Old May 13, 2008, 08:47 AM
suirendoujin is offline
Find More Posts by suirendoujin
The Far East
Joined Jan 2006
Help!
Goettingen 580 airfoil coordinate
I need it to design a wing for my current scale sailplane project. Coordinates for this particular airfoil was not in UIUC database, Compufoil, or in any of books I have. Would appreciate any info. TIA.
suirendoujin is offline Find More Posts by suirendoujin
Old May 13, 2008, 10:26 AM
Thermaleer is offline
Find More Posts by Thermaleer
Florida
Joined Jul 2004
suirendoujin, I could not even locate this airfoil in Profili 2.18. Google did not show up anything obvious, looks like this one will be tough. Joser
Thermaleer is offline Find More Posts by Thermaleer
Old May 13, 2008, 06:18 PM
The Far East
Joined Jan 2006
Thermaleer, Yes, this one IS tough. Goettingen airfoil numbers are numbers given in sequence to an airfoil design, so you have to get hold of the actual coordinates or an accurate drawing. I am hoping European modeler can help me out.
Old May 13, 2008, 11:46 PM
Florida
Joined Jul 2004
What aircraft was it used on? Maybe it can be lofted from a set of drawings?
Old May 14, 2008, 08:45 AM
The Far East
Joined Jan 2006
This airfoil was used on Kyutei Type 5. A vintage sailplane with historic significance here in Japan. Made the first over an hour flight, auto-tow and aero tow. My build thread is here, http://www.rcgroups.com/forums/showthread.php?t=815703
There is a drawing of the airfoil in one of the 3 views I have. Unfortunately, its only 37 mm in chord, so in order to use it I must blow it up ten times. So much with accuracey. Goettingen 580 does look vaguely? similar to thickened Eppler 214. So, I f I cannot obtain coordinates, then will have to take an alternative approach.
Old May 14, 2008, 10:32 AM
ghostofpf1 is offline
Find More Posts by ghostofpf1
Joined Mar 2007
Assuming that's the fullsize gliders foil...
From what I've read scale foils don't always fair well at modelling sizes.Have you considered using something similar but designed for our reynolds numbers spread ??
HTH
Ghost
ghostofpf1 is offline Find More Posts by ghostofpf1
Old May 14, 2008, 10:45 AM
Lance Prior is offline
Find More Posts by Lance Prior
Salt Lake City, Utah
Joined Nov 2004
You may want to consider a thick high camber HQ airfoil.
Lance Prior is offline Find More Posts by Lance Prior
Old May 14, 2008, 03:05 PM
Bernd Brunner is online now
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Or may be a sd7062 (thinned to 12%). IMO itīs not necessary to add more drag by using too thick airfoils. The Re-numbers will be at least 150k or 200k.
Bernd
Bernd Brunner is online now Find More Posts by Bernd Brunner
Old May 14, 2008, 03:42 PM
Joined Nov 2004
I suggested thick purely for scale appearance.
Looking at the drawing the foil appears to be about 15% thick or more.
Old May 14, 2008, 05:18 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Is the University still there? That's where the airfoil came from, isn't it? If so, perhaps if you can find a German speaker you can find it and they'll just give you the coordinates. A lot of trouble, I suppose. Perhaps they even have all those coordinates on a web site?
lincoln is offline Find More Posts by lincoln
Old May 14, 2008, 06:16 PM
The Far East
Joined Jan 2006
Thank you all for your input. Goettingen 580 was used on full scale. At quarer scale, I thought, well, was hoping, to get away with it, biased more to scale appearance than performance.
Old May 14, 2008, 09:40 PM
jcpatrick is offline
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
United States, VA, Basye
suirendoujin - What happened to Hiroshi Takeuchi's NASG Airfoil Database? There were a lot of Gottingen airfoils there, and now the site is gone.
Here is a comparison of the airfoil you posted, the SD7062 Bernd suggested, and a Drela airfoil designed for hand launch gliders. You might want to try this one. If you find the 580 coordinates or data, I'm sure someone will help you make some airfoil drawings.
jcpatrick is offline Find More Posts by jcpatrick
Old May 15, 2008, 09:25 AM
The Far East
Joined Jan 2006
Well, based on the rather simple, if not crude airfoil shape provided with the 3 views I have, it looks like Goe 580 had a 13.5 % thick airfoil. If I can modify the coordinates of AG27-13% by thinning it to say, 12 % and giving it Philips entry, I might have an airfoil which might be a nice compromise between scale looks and performance. Thank you jcpatrick. I will probably reach a verdict? on Monday.
Old May 15, 2008, 12:04 PM
Joined Nov 2004
Are you talking about taking an AG27 and making it 13% thick?
You would probably be better off to use an airfoil that is designed to be the thickness you require instead of making a thin one thick.
Old May 15, 2008, 01:52 PM
dare to thermal
Mannheim, Germany
Joined May 2004
suirendoujin, what do you mean with "scale appearance"? Wouldnīt you fly the model, is it static? May be you can ask Loopingfred about the airfoil he has used on his KA-3 (2.5m; scale 1:4). By the way, i have looked at the polars befor i recommended the modified SD7062.
Cheers,
Bernd
Discussion airfoil coordinate extraction Pheasant The Builders Workshop 5 Feb 05, 2006 10:02 AM
