Old Aug 06, 2012, 03:57 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
You'll have to explain to me how you guys are using a 600mhz low-pass filter to prevent a DL from interfering with 1.2ghz video. DL is 433mhz, and the video is 1.2ghz. How does a 600mhz filter help anything?
I could see using a 400mhz filter on your video receiver, which would filter out 433mhz interference. http://www.digikey.com/product-detai...360-ND/2270981
Somebody explain to me what you're doing, please.
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Aug 06, 2012, 06:05 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Todd,
The transmitter emitts a lot of noise on a multiple frequency of 433 mhz, which affects the 1.2 band.
By placing the low pass filter inbetween the transmitter, and the antenna, you cut out a lot of that noise.
I don't get much interferance with chainlink on low, but when I kick up the power; I still have to step back from the ground station, even with the low pass filter.
before I put the low pass filter on the transmitter I couldn't be in close aproximity of the ground station.
I think DL only has one power, and it puts out more than Chainlink when it is on low, so you can see where you would run into issues.
m_beeson is offline Find More Posts by m_beeson
Old Aug 06, 2012, 06:11 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I've been thinking about using a high pass filter for the Vtx. "they say" that the 1280 can interfere with the 433 reciever.
It would have to be higher than 400Mhz though.
I just looked on digikey, and didn't find one that would work.
Old Aug 06, 2012, 06:27 PM
More Combat Please!
Utah
Joined Dec 2003
Originally Posted by m_beeson View Post
The transmitter emits a lot of noise on a multiple frequency of 433 mhz, which affects the 1.2 band.
I still don't see how a 600mhz filter is gonna help you, unless the 600mhz filter also filters on multiples of the frequency, in which case it'd filter 1200mhz.
Which transmitter are you talking about? Do you put the low pass filter on the video transmitter before the antenna, or on the UHF 433mhz transmitter before the antenna?
The new DL V2 has a switch for low and high power. The high power setting is what was formerly the ONLY setting, and they've introduced a new "low power" setting, for those who aren't going long range for things like MultiRotors. That extends the life of the TX battery.
Old Aug 06, 2012, 08:24 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
it goes in front of the UHF antenna.
It is a low pass filter, so it will not allow any rf to get past that is higher than 600Mhz.
That's a good improvement.
Old Aug 07, 2012, 11:55 AM
cardo is offline
Find More Posts by cardo
Mountain? What mount..CRASH!!
cardo's Avatar
United States, UT
Joined Feb 2008
ya, Low pass=it will pass the lower frequency's through. Same with High-pass, it will pass the high through wile blocking the low. You just have to find ones with the correct specs for your application.
I have had the same problem with my DL totally killing my 1.2ghz video. I finally figured it out when I was getting ready to fly and I was getting no video at all. After checking all the connections on plane/ground station I simply turned off the DL and ta-da, I had video. So I found that I have to make sure the video is working first, then I can turn on my DL. I need to get some filters.
cardo is offline Find More Posts by cardo
Old Aug 07, 2012, 12:40 PM
More Combat Please!
Utah
Joined Dec 2003
Okay, that makes sense now, thanks for clearing that up for me.
So the frequency on a filter is not to filter a specific frequency, it's to filter all frequencies above or below the filter value. Got it.
I didn't realize that you put them on the UHF antenna, I thought that they went on the plane.
So I bought a 2.4Ghz High Pass Filter for reducing interference to GPS and RC Receivers. I put it between my VTX and video antenna. That allows 2.4ghz and above frequencies, while blocking everything below it, right?
Old Aug 07, 2012, 12:47 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Yep, that's correct. High Pass means it passes from that frequency and above, everything below is atenuated. There's also BAND pass filters which filter frequencies above AND below which is similar to what you were thinking before, they only let frequencies around that target band to pass .
Castel101 is offline Find More Posts by Castel101
Old Aug 07, 2012, 12:58 PM
More Combat Please!
Utah
Joined Dec 2003
Is it just me, or does it seem like vendors should automatically include a band filter on any products they sell that are targeted to a specific frequency?
Should be law that all UHF and RC gear have a band filter internal to the gear so it only broadcasts on the specific frequency.
Old Aug 07, 2012, 01:15 PM
Castel101's Avatar
Joined Sep 2011
Well, the problem is that these are all passive filters, meaning there's no amplification or active component. No passive filter is ideal so the resulting signal output has always less amplitude than it's input, i.e. some attenuation. My guess is that manufacturers don't include a filter because of this and cost and because not everybody needs it. An active filter would need to be powered and will cost more.
Old Aug 07, 2012, 03:59 PM
More Combat Please!
Utah
Joined Dec 2003
Ah, makes sense. Pfff. So many issues with every aspect of FPV.
So here's a question for you guys.
Backstory: I tossed a prop on my X650 quad during take-off, and it flipped over onto it's head on the asphalt. Broke all 4 props and got a little sandy grit in the motors.
After that it just won't fly. Replaced props and cleaned out motors, but when I lift off, it shakes randomly, has little spasms. It's not oscillations like you get when your gains are off in the controller, but just random twitches. Dips a side suddenly and then straightens back up.
I thought maybe I'd damaged one of the motors, so I swapped each one out with a good one until they were all new motors. Still acts the same.
I'm thinking maybe one of the ESC's got messed up when the motors kept spinning after flipping it. The resistance could have caused one to go weird. But it seems like it wouldn't fly at all if that were the case.
Could the Naza controller, maybe the gyros, have been damaged? If so, seems like it wouldn't fly at all.
It'll lift off and hover, it just twitches like it has a nervous tick.
Any thoughts as to why?
Old Aug 07, 2012, 04:16 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
...because it's a quad. Talk about finicky! Dang, these things.
elCapitan is offline Find More Posts by elCapitan
Old Aug 07, 2012, 04:24 PM
More Combat Please!
Utah
Joined Dec 2003
Yeah, but the thing flew rock solid before the crash. So I know it's not the frame. The frame is fine. I was getting some incredible control & stability out of it. I'm sure a hex is more stable, but a hex also has 50% more things that can go wrong with it.
EDIT:
I just swapped the NAZA controller, and it does the same thing. Must be a bad ESC or a bad wire connection in one of the arms. Ugh, didn't buy a spare ESC in this brand. I'm kicking myself.
Old Aug 07, 2012, 05:35 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
No, I wasn't talking about the frame. I just meant multi-rotors in general have approx. 1.3 billion things that might go wrong. You warned me, and I've confirmed it. So why is it giving you problem? Because it hates you, Todd. They hate me too.
Good luck, man. Hopefully some more successful multi-rotor flyers can help you out.
Old Aug 07, 2012, 07:20 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
replace all the motors esc's and the control board and I bet it works perfect
3DNater is offline Find More Posts by 3DNater
Digital cameraes used for aerial photography JensJakob Electric Plane Talk 22 Jan 22, 2014 09:41 AM
Best Camera for aerial photography? BillH Electric Plane Talk 26 Dec 11, 2010 07:14 AM
Aerial Photography dstout Parkflyers 10 May 13, 2002 03:15 PM
Best plane for aerial photography dgtaylor Electric Plane Talk 18 Oct 01, 2001 02:21 AM
Aerial photography - first attempts leccyflyer Electric Plane Talk 11 Jul 29, 2001 03:20 PM
