Hey Owl,
Yeah, I know the energy/transportation issue has it's effect. I did think that Lonestar was a much bigger player than is the case as far as statewide prices go. I was thinking locally, not globally. As for the turbine blades I'm surprised to hear that. I would have thought those would be built with honeycomb cores or such. I was able to date this Paramount build a little closer just now. I opened up the wing roots and found some Kraft Radio style connectors.
Hi Sean
When i joined the club in 80' a lot of the flyers were using Kraft stuff so i bought a 3 ch single stick for my Paragon and was a neat radio with a small plastic case , very light also. Then a few yrs later they just were gone so about 85' i bought a Futaba set up, now i just got a HiTec laser 6 ch for my new Wood E Roadster. Have you tried Specialized Balsa in Col. i'am going to get an order in on monday for the new plane plus they have round balsa dowel's that i can use in my new build to help hold the sticks & stab together at the tail end. Did you find the thread on the fin - stab mod as that looks pretty good for making it bullit proof back there. With the short run of the Paramount kits i think most of them were sold and built in the late 70's as the two i was telling you about were built before i joined the glider club in 80' Don |
Hey Don,
No, I didn't find the thread showing the Paramount stab mod. Can you post a link or such? I am really interested to see what was done. Haven't tried Specialized Balsa yet but I'll check them out. Before I go ordering wood I have to decide what I need. In other words I have GOT to focus and make a list of which sailplane kits I want to get done and in what order. This Paramount sort of popped up and since it's so far along anyway I figured that I would get it out next. After that I have two Oly III kits on the shelf that I would like to get done as I've already built one, love the design but have yet to actually FLY one. I'll need a good bit of wood for one of the Oly III kits as I acquired it missing strip and sheet stock.Ah well, so many cool woodies out there and so little time.
.Quote:
Don,
I think the aluminum bushing thing will work, I've done it plenty of times but the trick is these things don't need to sit for ages without even being actuated. I'm guessing the Paramount was built around 30 years ago due to those Kraft plugs. If it sat on a shelf, or in an attic most of that time galling is to be expected. When I do the final assembly on this one I'll use something like Never-Seize applied with a toothpick. |
Why a Drifter II you ask? Well, it's fun just for the nostalgia. And it's a woodie. And, although I generally feel bigger is better, unlike what some of my fellow woodie lovers have expressed here, I'm not obsessed with the size of my wood!
![]() LOL...
Latest blog entry: The BEST!
Try PENETROL...for long term metal protection.
Seanpcola, I have 1/2 in. wingrods in several gliders, the others have tempered steel. Living on the coast of Texas with 90% humidity, I had to find something to protect all the different metal I had. Like lawn tractor decks, galvanized boat trailers, and the wing rods...to name a few.
Penetrol is a clear metal, or wood ...primer/thinner. It's often added to oil based paint to make brushstrokes flow out to a high gloss. It has UV inhibitors that help it last in the sun. I use it by it's self, as a clear metal protector. I can lightly brush any rust or corrosion, like on bolt heads to my John Deere engine. Blow off the dust and with a rag soaked in PENETROL,or a brush, just add a light coat. It drys to a very thin, clear satin finish. It's tough stuff. It works on all metal types, even galvanized. I have a large sailboat trailer, that has to be completely submerged to lauch the sailboat. I wash it down after every use, but noticed a few days later there would be a white powder showing, all over the trailer where the galvanizing had reacted with the salty seawater. This was in 1984. I have used PENETROL to clear coat/seal the galvanizing eversense. The trailer and even the black steel springs, still look great. I only recoat every 2 years. It's great for the drill press, shop compressor, bandsaw, table saw and stored saw blades etc. It being clear, your original paint that may have faded, will get the look and gloss of fresh paint. It's so easy to use...give it a try. Got to go charge my woodie stuff... ![]() John Quote:
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
