s with an 11x8 battery. But I live at 5000 ft altitude which would affect it some. That's why you should check it with your watt meter.
Old May 15, 2011, 09:34 PM
bobly is offline
Joined Sep 2010
Bought mine 4/29 at lhs, it was shipped that week from Horizon and it has the AR600 in it.
Old May 15, 2011, 09:40 PM
bobly is offline
Joined Sep 2010
Haven't got to fly again -darn weather. I sent a querry to Horizon about the adapter. Started to fix it back, then check one of the close hobby shops and they had the collet type prop adapter which I like a lot better, so went and picked it up and now it is all better. That factory prop adapter has the smallest set screw I have ever seen holding it to the shaft. It doesn't have but three threads on it. Not sure what happened whether it wasn't tight to start with or worked loose. I got it out of the adapter, cleaned things up so the shaft would go back in the adapter, but there wasn't enough thread material left in the aluminum adapter to hold. I tapped the hole out to 6-32 threads and stuck it in the parts box for possible later need somewhere.
Old May 15, 2011, 09:44 PM
FTA_FTW is offline
FTA_FTW's Avatar
Joined Apr 2011
Ughhh I have such crappy luck I will phone HH tomorrow.
Did you get a 15C or 20C battery?
Old May 15, 2011, 09:50 PM
bobly is offline
Joined Sep 2010
Battery is a 15C that came with it. I bought a rtf and the lhs bought the transmitter back to sell to people wanting to start out with a bnf plane on the low $ scale.
Old May 17, 2011, 02:09 PM
chaos2984 is offline
Find More Posts by chaos2984
Joined Mar 2011
yea i got a 15c with mine. i think all the planes come with a 15c now for a 3s 3200
chaos2984 is offline Find More Posts by chaos2984
Old May 17, 2011, 05:11 PM
SandHog is offline
SandHog's Avatar
Joined Aug 2009
The 15c is the standard battery with the Apprentice; I bought my Apprentice summer 2009 -about 1 years ago- and it came with the 15c 3200mAh.
I think the newer 20c 3200mAh is the one they sell over the counter. It may eventually replace the 15c as the included battery, but probably not until they run out of 15c batteries.
Old May 17, 2011, 08:46 PM
FTA_FTW is offline
FTA_FTW's Avatar
Joined Apr 2011
Well can't wait to get my new motor installed and see how much faster it is Should be here next week. I may order a 4s battery in a few weeks because I don't think I will get the best results with my 3s.
Old May 17, 2011, 09:16 PM
SandHog is offline
SandHog's Avatar
Joined Aug 2009
It'll probably be a little faster, but don't expect a night-and-day difference.
The stock motor is an 870kV, and your new Power-Up-25 is a 950kV. Higher, but not dramatically higher. The difference is only 80kV, and 80kV X 11.1V = about 900 RPM's higher. That won't equate to much additional speed.
Depending on the new motor's efficiency, you may see a little longer flight times. The big difference will come when you decide to try 4s. THAT will give you significantly more speed. Just remember, though, the Apprentice is a trainer, not a pylon racer. Its huge wing provides a lot of lift, but also creates a lot of drag.
Old May 17, 2011, 09:32 PM
FTA_FTW is offline
FTA_FTW's Avatar
Joined Apr 2011
Noooo, not the news I wanted to hear hehe jk.
I don't plan on making it a wild racer, as you said it is a high wing trainer. But I just don't trust that stock plastic housing motor, which is mainly why I wanted to replace it. And of course to get a bit more speed.
I can also experiment with different sized props with my 3s batteries?
Old May 18, 2011, 08:15 AM
Joined Mar 2011
all you have to do is call HH and tell them your motor is cracked and you didnt crash it. And they will send you out a new design version of the complete metal endbell motor. Thats what they did for me.
Discussion Pitts Model 12 15e ARF by E-flite I got one!! helifann Parkflyers 7 Nov 19, 2008 10:23 PM
New Product Wrong area Get Real Beginner Training Area (Aircraft-Electric) 0 May 16, 2008 05:27 AM
Sold SOLD Blade CP RTF Electric Micro Heli by E-flite Lakepilot Aircraft - Electric - Helis (FS/W) 3 Nov 26, 2007 05:40 PM
For Sale E-Sky King V1 hopped up, RTF w/ Spektrum Radio zero9046 Aircraft - Electric - Helis (FS/W) 0 May 16, 2007 12:34 AM
Odyssey EP by E-Flite for a beginner flyer? Bellavance Beginner Training Area (Aircraft-Electric) 0 Oct 09, 2001 07:23 PM
