I think that may have been my problem. I was in a really tight canyon and I'm using a yagi I want to say it's an 8dBi and inverted V antenna on the plane. I just found out that circular would have been better to prevent multipathing. I thought it was strange that as I would fly further away and above the canyon walls my signal would clear up.
I think I'm going to go with one of these and get some circular antennas to go along with it. http://www.readymaderc.com/store/ind...roducts_id=823 What do you think? What camera are you guys using. I have a Pixim but I'm not having much luck with it. |
crosshair is the latest and greatest.
If you are interrested in my advice. I use the Skewed planar wheel on the transmitter side, and I raise it above the fuselage about 9". That configuration resists multipathing better than any other configuration that I have tried. Then for an omni The stack fan / or skewed planar wheel is a good antenna. I built a (skewed planar wheel / fan stack) that I am really liking, but I can't strike hugo's interrest in it. Then for high gain directional the crosshair is an excellent choice (from what I have read) I'm still stuck in the helical era ![]() Hope this helps Quote:
Ryan,
There are a couple of things that could cause decreased range. First off, I should state that I am very satisfied with CP antennas, but lets put that aside. reasons for decreased range 1) you have damaged the antenna and the angles are not quite right 2) you are getting a short circuit between the driven and the ground poritons of your antenna. This could be a single wire crossing over and touching a portion of the sma connector, or elements that it does not belong too... 3) You have a poor connection at a sma pin (I experienced this once, and now I solder the pins), or a poor solder joint which is causing too much resistance. 4) you have changed something in your setup, and now you have some sort of physical impediment, or RF interferance in your system. 5) your flying habits have changed, and now you are flying lower, and behind objects, which does not bode well with LP *I have some antennas that you can have. |
What kind of antennas are you willing to give away? I defiantly would like to try them. Here is still from a flight I had yesterday of the Little Grand Canyon. |
I've got a SPW, fan stack, and helical that you can have.
*that place is amazing... Quote:
| Thread Tools | |
| Best Camera for aerial photography? | BillH | Electric Plane Talk | 26 | Dec 11, 2010 07:14 AM |
| Aerial Photography | dstout | Parkflyers | 10 | May 13, 2002 03:15 PM |
| Best plane for aerial photography | dgtaylor | Electric Plane Talk | 18 | Oct 01, 2001 02:21 AM |
| Digital cameraes used for aerial photography | JensJakob | Electric Plane Talk | 15 | Sep 20, 2001 08:49 PM |
| Aerial photography - first attempts | leccyflyer | Electric Plane Talk | 11 | Jul 29, 2001 03:20 PM |
