Yep. It's an interesting gizmo. You put a transmitter on your plane, and then use a direction finder.
http://www.com-spec.com/rcplane/index.html It may work for finding your downed plane, but it's not really an elegant solution. A GPS transponder would be better. |
United States, UT
Joined Feb 2012
It's even more expensive, but claims 20~90 mi range from air (9 mi ground) |
For lost aircraft beacon I've been leaning towards this http://fmtv.us/rf_beacon.html its $50.00 dollars weights 2grams can be connected to a 1S lipo Here is a thread on it http://www.rcgroups.com/forums/showthread.php?t=1274173
Mike K. |
United States, UT, Herriman
Joined Jan 2012
I've used this one for rockets.
http://www.bigredbee.com/BeeLine.htm With a yagi antenna and basic receiver, I can track it from quite some distance. It can work over the whole 70cm band, which is nice. They have GPS capable units as well... |
You can set it to a FRS frequency, and set it to delay activation. Then with a little practice you can walk to the transmitter. If you hold the FRS radio against your body, then you get static when you are pointing 90deg, and 180deg from the transmitter, and no static when facing the transmitter. when you are a distance, then you can use a yagi for super long distances, and as you get closer the three tones are three strengths, so you start to pick up more tones. You could easily get within 100 feet of your plane, and maybe closer with very little practice. I am using a 1S LiPo that I pulled out of a keychain cam. |
Multi-rotors are really fun to fly, but I don't like the video I'm getting from them as much as the video from my recently deceased wing (RIP). It's just not as interesting as the big scenic stuff... at least not from a viewers perspective.
But dang they're fun to just go out and navigate around obstacles. I've had a few pretty close calls, chopping branches & leaves, bouncing off rocks, missing holes in rocks I was aiming for, etc. Haha, really fun. But the crashes suck. I ordered a new quad, the TBS Discovery, so I can have a frame that's easier to maintain, is more compact, and designed for action flying. I'm hoping I'll be able to get better footage with it. I did a three mile hike into a big waterfall on the back of Timp hoping to get some cool footage, but the wind picked up and started gusting hard. Plus there were like 100 people at the falls on Memorial Day, so it was too crowded to get any cool nature shots. I'm going back on a quiet calm day though. My new antennas showed up, and wow are they pretty. I got a nice helical and 3 Skew Planar Wheels for the new planes & quads. Finally getting my antenna tracker set up, now that my Deep Reaper is finally dead. I told myself I'd wait until I built a new plane, and it took longer than I expected, given how aggressively I fly. |
Mike B,
Wow, don't accidentally flip that thing over on it's head, or that antenna is toast! haha. I haven't seen that camera mount on the 550 before. Did you make that, or buy it somewhere? You're still getting quite a bit of vibration in your video as well as the props being visible. Are you filming in wide or medium FOV on the GoPro? If the video has wobbles, it's useless to me for video production. I'm crossing my fingers that the TBS will work, but I'm afraid after reading some of the reviews tonight about those arms being really bad for video. The TBS uses the flamewheel arms as well, in a spider configuration. T |
I found a gimball last night that I ordered.
The FPV and video portion of this monster were just slapped together to get it flying. One thing is for sure, and that is that this setup will change. I'm just flying and having fun with it. the shakey picture is just part of the shotty mounts.
United States, UT
Joined Feb 2012
I am thinking I could note the last recorded lat/long coordinates from the OSD then plug them into a GPS or phone and get me to within earshot of a beeper, then perhaps use other beacon type methods if the plane goes down without video. Has anyone ever had to go recover a lost plane yet? BTW... Beeson, have you guys ever recover that SW that went down earlier this year? |
I'm just using these cheap discovery buzzers.
http://www.hobbyking.com/hobbyking/s...y_Buzzer_.html I'm putting 2 or more on each of my planes from now on. They're so cheap, and you don't know which attitude your plane will land in a crash. So I put a buzzer top & bottom and assign them to a switch. I take my radio with me when I go to find it, and flip the switch intermittently to see if I can hear it. Works like a charm if you know generally where the plane is. No reason you couldn't just add more of them to make it louder if you want. |
United States, UT
Joined Feb 2012
the other HK beepers I've used don't work very well. I'll give these a try. |
Nope, it's still MIA
| Thread Tools | |
| Best Camera for aerial photography? | BillH | Electric Plane Talk | 26 | Dec 11, 2010 07:14 AM |
| Aerial Photography | dstout | Parkflyers | 10 | May 13, 2002 03:15 PM |
| Best plane for aerial photography | dgtaylor | Electric Plane Talk | 18 | Oct 01, 2001 02:21 AM |
| Digital cameraes used for aerial photography | JensJakob | Electric Plane Talk | 15 | Sep 20, 2001 08:49 PM |
| Aerial photography - first attempts | leccyflyer | Electric Plane Talk | 11 | Jul 29, 2001 03:20 PM |
