View Poll Results: Please help name this glider
Hellferstout 5 26.32%
Numeric 9 47.37%
Knaughty 5 26.32%
Voters: 19. You may not vote on this poll
Old Nov 04, 2012, 12:33 PM
scaflock is offline
Find More Posts by scaflock
I need some building time in t
scaflock's Avatar
United States, AZ, Douglas
Joined Nov 2007
No Problemo Jeff. We all need to vent form time to time. Seems that it wasn't a good night for Jeffs in general. I tripped on some stuff last night and wiped out too. No major damage except to my pride. It was close though. If I hadn't been able to catch myself using the table I"d have done some major damage to my ham string. It was sore but felt a lot better when I got up this morning.
On another note... This is strange to see all the reminders about the time change. Snce I"m now in Az we don't have to do it. Kind of weird feeling in a way.
scaflock is offline Find More Posts by scaflock
Old Nov 04, 2012, 12:40 PM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Yeah GDon, that would have been great to have those guys around.
On the laser cut/burned edge thing. It's best to lightly sand that burned edges before gluing anyway. The laser cutter sort of cauterizes the wood in those areas and glue often won't penetrate like it should.
Jeff the ...younger? (Did we establish that yet?)
It's all part of getting older. I hate it when you wake up sore in the morning. I'm talking about "car wreck" sore for no apparent reason. I do that a lot.
I hate programming a tx. I know I can learn it and do it, I just have some kind of aversion to sitting down and learning it. That's why I had my computer bh Randy around. I'd just have him get everything mixed and operating then fine tune it to what I want. He set up 3 or 4 different layouts and I just copy to a new model and tweak.
As for a new model I set everything to TLAR, then set dual rates for about 1/2-3/4 of those throws. Throw it a few times to make sure the elevator is close to neutral then launch. Once you get up high feel everything out. Do that a few times and once I have it set then I dump the low setting so I don't accidentally change something in the air and not realize what's going on. But, that's just me. Once I get everything where it feels good I don't change rates.
seanpcola is offline Find More Posts by seanpcola
Old Nov 04, 2012, 05:06 PM
Lil Stinkpot is offline
Find More Posts by Lil Stinkpot
Egads! It's a GIRL!
Lil Stinkpot's Avatar
United States, CA, San Jose
Joined Jul 2011
Not a woodie, but....
I asked in the "Sorry Error" thread, but I'm asking here, too. See, my Radian went in slightly out of radio control, and the prop was running even though the throttle was off that's not the issue. I fixed that (needed re-binding).
The problem is the nut that the prop is screwed onto. The set screw made itself a new groove, and now the nut spins freely. Adding insult to injury is that the nut is trapped on the motor shaft somehow, probably by the turnings made by the set screw. Arrrrrgh!
Here's the real question: can I change the motor shaft? How the $&#% do I get the nut off, if it's even worth the effort. Does it matter that the motor smells of ozone? (a sign of fried circuitry, but maybe nothing to a motor, I don't know)
In a nutshell? Now what do I do?
STUCK:
Lil Stinkpot is offline Find More Posts by Lil Stinkpot
Old Nov 04, 2012, 05:53 PM
Captain Canardly is offline
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
That's an everyday thing in our shop Katie! can you get a (largest possible) pliers onto the shaft behind the screw? Maybe whittle out some clearance on the plastic, leave at least 1/2 diameter of plastic surrounding the screw's countersinks, and you'll have enough structure for the mounts.
Pry in 90 degree segments- 'walking' around the shaft until freedom is cried.
file the prop shaft, and deburr the Id of the screw- that would be either a 3 mm- .120/ or 2 mm- .07875( Iknow that one) drill being used to deburr the spot causing troubles. remount and have @ it!
Johnny
Captain Canardly is offline Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Nov 04, 2012, 05:59 PM
gdjsky01 is offline
Find More Posts by gdjsky01
Jeff
USA, CA, Redondo Beach
Joined Aug 2003
Battery replacement
Referencing the photo below. Any idea where I can get a pack like that? I think they are 1250mah 4/5 sub C. Lots of people sell those. But the configuration is not common. Vendors? Custom pack? Can't make one. My soldering skills are awful!!
gdjsky01 is offline Find More Posts by gdjsky01
Old Nov 04, 2012, 06:04 PM
Don Stackhouse is offline
Find More Posts by Don Stackhouse
Don Stackhouse's Avatar
United States, OH, Bradford
Joined Jun 2005
Try Radical RC:
www.radicalrc.com
Don Stackhouse is offline Find More Posts by Don Stackhouse
Old Nov 04, 2012, 06:11 PM
Egads! It's a GIRL!
Joined Jul 2011
But cap'n! The nut is nae jammed on the shaft, it is trrrapped on it, spinnin' freely, but nary to come off.
When the screw was forced around the shaft, it acted like a lathe, and cut a ring all the way around the shaft. That much I can see. I presume that the screw acted like a dull lathe tool, and pushed the shaft material around instead of cutting it, making a raised doughnut that prevents the adaptor from being removed. I can't get any leverage on the ring, and the adaptor spims easily around. I can't even get it to jam to start to pry it off. :angryface:
Old Nov 04, 2012, 06:38 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
You can't back off the set screw, correct?
If you're not worried about ruining the prop nut use a Dremel and cutoff wheel. Slice down through the nut and into the center of the set screw deep enough to get a straight slot onto the set screw, then use a screwdriver narrow enough to do the job. I'm guessing you only need to back the screw off a tiny bit to clear the groove.
Or, drill the set screw and use the appropriate size Easy Out. Probably less likely to succeed this way though. I imagine that set crew is hardened.
Don't know about replacing the motor shaft. I know it's easily done o some motors but not familiar with what you have.
Old Nov 04, 2012, 06:41 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Change to Lithium? If not order through Radical RC as Don S suggested. If you have a Batteries Plus or Battery Source locally they can build one but...............if they don't have REAL, clearly labelled Sanyo cells keep walking.
Old Nov 04, 2012, 07:03 PM
Egads! It's a GIRL!
Joined Jul 2011
The set screw has been removed. It is out, and the adaptor is still stuck.
Here is a quick and dirty diagram of what I see. The to picture is a normal shaft, with a little mark where the set screw sits. The second is what I can see through the set screw hole. I did not draw in the supposed raised "capture" ring, but I'm sure something is there.
Old Nov 04, 2012, 07:10 PM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Nov 04, 2012, 07:40 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Kennedy composites has them, http://www.kennedycomposites.com/batteries.htm
Windependence is offline Find More Posts by Windependence
Old Nov 04, 2012, 07:45 PM
ronrange is offline
Find More Posts by ronrange
Joined Jan 2003
Nut removal
Have you tried or thought of a small wheel/bearing puller?
ronrange is offline Find More Posts by ronrange
Old Nov 04, 2012, 07:52 PM
Egads! It's a GIRL!
Joined Jul 2011
I never knew they existed. I can't say that I have a full-scale (car) bearing puller that will work.
I can say that jamming the pliers between teh white housing and the adapter and using the housing as a fulcrum did not budge the adapter.
Old Nov 04, 2012, 08:04 PM
Joined Jan 2007
What a bummer- kick back with dexter, he always has answers!
http://www.hobby-lobby.com/puller_fo...s_782_prd1.htm
HELP ME!!!< I think I'm getting addicted to cutting foam!!! slowflyer Foamies (Kits) 7 Feb 21, 2011 12:58 PM
I'm Getting my FiXX Craig558 Foamies (Kits) 6 Mar 18, 2002 10:40 PM
looks like i'm getting a piccolo, any advice? cheapflyr Electric Heli Talk 13 May 10, 2001 08:34 AM
I'm getting worried SchiessCo Electric Plane Talk 1 Apr 21, 2001 08:11 AM
