Old May 12, 2008, 01:42 AM
mkeveney is offline
Find More Posts by mkeveney
Just a test glide...
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
Build Log
Crobe 2 scratch build
My Crobe 2 build is now underway.
If you've never heard of the Crobe 2, please see the general discussion thread here:
http://www.rcgroups.com/forums/showthread.php?t=848111
It will direct you to the original Crobe site, with plans, etc.
I thought I'd contribute a build log, since I've learned so much from other build logs. I'm scratch building from the plans, since I aleady had most of the material on hand.
I think it would be a good idea to keep general discussion of the Crobe2 on the original thread... but please feel free to add any questions or comments about my build in particular here.
mkeveney is offline Find More Posts by mkeveney
Old May 12, 2008, 01:43 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
I have had bad luck trying to transfer printed plans to balsa. I've tried carbon paper, a hot iron to transfer heat-sensitive copying machine toner, and acetone to dissolve the toner. None have worked for me. Things always seem to smear, transfer incompletely, or get distorted.
Instead I simply make an extra copy of the plan and cut the parts from it. (In this case the Crobe 2 designer has helpfully included a parts sheet separate from the plan.) Then I stick the paper to the balsa; cut the part out; and remove the paper.
To attach the pattern, you can use rubber cement if you like... it leaves a gummy reside that has to be rubbed off when you're done. I don't care for it particularly.
The stuff I currently use is called 3M Remount. I got it at an art store ages ago. I'm still on my first can.
You spray it on, let it dry, and then stick it to whatever you want, over and over again. It comes off without leaving any residue. I think it's the same stuff as on the yellow Post It notes.
An advantage of this approach is that you can put the part anywhere on your balsa stock you like: Align straight edges on the part with straight edges in the stock, or hold your wood up to the light to find the absolute lightest (or strongest) portion of the wood.
You can stick the patterns to a piece of waxed paper and save them for future use too.
This photo shows some patterns cut out and sprayed (sitting upside down on an overspray sheet...rather hard to see).
Old May 12, 2008, 01:45 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
These shots show the fuselage sides, doublers, and tailfeathers... the remainder of the parts are similar.
I had to arrange the grain on the doublers lengthwise (contrary to the plan) since the part wouldn't fit any other way on the stock I found.
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
I did wet and clamp the sides as described in the build instructions, but forgot to photograph that step. This shot shows the doublers glued in place, with the clamping re-established. (Right now that can of dope is just a weight, but I'll be using it for covering later )
I glued the doublers with CYA, and will probably be using CYA instead of PVA for most of the construction. (I'm patient enough to cut out my own parts, but not enough to wait for glue... go figure).
Old May 12, 2008, 01:50 AM
Sensiblenick is offline
Find More Posts by Sensiblenick
Tearing the Skies a new one...
Sensiblenick's Avatar
Sweden: Ystad
That's a lovely job you've made of those parts..
Since reading the Crobe2 thread I've been itching to see one of these go together. Now sat on the edge of my seat awaiting more pictures
Mvh,
Nick.
PS.... Sand it round!!
Sensiblenick is offline Find More Posts by Sensiblenick
Old May 12, 2008, 05:21 AM
flybaby2000 is offline
Find More Posts by flybaby2000
Closed Account
Joined Apr 2004
no one trying a glass or vac formed fuse yet..
seems possible for this size model
cheeers
doug
flybaby2000 is offline Find More Posts by flybaby2000
Old May 12, 2008, 07:58 AM
wingbeat is offline
Find More Posts by wingbeat
Gravity gets me down.
wingbeat's Avatar
United States, WI, Milwaukee
Beautiful work. I need to go get some "reading glasses" to cut parts... my near vision is shot, and those wing parts tiny!
I like that spray you found. I did the same technique, only with 3M77 sprayed in a light coat.
WTG on starting a plan build. Subscribed.
cheers,
'beat
wingbeat is offline Find More Posts by wingbeat
Old May 14, 2008, 01:42 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
Oops.. forgot to post stuff yesterday. Today's entries actually cover two days of off & on work.
I added the extra skinny doublers in the hatch area. As I mentioned before, the pattern calls for the main doublers to be arranged with vertical grain. Since I had to arrange them horizontally, it would've made more sense to combine them with the hatch doublers as a single piece of ply.
Old May 14, 2008, 01:44 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
The triangle stock is installed. I had to cut my own, since I could find no 4mm stock at the hobby shop.
Old May 14, 2008, 01:45 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
Gluing the forward bulkhead in place. The servo mount rails were cut to size and simply held in place by the clamp in this shot.
Old May 14, 2008, 01:46 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
The servo rails are now in place. It was tricky to get everything clamped in place properly for this step. Slow drying glue would've probably been smarter than cyano, but I managed to pull it off without gluing the servos in!
Old May 14, 2008, 01:48 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
Forward sheeting now installed. The plans and instructions did not specify whether the sheeting was to be arranged with grain crosswise or lengthwise. I opted for crosswise, since it's easier to bend this way, and it's the way I've seen it done on other planes.
Old May 14, 2008, 01:49 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
I tapered the triangle stock before installing the rear bulkhead. I figured it would be easier to get the knife in there before the fuse was pulled together.
Here's my trick for marking a line to taper stock when it runs around curves: use a piece of tape for your line.
You can easily reposition the tape until it eyeballs exactly straight. If you trim very gently, the tape also seems to guide your knife when you get down to the last little slivers.
Old May 14, 2008, 01:50 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
The rear bulkhead is in and the sides are now joined. They aligned perfectly, which is rare for me. Usually some kind of twist has worked its way in by now, and I have to persuade the wood to line up before gluing. This time I seem to have nailed it pretty well.
Old May 14, 2008, 01:52 AM
mkeveney is offline
mkeveney's Avatar
Oakland, CA
Joined Aug 2005
With this much complete, I started to worry about how I was going to insert the servos. It's a little tricky to insert the second servo with the arm already screwed on -- and there's no room to attach the arm once the servos are in there.
I figured out the following technique:
First get the servo arm on the splines so it's 90 degrees from the case at neutral.
Then plug everything in and move your transmitter sticks so the arm goes all the way toward the top side of the fuse. (Or just force the arm over by hand if you're not worried about stripping the gears.)
When inserting the servo you'll have to tease the arm into the slot, and might have to turn it back a little bit before you can get the servo seated properly.
By the way... I had to increase the width of my fuse by about 3mm to accommodate my 6.4 gram Blue Arrow servos.
Cool little brothers first scale scratch build 0-2 foam and tape Foamies (Scratchbuilt) 20 Apr 29, 2008 08:48 AM
Video Sky Force Scratch-Build U-2 deltaV Electric Plane Talk 2 May 09, 2007 11:13 AM
Scratch build - kit build - or ARF? hardlock Foamies (Kits) 16 Oct 12, 2001 04:05 AM
Want to scratch build a fun fly plane. Cay you recommend plans? WilliamSettle Sport Planes 4 Oct 04, 2001 11:29 PM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
