Gloves!! Get some cheap disposeable nitrile gloves, the blue ones. Try never to get epoxy on your skin:eek Dave |
Katie! @ the last MoM contest ( vid earlier) one of the fellas had 'the doc's'( Drella) ultralight carbonized 2 meter- I'm brainlocking for the name now, but he was going uphill wide open, and zoomed a bit, but I was not impressed. The benefit that musty day was the birds were not worried about the crosswind as my canard was. Your much better off with good towhook position and learning to 'Kite' the bird on launch.
Familiarity with a particular airplane helps too. In my opinion my skill level was at the top of it's game back in the late 80's and early 90's when I was flying a lot every weekend and pretty much only flying one sailplane. I knew what it would do in every condition and situation. Congrats on the new job! |
Secondly, particularly if the plane has flaps, an all-flying tail often needs to be about 20% or so larger than an equivalent stabilizer+elevator. The key is whether the size of the tail is determined by stability concerns or by elevator authority requirements. If you have flaps for landing, it's likely to be elevator authority, to overcome the high aerodynamic pitching moments of the large flaps. When you deflect an all-flying stabilator, you only change its angle of attack. When you deflect an elevator, you change the angle of attack of the tail, but also the camber, so you don't need as much tail area to make the same amount of tail lift. |
Don, thanks. I understand.
It's kinda like making an upside down wing with a regular stab/elevator setup, where I can't do that with a stabilator. David: I am usually really uptight about gloves. I ran out and stubbornly went forward, thinking that I can keep my fingers out. Well, not entirely, apparently. Anyways, I'll be getting a box the next time I'm out. I'm not going to try to full-pedal the BoT. It sounds like it won't make it, and considering what covering I'll be using, I won't risk it. I'll keep am eye out for a good, cheap, used mouldie. |
Unless you have a different, high-speed airfoil, most "gasbags" don't zoom well. The idea behind a zoom is to use line tension to build massive amounts of excess airspeed at the top of the launch, then convert that to extra altitude after you come off the line. To do that, the plane needs to retain energy well, which means having low drag at low lift coefficients. The thick, highly cambered airfoils on the older designs tend to get a lot of separation on the underside at moderate and low lift, which kills the extra airspeed pretty quickly, and limits the altitude gain in the zoom. This is aso why these designs typically do not penetrate well.
Katie, I've found some of the better deals on surgical gloves at WalMart in the health section, typically in diabetic supplies. Sam's Club can also have good deals. Make sure to get nitrile, urethane or vinyl gloves, NOT latex. Latex provides almost zero protection against the chemicals we typically work with, especially laminating epoxies.
Some of our chemicals also attack vinyl. Nitrile usually does better. If you are working with really nasty stuff like that, wearing two layers of gloves is usually a good idea. |
I will not shop at Walmart. They treat their employees and customers like trash. (and our local WM STINKS)
There is a tool supply place we like, and they carry a brand of gloves that actually fit. That's where we're going. ![]() I know about epoxy vs latex. I know epoxy is bad. I was just being stupid stubborn last night. Admit it, we all have our moments. |
USA, CA, Redondo Beach
Joined Aug 2003
Now where wuz we?
More later. I am off to Walmart (well Sam's Club) to get more kitty litter. Six cats create a lot of ![]() ![]() |
United States, MA, Waltham
Joined Dec 2001
Isn't the BOT airfoil a bit thinner and faster than most? It's not completely flat bottomed, either.
I have seen Mark launch the Allegro Lite, and if done right it is quite impressive. Particularly because watching it is like listening to an LP on 78rpm. The AL flies very well, too. |
Latest blog entry: pics from Winthrop, MA indoor flying...
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
