Old May 10, 2008, 07:38 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
Gallery
5 gram or 10 gram Brushless Post your Model Picture thread
I got this idea from Michael (epilot). He was commenting in another thread on how with these small motors he hasn't seen alot of models out there under 100g. I figure they're out there but scattered around in different threads, or perhaps not posted. I thought it would be fun to get everyone to show off their indoor/micro models that use these motors.
So post any pics and info on any model your using a 5g or 10g brushless UH or 2dogrc of other manufacturer.
I'll start...from the scratchbuilt thread http://www.rcgroups.com/forums/showthread.php?t=710077 There is also a 5g version for the sumo by Firetrappe that weighs in at 47g auw.
Heres my micro sumo...
I used 3mm depron, no rigging just some small depron blocks for support and a carbon spar for the wing. Tape on the wing for damage control.
1x 1811-2000 motor https://www.unitedhobbies.com/UNITED...idProduct=5358
1x gws 7035 prop
1x BA 3.6 servo (for ailerons...i was afraid 2.5's wouldnt have enuff torque)
2x Ba 2.5 servo
1x BA 6amp speed controller https://www.unitedhobbies.com/UNITED...idProduct=5531
1x BA rx small jst plug type http://www.bphobbies.com/view.asp?id...11&pid=V768578
1x Polyquest 300mah
+ various control horns, .032 metal control rod, ezconnectors and a 1/16" carbon spar. Motor mount's a small disk from a cd blank epoxied into the cavity.
Auw is about 98 grams or 3.45 oz. Its now heavier with all the repairs!
Thank you firetrappe for this great thread...i have been looking for something in this size range for the driveway and backyard. The control response is amazing. I can get flat 2' turns and 2' loops if i want to.
Here is the Vid on 3 cells, on a 5030 prop. I now use the 6030 prop for both 2 cell and 3 cells.
Bill
poulsbobill is offline Find More Posts by poulsbobill
Old May 10, 2008, 10:51 PM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
Here is my Mega Spoil Sport designed by Gary Jones ( soon to be released from BSD ) great flier!
5 gram Hobby City motor
Feigao ESC
Power 3.7 gram servos
Corona RS 410 receiver
Full River 220 2cell
AUW 64 grams
Jerry Combs is offline Find More Posts by Jerry Combs
Old May 10, 2008, 11:11 PM
lukibob is offline
Find More Posts by lukibob
Fractal Integrator
lukibob's Avatar
United States, KY, Edgewood
Joined Aug 2006
5g motor
Here is my DR1. It is my current daily flyer. Still working out the bugs, hence the patches. There are many more now
Here is a short thread on it http://www.rcgroups.com/forums/showthread.php?t=797604
5g HC motor
turnigy 6a esc
3 HC 3.7g servo
GWS 6ch receiver (all I had laying around)
current battery is 200mah 2s hxt
AUW 70.55g
lukibob is offline Find More Posts by lukibob
Old May 11, 2008, 12:14 AM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
If I may copy lukibobs format:
60cm wingspan
10g HC motor
turnigy 6a esc
3 HC 3.7g servo
Corona Synthetized receiver
Battery either 200 or 250mAh
AUW about 85g
Thread over the Waterplanes forum here
I have a 5g motor waiting for a plane, maybe Ill do one for my girlfriend, shes been asking for it for some time already.
AleG is offline Find More Posts by AleG
Old May 11, 2008, 12:40 AM
termite is offline
Find More Posts by termite
Utica Il.
Joined Dec 2002
That's a beauty!
Randy
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old May 11, 2008, 10:33 AM
printer2 is offline
Find More Posts by printer2
Where did I put that ...
Winnipeg
Joined May 2007
F22 park jet
WS - 16"
Length - 23"
Motor - UH 10g 2000kv motor
Battery - 500mah 2S
speed controller - 6amp
Servo - UH 5g
AUW 100g
Prop - 6x3
Made this one out of stripped foam core board and some epp from packaging material. It seems like a nice combination but I was feeling very anxious after a long winter and took it out in 20kph gusty winds.
One gust caught it and directed it nose downward into the ground. The damage was caused by the airframe flexing and the prop taking a chunk out of the foam board. The epp did it's job and bounced back. Some hot glue should do the trick.
printer2 is offline Find More Posts by printer2
Old May 11, 2008, 12:49 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Heres a couple of mine.
The Lazertoyz Mini Arrow has a UH 10g 2000Kv and the Fik 60 has one of epilots 10g motors.
dekan is offline Find More Posts by dekan
Old May 11, 2008, 12:55 PM
termite is offline
Utica Il.
Joined Dec 2002
Do you think the 5gr would work with the FIK 40?
Your thoughts please?
Randy
Old May 11, 2008, 01:36 PM
Michael in Toronto is offline
Find More Posts by Michael in Toronto
E-flyer since 1981
Michael in Toronto's Avatar
Joined Oct 2000
Approx. 95 grams
Sig Hacker Piper Cub
E-Flite 180 brushless.
Flies great!
Michael in Toronto is offline Find More Posts by Michael in Toronto
Old May 11, 2008, 07:07 PM
phil stevo is offline
Find More Posts by phil stevo
phil stevo's Avatar
Sydney
Joined May 2004
In the interest of keeping like with like I copied these from my post on 5g motor thread:
My ULT with 5g BL weighs 60g and is 300 (PNut size), BA 3.6g servos on A and E, Pent 6 ESC, all 2mm depron from Micro Ult plans on another thread.
Brown Lit Gem has been posted previosly, same weight and gear but 375mm span.
The 4ch profile model is 17 in span and weighed 65 g with similar gear, but has now been converted to the 10g motor for zippy 3D capable performance and weighs 75g.
phil stevo is offline Find More Posts by phil stevo
Old May 12, 2008, 06:12 AM
igi is offline
igi
Find More Posts by igi
igi
Easy Glider
Hildesheim, Germany
Joined Nov 2002
Micro Silence made from wallfoam
Wingspan: 39cm
AUW: 46g
Motor: 5g UH
Prop: GWS 5030[IMG]
ESC: 6g UH lightened to 4g
Bat: 135/180 mAh UH
RC: Falcon Rx, 4 Falcon Servos
igi is offline Find More Posts by igi
Old May 12, 2008, 06:38 AM
Peter Mack is offline
Find More Posts by Peter Mack
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
My humble offering is a delta powered by the 5 gm UH motor that has given me good service. My learning progress in RC has been from indoor micro to outdoor parkflyer size models (the reverse I suppose of most modellers) and this is the first that I have ever managed to loop! Span is 40 cm, Length 34 cm, weight about 70 grams. Wing is 3 mm Depron, flat surface. The nose has a plate of 1/64" ply underneath and a plug made of EPP foam. Both have helped with my many less-than-perfect arrivals. Battery is a 2s 135 mah or 180 mah cells and the usual 6 gm ESC. The 5 gram motors are great, as long as you treat them carefully. I managed to mangle one by pulling out the wiring. My friend and I are dreaming of building Twinkle-type flying boats based using the motor.
Peter
ps Nice models as usual Phil. I was tempted to make a Depron version of your P-Nuts. I still have the plan you sent to me in 1991!
Peter Mack is offline Find More Posts by Peter Mack
Old May 12, 2008, 05:38 PM
Poulsbo, Wa
Joined Sep 2004
Wingspan: 39cm
AUW: 46g
Motor: 5g UH
Prop: GWS 5030[IMG]
Bat: 135/180 mAh UH
igi,
How did you lighten that esc?
Bill
Old May 13, 2008, 07:26 AM
igi is offline
igi
igi
Easy Glider
Hildesheim, Germany
Joined Nov 2002
igi,
Bil
I removed the heatshrink and the motor wires (soldered the motor directly to the ESC) excanged the battery wires for thinner ones and the rx cable and plug for a much tinier Falcon one.
igi
Old May 13, 2008, 07:28 AM
Tim Cullip is offline
Find More Posts by Tim Cullip
Tim Cullip's Avatar
USA, NC, Apex
Joined Aug 2003
Remove the shrink wrap and replace the wires with lighter versions. I got mine down to about 3.3g.
Tim
Originally Posted by poulsbobill
igi,
Bill
Tim Cullip is offline Find More Posts by Tim Cullip
Cool Please post your spitfire picture. mike7130 Scale Kit/Scratch Built 49 May 17, 2015 01:44 AM
Cool Please post your Spitfire picture. mike7130 Fuel Warbirds 12 Apr 07, 2005 11:00 PM
Cool Please post your spitfire picture. mike7130 Parkflyers 0 Dec 23, 2004 09:07 AM
