Don,
I would not use microballoons. Microballoons actually weaken epoxy, as we learned the hard way back in the '70s. Cabosil, cotton flox, or milled glass would be a much better choice. I usually mix enough in to make it the consistency of tooth paste, unless I need it to flow some. In that case I make it thinner. Microballoons are good for fillets or filling wood grain or weave in fiberglass. Your choice, your model, but them's the facts... I was in New Orleans the week after Katrina, getting the railroad running again... and I have nothing good to say about it, so I'll say nothing at all... ...Jack |
Latest blog entry: The BEST!
Steve's correct if you don't put too much in, it's OK. If you really load it up, it is weakened. I believe Dr. Drela commented on this some time ago...
I just potted my 17/32 tubes into my wing roots for my Hawk build. I used a bit of milled glass and some Cabosil, but it has to flow some so I heated it as it went in... It went off a little faster than what it's supposed to... which just meant I didn't have to wait as long to do the other side... not a bad thing. I am going out to bend my joiner. Left to do are: Fit wings and joiner to fuselage; Fit stab; Fit rudder; Make servo tray; Fit and rig spoilers; Cover; Install push rods; Balance; Fly... All the parts are made... If I was going to be home this week, I'd finish her... Alas, duty calls... Jack |
United States, IN, Fort Wayne
Joined Apr 2003
epoxy and brass tubes.
Way back in the seventies and early eighties, I participated in F3B Team Trials and made it thru to the finals three times. Imagine doing this with woody sailplanes back then, before carbon, we were all learning with each wing failure as we turned Base B in the Speed runs, what worked and what didn't work.
Lesson # 20040092 : brass tubes surrounded by any 30 minute and up cure time epoxy, mixed or not mixed ( reasonably ) with Mirco Balloons, placed between the spars with 1/16 plywood horizontal shear webs on both sides of the brass tube and attached to the sides of the spars do not break when the wing rod is inside the brass tubes and the plane is negotiating the speed turn a Base B. ( RCC Group's longest run on sentence ). Because,the weakest bending ( break ) point is located at the ends of the brass tubes. So once we figured that out, it became all about the size and strength of the wing rod. And then we discovered the use of carbon. Ray Sky Bench http://www.skybench.com |
Joined Apr 2003
are you saying a 6 inch wing joiner ??? Ray Sky Bench http://www.skybench.com |
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
