View Poll Results: Please help name this glider
Hellferstout 5 26.32%
Numeric 9 47.37%
Knaughty 5 26.32%
Voters: 19. You may not vote on this poll
Old Jul 03, 2012, 05:03 PM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Originally Posted by highflier View Post
Typically the ailerons are Down and Up deflection.
Flaps are Neutral to Down deflection.
Now depending on how you attach things you will want a different tapper.
I.E. if you use X method (I use this alot of spot planes you need to tapper both top and botton of the aileron leading edge
If you use tape along the top edge you only tapper the button edge on the ailerons.
I often do the same thing on the flaps. but it could be done reverse
Highflier
This ^^^^^^^
I forgot to mention how the tapers should be oriented.
seanpcola is offline Find More Posts by seanpcola
Old Jul 03, 2012, 05:12 PM
Lil Stinkpot is offline
Find More Posts by Lil Stinkpot
Egads! It's a GIRL!
Lil Stinkpot's Avatar
United States, CA, San Jose
Joined Jul 2011
Much, much, much too late now. It is how it is, and I can't/ain't gonna fix it. Just call it a special feature. I'll post a picture later. It should fly fine.
Lil Stinkpot is offline Find More Posts by Lil Stinkpot
Old Jul 03, 2012, 08:49 PM
Lacquerhead is offline
Find More Posts by Lacquerhead
Wood Chucker
Lacquerhead's Avatar
USA, TX, Allen
Joined Nov 2009
Originally Posted by schrederman View Post
House and 7 acres in Amarillo is on the market! I'll be working in Ft. Worth on the 16th... We're both praying that we will never have to move again...
Well then, welcome to the Metroplex!!!
Lacquerhead is offline Find More Posts by Lacquerhead
Old Jul 03, 2012, 08:53 PM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
All the best with the maiden Katie, pics please if you dare!
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Jul 04, 2012, 05:17 PM
granada don is offline
Find More Posts by granada don
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
To Steve and all the thread troops
Have a neat fourth of July.
G Don
granada don is offline Find More Posts by granada don
Old Jul 04, 2012, 05:44 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
And a Happy Fourth from Florida to all!
I did something totally different for me today.............not one darn thing! I read, listened to music and took a nap! First daytime sleep I've had literally in years with the exception of the time I got the flu.
We're having our shindig on Saturday.
Old Jul 04, 2012, 06:03 PM
robh is offline
Find More Posts by robh
Good, fast or cheap, pick two
robh's Avatar
Napa, California
Joined Jul 2006
Oly II build problem - any advice?
Hi all,
I'm just starting to build an OLY II SX, and have decided to start on the fuse. I'm at the part of the build where I'm to fasten the front ply/balsa section, to the rear balsa fuse section, and the instructions say to make sure to align the bottom edges of both pieces along a straight edge, as doing so ensures accurate setting of the decalage at the rear. So here's the problem I have...one of the rear balsa pieces is very "tweaked", and the bottom of it is anything but flat to align to the ruler. It almost looks like it moved when the laser was cutting it. The slight twist the other direction is easy to fix and will straighten out when assembling to the base and installing the top sheeting, but the upward twist in the fuse is more challenging, as I can't force it into position.
I guess that my options are:
1. sand a true straight edge on the bottom of the curved piece, removing the curve, then re-assemble along a straight edge as the instructions say - that will then cause a misalignment in the left and right top fuse edges of the surface where you mount the h-stab (not good).
2. glue the one side that is straight together, then using it as a template lay the pieces for the other side on top of them, ensuring alignment of the top edges, letting the bottom "wander" as it wants to. (ugly, but accurate where it needs to be?)
3. Call Ray and ask him to send out a couple of replacement pieces. I hate to do this, but it may be the best option?
I know that part of the beauty of working with wood is that one can get creative with the build, and I could probably wing this, however as these fuse pieces determine the accuracy of the rest of the tail build I want to get them right. It's a pretty important step not to do wrong.
I've attached a few pics that will hopefully help to explain a little further. Any and all suggestions are greatly appreciated, in advance!
Thanks very much, and Happy 4th of July to all!
Rob
robh is offline Find More Posts by robh
Old Jul 04, 2012, 06:13 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
If it was me I would pin the two halves together, correct the "bad side" H stab saddle to match the correct good side and then sand the good side's bottom to match. You should only end up with a slight upward taper on the bottom and that wouldn't even be noticed.
Old Jul 04, 2012, 06:17 PM
robh is offline
robh's Avatar
Napa, California
Joined Jul 2006
Hey Sean, that's a really logical approach that I hadn't thought of and it would work easily. An added benefit would be a (slightly) lighter tail too, which is always a good thing. Excellent, thanks!
Old Jul 04, 2012, 06:31 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
I'm your go-to guy on screwed up stuff. I've sure had to fix plenty of my own.
Only critical thing is for
A: Both sides to match exactly
B: Relationship of wing saddle to H stab saddle. Just use the know correct side as a guide. (Incidence angle)
The bottom is not as critical as the top.
Old Jul 04, 2012, 07:38 PM
robh is offline
robh's Avatar
Napa, California
Joined Jul 2006
Thanks again Sean, and I've learned a few things along the way on how to "fix" things - mostly that I've screwed up, and I'll add this technique to the quiver! Should be easy enough to do too, which is always a good thing
Cheers,
Rob
Old Jul 04, 2012, 07:47 PM
Egads! It's a GIRL!
Joined Jul 2011
Rickenfrackingdagnabbitsteenkin video editor....
Old Jul 04, 2012, 09:06 PM
Egads! It's a GIRL!
Joined Jul 2011
It flies!
Today I maidened the Spirit E. Wow! The first, first launch was piloted by me, but I had to have someone take if really soon after I got off the hook. I need more aileron practice!
Bruce was an angel, and helped me set up some flight modes, trimmed the plane (didn't need much *smug*), and flew it a few times so that I could get some videos. He says that it's really obedient, no stalling issues, penetrates well, and flies straight. A good plane! It is a little on the heavy side at 33 ounces, but that's not terrible. It's a good sloper, just what the frame was built for (I got it as a nearly finished kit plane). Heck, it didn't even have a tow hook until I put one in last night.
I uploaded a short video. I labelled it as the "first" flight, but really it's the second (shhh!). The first one I flew, as I should, but then it got away from me.
Tie Dye Spirit Elite Maiden Flight (1 min 25 sec)
I am working on a longer composite video, but it's my first time editing, and it'll be a while before I finish. You'll like it!
Old Jul 04, 2012, 10:00 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
That thing looks awesome Katie!!!!!!
Old Jul 04, 2012, 11:49 PM
harborflyer is online now
Find More Posts by harborflyer
harborflyer's Avatar
United States, CA, Santa Ana
Joined Jul 2010
Katie,
33 oz is OK. I won 1st place WOODY at the RES CHALLENGE I.S.S. in riverside with a 3m Gnome that was about the heaviest model on the field. The 2m Elite needs a little weight to make that airfoil work.
ross
harborflyer is online now Find More Posts by harborflyer
HELP ME!!!< I think I'm getting addicted to cutting foam!!! slowflyer Foamies (Kits) 7 Feb 21, 2011 12:58 PM
I'm Getting my FiXX Craig558 Foamies (Kits) 6 Mar 18, 2002 10:40 PM
looks like i'm getting a piccolo, any advice? cheapflyr Electric Heli Talk 13 May 10, 2001 08:34 AM
I'm getting worried SchiessCo Electric Plane Talk 1 Apr 21, 2001 08:11 AM
