Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
Old May 12, 2008, 05:33 PM   #1
AMA 125691
wmcneal's Avatar
Send a message via AIM to wmcneal
RCPowers.com Extra 300- Free plans
I can never resist a free plan so I downloaded this one from Dave at rcpowers.com two days ago and got busy. I still have to install the electrics,but I think it's going to be a nice one.
See link to post for plans--->> http://www.rcgroups.com/forums/showp...3&postcount=10
  • Name: Extra300b.jpg
Description: Yankee Doodle pigeon is gonna git hees tail feathers shortened! Yankee Doodle pigeon is gonna git hees tail feathers shortened! 70.0 KB · Views: 1555
  • Name: Extra300c.jpg
Description: Dick Dastardly at the controls. Dick Dastardly at the controls. 68.8 KB · Views: 1163
wmcneal is offline Find More Posts by wmcneal   Reply With Quote
Old May 12, 2008, 07:03 PM   #2
yardboz1's Avatar
Looks good. I also downloaded the plans, but then got busy with other builds. What are you planning on powering this with? Looking forward to a report on the maiden! BTW, coudn't help but notice your pilot looks a little like your avatar.
Sterling
yardboz1 is offline Find More Posts by yardboz1   Reply With Quote
Old May 19, 2008, 09:33 PM   #3
Cant you feel the freedom
NuttyPro67's Avatar
Send a message via AIM to NuttyPro67 Send a message via MSN to NuttyPro67 Send a message via Yahoo to NuttyPro67
That Extra 300 is looking EXCELLENT! Post some flight videos if you can when she gets flight worthy.
NuttyPro67 is offline Find More Posts by NuttyPro67   Reply With Quote
Old May 19, 2008, 09:38 PM   #4
AMA 125691
wmcneal's Avatar
Thanks! Just finished it tonight. It'll be ready for a maiden when the wind finally calms down around here. Here it is ready to fly at 15 oz. I added wheels and tail skid for takeoffs and landings. Power is a tower pro 2410-12 with a 9x4.7 APC prop
  • Name: Extra300d.jpg
Description: 2410-12 Tower Pro motor 2410-12 Tower Pro motor 58.5 KB · Views: 2266
  • Name: Extra300e.jpg
Description: Also added a Bp hobbies BEC for Extra safety. ;-) Also added a Bp hobbies BEC for Extra safety. ;-) 60.1 KB · Views: 2142
Old May 20, 2008, 06:03 PM   #5
Just one more flight...
RCSuperPowers's Avatar
That is so good wmcneal! What a paint job and the wheels take it to the next level.
Some info for all, here is the power set up I used on mine:
Motor: www.MotrolFlyUSA.com 2205-1350kv / 20A ESC
Prop: www.GwsProps.com 10x4.7
Battery: www.CommonSenseRC.com 3S 700 mah, 15C
Servos: www.CommonSenseRC.com (3) HS-65
FREE PLANS:
http://www.rcpowers.com/PDFplans.htm
  • Name: RCG1-sm.jpg
  • Name: RCG2-sm.jpg
RCSuperPowers is offline Find More Posts by RCSuperPowers   Reply With Quote
Old May 22, 2008, 10:26 PM   #6
AMA 125691
wmcneal's Avatar
Well, the winds finally subsided enough this evening that I was able to go out to the park and test fly my new Extra 300 under the stadium lights after dark. I plugged in the battery, double checked the control surface movements and floored the throttle. After a roll of about 15 feet she rotated to vertical, whereupon I reduced the throttle and brought it into a nice hover about 25 feet up. It was not as stable as I thought it would be, so I pushed forward and leveled it out and trimmed it properly. After few more circuits around the field I landed it and replaced the 910mah battery with a 1350mah and took off again. It was more stable with the cg moved forward and was easier to hover. I then did some mild aerobatics and rolling circles, etc. I did harriers and knife edges. It was really fun! The only bad thing I noticed was that the fuselage twists while rolling fast. It is weird to see the horizontal stab out of alignment with the wing. It does return to normal once the air load is removed. I will have to figure out some way to brace it without adding too much weight.
Old May 23, 2008, 06:04 AM   #7
Trees Think My Planes R Tasty
mastrsn's Avatar
Location: about 12" from my computer in Jacksonville Fl.
Remember my big Red, White and Blue Tribute foamy? ( no longer in production ) It used to twist at the tail too. I think it's because both have long fuselages and 6mm foam doesn't have enough stiffness. I'd be careful trying to stiff it up and not add anymore weight. Then it won't 3d as well...
mastrsn is offline Find More Posts by mastrsn   Reply With Quote
Old May 23, 2008, 11:08 AM   #8
AMA 125691
wmcneal's Avatar
Yes I remember it.
I flew the extra again this morning. I now think some of what I was seeing was part optical illusion because of the ailerons being deflected so far. Anyway, it still flew great. I think I'll just leave it alone and concentrate on my 3d flying skills so I don't doink it.
Old May 23, 2008, 06:24 PM   #9
Hey Bill, saw you doing a knife edge with your new plane when I cut through the park on the way to work this AM....Knew better than to stop as I would have been late for work for sure....Did you see the post here http://www.rcgroups.com/forums/showthread.php?t=769078 where the guy added a truss system to help with the flex ??
BillyBee is offline Find More Posts by BillyBee   Reply With Quote
Old May 23, 2008, 06:34 PM   #10
AMA 125691
wmcneal's Avatar
Hey Bill. Thanks for the link. I just might try that.
Old May 24, 2008, 02:01 PM   #11
Hi
Where is the point of gravity of your plane ?
Radioactiveman is offline Find More Posts by Radioactiveman   Reply With Quote
Old May 24, 2008, 02:26 PM   #12
NuttyPro67's Avatar
The center of gravity can be found on the FREE PDF plans that you can download at RCPowers.com or at this link: http://www.rcpowers.com/PDFplans.htm
Thanks!
Old May 24, 2008, 03:13 PM   #13
AMA 125691
wmcneal's Avatar
I fly mine with the center of gravity right on the wing spar, or 1.75" (45mm) back from the leading edge at the wing root.
Old May 24, 2008, 03:27 PM   #14
Oh yes i was blind sorry and Thanks for the answers.
Old May 25, 2008, 07:44 PM   #15
AMA 125691
wmcneal's Avatar
Got a video of a flight this morning. It was a little windy, but it was still fun. Enjoy!
http://vimeo.com/1976551
Discussion 3D Batix Extra 330 Free plans Great plane Ben-Rod 3D Flying 916 Yesterday 09:22 PM
Video 3DHobbyShop.com Extra 300 SHP Get Real Airplanes - Electric Videos 2 Oct 09, 2007 02:11 PM
Video 3DHobbyshop.com Extra 300 SHP 55" BoneDoc Airplanes - Electric Videos 5 Jul 30, 2007 10:16 PM
Looking for suggestions for a Extra with free plans. CptanPanic Foamies (Kits) 2 May 27, 2005 11:52 AM
Congratulations SimpleM!
