Old Jan 17, 2003, 09:04 PM
tlh101 is offline
Find More Posts by tlh101
FICKLE FLYER
tlh101's Avatar
United States, NM, Elephant Butte
Joined Dec 2002
What do you think about this? Electric FliteStreak
These are plans for an old C/L ship called a Combat Streak. Very good flyer. These plans are 1/2 size of the original mode. If built to the plan size, it will have a 21" W/S, and be about 13 1/2 length.
Am I crazy, or will this be a good park or indoor flyer? What power system do think will be best?
tlh101 is offline Find More Posts by tlh101
Old Jan 17, 2003, 09:12 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
I like it! Has a cool, vintage look to it. I think it could make a nice indoor flyer with that thick symmetrical airfoil, inverted should be quite nice. I'd cut half the wing ribs out and try to build it as light as possible, then start with a GWS DX motor. At less than 24" you should be able to get it to or under 7 ounces AUW. Assuming you're running a geared motor and large prop to slow it down for indoor use, you might also consider enlarging all the control surfaces to give you more stability for low speed maneuvering. Good luck!
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 17, 2003, 10:09 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Hmmm... Looks pretty cool. I think I'd go with maybe 5 ribs total 3/32" thick, 4 1/8" spars w/ a 1/8" spruce LE and a 1/8" balsa TE , 1/16" box fuse with just a few 1/8" square formers... IPS-2XC w/8x4.3... Aileron / Elevator...
Hmmm.......
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 17, 2003, 10:18 PM
columbiarcdude is offline
Find More Posts by columbiarcdude
columbiarcdude's Avatar
St. Louis, Missouri
Joined Oct 2000
WOW ... what a walk down memory lane. I built and flew one of those WAY back in the early 1960's ... it flew great. Back then you could get the plane, engine (McCoy), dope, glue and change back from your $10 bill. After that I upgraded to a Riley Wooten VooDoo and a Fox 35 Combat Special ... hot stuff
Anyway I agree with Tres, it'll probably convert nicely. I'd make it a 3 channel plane. Motor, ailerons and elevator. Looking at the drawing you posted, it looks like the wing trailing edge where the ailerons go is a little bit small ... so I'd enlarge them some. Also mount the verticle stab straight ... you won't be needing to keep it tight on the lines. The elevator looks OK but but like Tres said you might want to enlarge them some too. Won't hurt a thing.
Good luck
Tom
columbiarcdude is offline Find More Posts by columbiarcdude
Old Jan 17, 2003, 10:36 PM
bjsiegel@texas.net is offline
Find More Posts by bjsiegel@texas.net
EFlight=Fun,Big-T=BIG FUN
San Antonio, TX, USA
Joined Jan 2001
Oh Yaa! The thrum of the lines, the whirling background, the surge of adrealin as dive for the kill! Oh Yaa!
My favorite combat plane BG (before girls). Had one with a Fox 35 Combat Special, silked the wings, gloss black on TE and fuse and tail, bright yellow for the pointed stipes on fuse/tail and middle of wing pattern, fire red on the wing LE, bubble canopy with pilot. Oh YAA! (suppressing oil, clean up, breaking in and tuning, tuning, tuning engine, glow plugs, nitromethane raw/burnt smell) Cost me many hours mowing lawns, yes Sir!
I have seen several Flight Streaks recently in the hobby shops but never the Combat Streak. Use the basic design and it should work. Extend the rudder and enlarge the elevator some. The kit would be a real bear to convert thou. LOTS of heavy ply/balsa structure. Which figures since it was designed to fly combat - big, heavy, tough. Flew great as long as the motor was running well. But I could glide it well by "whipping". Finally destroyed it in a direct impact midair - confetti... Oh well!
Love that plane,
Bernard "Crash" Siegel
bjsiegel@texas.net is offline Find More Posts by bjsiegel@texas.net
Old Jan 17, 2003, 10:53 PM
Wade Joos is offline
Find More Posts by Wade Joos
Wade Joos's Avatar
United States, UT, Salt Lake City
Joined Aug 2002
Flite Streak
Oh the control line days. Had one of the flight streaks. One day the "down" line broke--- full up! Not much to do except watch it make real tight loops. Darned if that thing didn't come out just right so that the bottom of one of those loops was right on the ground. Broken prop. No other damage What are the odds?
Wade
Wade Joos is offline Find More Posts by Wade Joos
Old Jan 18, 2003, 02:26 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
At 21" it was either a 1/2 A .049 or A .09. An Astro 010 would be equivelent. They were pretty fast at about 30 -35 mph, but would loop in 30'. Looks like a fun project.
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jan 18, 2003, 06:04 AM
Russell2 is offline
Find More Posts by Russell2
Deer Park, Tx, USA
Joined Feb 2001
The Flite Streaks were great sport U/C too. I had 1/2a,b,c class and they were all great. In fact, there is still a large one hanging in my dad's garage with intact covering.
Russell2 is offline Find More Posts by Russell2
What do you think about this tape for zagi's funflyer Foamies (Kits) 2 May 17, 2016 08:14 PM
Yippee! What do you think about this??? Extra 3D Product Announcements 11 Jan 07, 2005 11:43 PM
Question What do you think about this camera mount? JoeCrasher Aerial Photography 3 Jun 10, 2004 01:15 PM
What do you think about this lipo charger? Gigaah Batteries and Chargers 5 Feb 22, 2004 08:51 AM
What do you think about this......?? mlehman Parkflyers 6 Feb 26, 2003 03:14 PM
