Arbiter,
I'm prob. going to try to do the #12 plane. My airbrush will struggle with the fine dark gray over the light. I do like the green upper surfaces on this one and the #8's wing and tail. Here is another link to a plastic model painted as #12, also some history according to the modeler. http://modelingmadness.com/reviews/a...er/tmc262b.htm Will see how it turns out? Might have to also think about doing #14 since it did not exist and then I can take liberties on paint. I've modified a few adaptors using a lathe with pretty good results, still easy for bit to wonder a few thousands and ruin adaptor. I believe the proper methode is to ream to final dia. but most people are not equiped for this. Next set I mod. for 2.3 I will under drill by a few .000 and use Bill's technic to slowly work by hand. Also motor shafts can be over or under a little which does not help matters. To bad GWS did not use collit type adaptors in their design, since I believe this type to be the best overall for good results. Cheers--Stacker |
Great work Stack! Nice to see this thread got back on track. I hate trolls.
J |
Latest blog entry: F7F Tigercat from Palmer Plans
Cool! Bring her to Vegas. With all the mods you do to these 262s, you should probably order a shipping container full of them.
J |
Jake,
Antenna was a real pain! Don't think I want to do another unless it's for a HE219. Check this model out. http://modelingmadness.com/reviews/a...er/tmc262b.htm I thought they were also all grey and dark gray untill I started looking on the web. I think my green is to dark and I will prob. put one more lighter coat on of a bit lighter color. Fuse will have dark gray sploches on similar to the model. The green with white crosses on top might make it easier to see comp. to the light gray of the others, unless I fly with the green hils in the background. Cheers--Stacker |
I wounder, if we use twin EDF40 on her, will make her looks even more closer to a real one engine shape!
![]() GWS EDF40 can out put 444g with BL2018 motor: http://www.rcgroups.com/forums/showthread.php?t=848309 Yet since from such a small dia. EDF can get 444g, the airflow speed will much speedy! ![]() I believe this will make the final topend speed go faster!?
GWS262 with nearly scale nacelles
Well Dave I've been putting this one of for a while, but said I'd do it, so I'm finally on it.
GWS262 with Microfans and Hyperion Y22s 600kv motors. May have to really abuse the setup on 4s to get what I want out of it, but it'll go.One nice touch is that the stock outlets are very small for a 64mm fan, so I didn't need to do too much downsizing on the outlets to get the dia down to 45mm. Just a 1/16" balsa ring shim around the heavy gloss paper thrust tube was all it took to resize. The fans had already been mounted in cutoff sections of A10 nacelles and were tested on another plane in flight, so they were just a matter of padding with depron to blend into the nacelles, after epoxying in place. Bill
The current draw actually is an issue, as I would like to use an EVO 3s-1800 for lighter weight. Probably will need the 2170 though, so as not to abuse the batt. I figure that the extended nacelles moves these motors far enough forward from stock that they will decrease the need for noseweight, even if they are lighter than the 3900kv GWS long cans. Bill
