Old Jul 09, 2012, 07:23 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by JONBOYLEMON View Post
I was thinking of a RC deployable smoke. It would have to be such that it wouldn't start a fire.
Originally Posted by seearestacey View Post
Not only did I loose a GoPro, but the video on it...
Originally Posted by Wind_of_Change View Post
I should have new bearings for the Hex this week, and I'll think about doing some flyovers from the ridge.
I'm sure that I'll have to pop for another GoPro, but I'm still walking it off.
It's still too soon, and I start getting upset when I think about replacing it
Most everything on board will sustain some moisture without too much damage. Hopefully; It's closed up pretty good in a bay.
So If it takes a while, then I'll just be happy if it shows up...
I figured that I could hike the top and see a glimmer of white in the trees, but that is not the case.
m_beeson is offline Find More Posts by m_beeson
Old Jul 09, 2012, 08:52 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Well if it crashed hard, there's a possibility that it ejected the main lipo pack. So all you need to do is wait until a deer bites into it and shorts the pack with his teeth, then you'll have a smoky signal you can track. That could be problematic if he's running like crazy... a moving smoke signal isn't gonna help. Hopefully it just kills him and he sits there and smokes for a while. If there's enough juice in your pack, you can bring a fork and knife and have some fresh cooked venison right there on the spot!
I always hope when I have a crash that the pack doesn't eject, that way it'll sit there live and fully drain the lipo til it's dead. The best idea is to just make sure your packs are double secured. I use a velcro strap as well as a door.
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Jul 11, 2012, 11:23 AM
cardo is offline
Find More Posts by cardo
Mountain? What mount..CRASH!!
cardo's Avatar
United States, UT
Joined Feb 2008
Originally Posted by m_beeson View Post
Mike K,
I did a little testing with the fmkit, and was satisfied that I would be able to use it,
but I would recommend doing some long range testing,
and I would say that a directional antenna is a must.
a signal strength indicator wouldn't hurt either.
-Mike
I feel your pain Mike, I have had to make 4+ hikes to find a plane. One of them being treacherous. I have Todd to thank for helping me find the wing in the picture. I had lost all hope....then Todd called me on my cell and was asking me where I was at on the mountain. That got me looking around so I could describe my location, and then there it was sitting in a bush up above me on the slope.
I hope you can find your plane.
If your in a pinch you can make a directional antenna by getting a Pringles can, poking a hole in the bottom and putting your handheld radio antenna through the hole. It's not the best but it will work. Or there are lots of antenna plans online...just have to find one that will suite your needs.
cardo is offline Find More Posts by cardo
Old Jul 11, 2012, 03:55 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Hope you can fly your plane soon. Really sucks!
Castel101 is offline Find More Posts by Castel101
Old Jul 12, 2012, 12:12 PM
seearestacey is offline
Find More Posts by seearestacey
Keep Calm, and Carry On...
seearestacey's Avatar
United States, UT
Joined Feb 2012
http://www.cnn.com/2012/07/12/world/...ugh/index.html
seearestacey is offline Find More Posts by seearestacey
Old Jul 12, 2012, 12:38 PM
United States, UT
Joined Feb 2012
m_beeson,
Do you think a gps type tracker that sends it's coordinates via. cell phone signal (GPRS) would work in the area you went down in, or it's too remote and wouldn't have had a signal anyway? I'm still kicking around the the FMKit Beacon idea, but it sounds like it wasn't much help much this time. Would you still recommend it?
Old Jul 12, 2012, 11:22 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
cardo,
Wow, I'm glad you found it.
I still have a couple of brutal hikes that I need to make, before I call it...
I also should have the hex in flying order here shortly, and that "may" help.
Old Jul 12, 2012, 11:27 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
m_beeson,
Geeze,
I don't know what to say about the fmkit at this point. I really don't know.
It could have been a LiPo that had too little MaH, or maybe it just didn't send the signal out from where it was. I just don't know.
I am looking at the gprs, but when I was on the mountain, my cell coverage was horrible; even though I was just above the valley, and in plain view of any and all cell towers.
Lynn & Nate have a fmkit, and we need to do some more extensive testing, and we really need to build some directional antennas.
I know that I'll try to resolve this issue before I fly behind mountains again...
Old Jul 13, 2012, 12:04 AM
More Combat Please!
Utah
Joined Dec 2003
You do know that you're not supposed to fly behind mountains, right? I mean, that's sort of an important thing to know as an FPV pilot.
Old Jul 13, 2012, 12:10 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Hey, better than trying to fly "behind" bodies of water. I definitely need a new ESC for my Assassin now.
elCapitan is offline Find More Posts by elCapitan
Old Jul 13, 2012, 12:15 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I know it sounds funny, but with circular polarized antennas, and 433 pumped up on high, I have flown behind mountains.
Not completely behind mountains, but deep enough that it wasn't considered LOS any more.
Old Jul 13, 2012, 11:46 AM
More Combat Please!
Utah
Joined Dec 2003
That's what ya call "Dancing with the Devil", or "Flirting with Disaster", or "Putting it all on the line"...
or some other things that we shouldn't say in a public forum.
I've intentionally flown behind small stacks of rock and the like, lost signal for a few seconds, no problem, but those couple of times I've unintentionally gone behind a big hill and lost video, it always scares the crap out of me. Thank heavens DragonLink always goes out AFTER video, so I can yank the stick and pull up, flying out of danger just as soon as the video starts to break up.
Old Jul 14, 2012, 06:56 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have thought for some time that maybe we should copy what the falconers do.
Patrick is a falconer and at one time was an RC flyer. He has a small tracking device that is small enough he can put them on the back of his birds. He can track the bird for 25+ miles with a scanner that is on a hand head antenna.
I know his battery on the transmitter is capable of broadcasting 7-35 days depending on which model you get. The battery is small enough a peregrine not only can carry it but still be fully aerobatic.
http://www.merlin-systems.com/falconry/fmv.htm
Lee is offline Find More Posts by Lee
Old Jul 14, 2012, 02:36 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Lee,
Lynn has been talking to me about these systems for a couple of months now.
Some of the equipment can be very expensive, but it is worth looking in to...
Anything is better than loosing a plane
-Mike
Old Jul 14, 2012, 08:56 PM
KatanaGuy is offline
Find More Posts by KatanaGuy
Design, Build, and Fly
KatanaGuy's Avatar
Pleasant Grove, Utah
Joined Nov 2001
My flight at Pineview Reservoir earlier today. Raw, uncut. This is mirrored in the FPV fourm: http://www.rcgroups.com/forums/showp...postcount=9643
Pineview Resevoir FPV: Boat Buzzing and Wake Boarding Backflips (9 min 3 sec)
-Steve
KatanaGuy is offline Find More Posts by KatanaGuy
Digital cameraes used for aerial photography JensJakob Electric Plane Talk 22 Jan 22, 2014 09:41 AM
Best Camera for aerial photography? BillH Electric Plane Talk 26 Dec 11, 2010 07:14 AM
Aerial Photography dstout Parkflyers 10 May 13, 2002 03:15 PM
Best plane for aerial photography dgtaylor Electric Plane Talk 18 Oct 01, 2001 02:21 AM
Aerial photography - first attempts leccyflyer Electric Plane Talk 11 Jul 29, 2001 03:20 PM
