View Poll Results: Please help name this glider
Hellferstout 5 26.32%
Numeric 9 47.37%
Knaughty 5 26.32%
Voters: 19. You may not vote on this poll
Old Feb 18, 2013, 09:10 PM
granada don is offline
Find More Posts by granada don
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
Looking good there Wayne, what color are you going to cover the sheeting with?
The poly wing sure gives a different look to the Raven.
G Don
granada don is offline Find More Posts by granada don
Old Feb 18, 2013, 09:34 PM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Originally Posted by granada don View Post
looking good there wayne, what color are you going to cover the sheeting with?
The poly wing sure gives a different look to the raven.
G don
+1000
seanpcola is offline Find More Posts by seanpcola
Old Feb 19, 2013, 09:05 AM
scaflock is offline
Find More Posts by scaflock
I need some building time in t
scaflock's Avatar
United States, AZ, Douglas
Joined Nov 2007
Sean.... Check your PMs.
scaflock is offline Find More Posts by scaflock
Old Feb 19, 2013, 09:28 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Jeff,
Sorry my inbox rejected your last PM. Try again, I cleaned out some folders so there is room now.
Still waiting for the local news to air the segment they filmed at work so that I can link the video on here but.............
Gonna take some pics of a guest that is going to drop in at work on Thursday. I'll post the pics if I'm allowed to take them and then I want to see if any of the old rockers on here can identify him. Jeff: If you don't guess right I'll lose all respect for you.
Old Feb 20, 2013, 11:04 AM
hog2soar is online now
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Hey Everyone,I haven't been on here in a while. It looks like I've missed out on some things.
First I want to say to Katie a belated very sorry about your loss. I just found out when I was looking back at all the things I missed. I met both you and Dory last year at our Fall Festival in Visalia.
I'll have to check in more often. This is one of the best Threads on RCG.
Steve,you really started something. I think you should get an award for having the largest thread with the most BS on RCG It's really fun to go back and read some of the stuff on here.
Well,I've been doing what this Thread says. "I'm getting a woodie-woodie builds". I just finished building a Mirage,that I call Mirlusion. Because I changed everything on it. I built a custom fuselage,lengthened it skinnied it and fiberglassed it. I built custom tail feathers and the biggest change I made to it was the wing. The stock version calls for a 3 piece wing. But I don't like the looks of a 3 piece wing and I'm always changing the things I build. So I made it a 5 piece wing,based on the Bubble Dancer specs with Darth wing tip Guru tips. Oh yeah,for you purist,I stuck a spinny thing on it's nose AUW 46 ounces ready to fly.
I took it out for it's maiden but didn't get very far because I broke one of the wing joiners when I was test throwing it. Bad JU JU! Hopefully I can maiden it next week. At least it looks good before I fly it
I'm also building a balsa build up 60" DLG called "Manta". Of course I had to bastardize it also. I wanted something fun to build and to play with so instead of building it with Ailerons (flapperons) I deceided to make it a poly wing RE DLG. I bought a pod and boom for it and I've built the wing. In it's bare bone frame it's auw is 8.5 ounces. That's the fuse two servos skeleton wing and tail feathers. All I have to add is the battery,rx, and covering. It should be fun to play with.
Here's a couple pictures to show there really is some building going on here also.
Take care everyone.
Eddie ( aka Hog)
hog2soar is online now Find More Posts by hog2soar
Old Feb 20, 2013, 12:40 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Looks awesome Eddie! I really, REALLY like the looks of that thing!
Old Feb 20, 2013, 02:06 PM
scaflock is offline
scaflock's Avatar
Joined Nov 2007
I agree Eddie. Looks great! (Just about like my Paragon only smaller.) I have always liked that color combo and to me it shows up great against the sky even when getting close to specked out.
Sean... As per our conversation earlier today I've been reworking the wing control surfaces on the ASP. Spoilers will still be solid wood but the flaps and ailerons are now built up and strengthened with Carbon. Due to the length of the surfaces I'm going to go with five hinges in each one. I laid out all the wing drawings on the floor and OMG this thing is going to be a MONSTER!!! I may have to do it in shades of greens and rename it the GODZILLA!!! If you can't see this thing at 2,500' AGL then you're surely blind as a bat!
Old Feb 20, 2013, 07:47 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
If you get the plans finalized and I'm not put on a deadline () I'll build a prototype too but (with your permission) I have some other ideas that won't gel with your concept for the actual kit.
Spoilers: I would use those new servo-less spoilers that just drop in the wing and plug in (Added cost but I think well worth it)
Dual Tow release. Explanation : Aerotow release in nose and releasable winch towhook both running off the same servo. Reason: I want to experiment with higher winch launches done the old school way with no regards to "contest rules". Tony uses releasable tow hooks on some of his SailAires and he can strip the last inch of line off a full drum before release by kiting it. As you know I don't give a rat's patooti about contest flying but kiting is a blast and you can get a glider waayyy up before release.
(Maybe) Landing wheel
One concept I've been thinking about on a larger D-tube wing is to glass the D-tube sheeting to stiffen it up but use really light covering on the open structures. I want to play with that idea.
Old Feb 20, 2013, 07:50 PM
Lil Stinkpot is offline
Find More Posts by Lil Stinkpot
Egads! It's a GIRL!
Lil Stinkpot's Avatar
United States, CA, San Jose
Joined Jul 2011
Hiya, Eddie!
Yeah, it's been one hellova roller coaster ride. And it's only just begun.
I have a short kit for a manta. I really got to get on it, once the dust settles. Tell us how the poly wing turns out!
Lil Stinkpot is offline Find More Posts by Lil Stinkpot
Old Feb 20, 2013, 08:27 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
G Don
G Don, I have gone round and round with wing covering options. I actually had one of the wings partially covered and did not like how it was looking so I stripped it and started over. I made a small 3 view plan for the Raven so I printed a bunch of those off and went and found a box of crayons and I made a bunch of color sketches I am considering. I taped some covering to the wing last night to see if my latest idea will work. I think it has promise but I have not committed yet.
Eddie, both Katie and I have Manta short kits waiting in the wings. Anything in that build you care to share with us? Was it straight forward or was there something that gave you pause? I must say you did a great job on that Manta fuselage, it looks just like carbon and kevlar. Ultracote is getting better and better at looking like the real thing. The Mirlusion looks fantastic.
Wayne
Windependence is offline Find More Posts by Windependence
Old Feb 20, 2013, 08:48 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Wayne
Wayne and Katie,I built the Manta wing also from the short kit. No problems what so ever. Well I take that back. When I printed the plans they didn't come out to scale. So I just hand drew over the printed plans and made them to scale.
I just like changing things and I didn't want to mess with flapperons so that's why I built a poly wing out of it. I don't know how it's going to fly,but it's not going to be used for any contest flying. Just something to throw around.
Katie,hang in there. God will guide you.
Eddie
Old Feb 20, 2013, 10:10 PM
Captain Canardly is offline
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
What a build season! I was snuggled up with my favorite game, listening to roof pop crack and rumble in 35-45 mph gusts with-5 degrees. came up with this. now I need to finish'er up!
Captain Canardly is offline Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Feb 20, 2013, 10:57 PM
alstrahm is online now
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
Joined Oct 2002
servo-less spoilers
Sean, do tell more!
Al
alstrahm is online now Find More Posts by alstrahm
Old Feb 20, 2013, 11:05 PM
Hossfly72 is offline
Find More Posts by Hossfly72
Thermal Naked!
Hossfly72's Avatar
United States, AL, Mobile
Joined Dec 2007
Cap! You better put a wing and tail on the other side or you're just gonna fly in circles!
Hossfly72 is offline Find More Posts by Hossfly72
Old Feb 20, 2013, 11:52 PM
Joined Jan 2007
I don't wanna! I'm a Nascar nut!
HELP ME!!!< I think I'm getting addicted to cutting foam!!! slowflyer Foamies (Kits) 7 Feb 21, 2011 12:58 PM
I'm Getting my FiXX Craig558 Foamies (Kits) 6 Mar 18, 2002 10:40 PM
looks like i'm getting a piccolo, any advice? cheapflyr Electric Heli Talk 13 May 10, 2001 08:34 AM
I'm getting worried SchiessCo Electric Plane Talk 1 Apr 21, 2001 08:11 AM
