Uvalde, TX
Joined Sep 2002
I'm building an XE2-400 right now and will be putting a Mega 16/15/4 on it. I did a lot of research before ordering my equipment and I chose CP1300 SCR cells instead of the HR1700 AUPs (against the advice of some). From what I gathered, the HR1700 AUPs are much fussier than the CP1300s and will take significantly longer to charge. According to this guy, the CP1300s gave his brushless Zagi the best performance and they take less than 20 minutes to field charge: http://home.flash.net/~jecramer/zagi.htm
Others here have told me the HR1700 AUPs require anywhere from 30 to 45 minutes to field charge, depending on whether you want to "push" them. Others said you should never push these cells when charging them. Either way, the charging times appear to be significantly longer than the CPs which are "rapid charge" cells. I don't understand the advantage the HRs offer - so you maybe gain a minute or so in flight duration but then they take twice as long to charge. For me, maximizing stick time in a flying session is more important than maximizing duration for a given battery pack. I hate being grounded waiting for packs to recharge. P-calc showed the 6x4 prop to be the most efficient for this entire set up, with an efficiency rating very close to the maximum possible efficiency. To be safe, I ordered an assortment of different props in this diameter/pitch range. Hope this helps. Houdini |
| Thread Tools | |
| Discussion Help with Zagi 60 upgrade to Mega AC 16/15/4 | reefboy | Flying Wings | 36 | Jan 13, 2007 05:55 PM |
| Question Prop for Mega ACn 16/15/5 | foamflyer | Power Systems | 10 | Jan 05, 2006 11:41 PM |
| Suggestions needed for a gear box for MEGA 15/16/4 | farnboro flyer | Power Systems | 15 | Aug 03, 2005 03:25 AM |
| Help with what prop for this motor and GB | Mike Parsons | Power Systems | 8 | May 21, 2003 07:52 AM |
| Mega 15/16/4, 2.5:1 Gearbox Question... | Flying Low | Power Systems | 8 | Oct 19, 2002 08:31 PM |
