Nightowl,
The stresses Don talks about are not bending loads. A bending load is always comprised of the 3 actual stresses that Don describes. The quarter-sawn "C" grain wood has been proven to take more tension and compression stress that "A" grain wood. For leading edge sheeting, A-grain balsa is the first choice because it bends much better across the grain without splitting. But for spar caps, ribs, and other members that take loads and don't have to be bent, C-grain has been proven to be the stronger of the two. Don's post was spot on. For instance, I am using a piece of quarter-sawn Englemann spruce right now for a sound board. It's .090 thick and 9" wide. It's grain is very even, and about .050 on centers, running vertically through the wood, and it is heavily "cross silked" (luthier term). The cross silking is the radial wood fibers that Don mentioned. It will go a long way to keep this thin spruce from splitting. UD CF is not A-grain, nor C-grain. It's constant filament fill is completely different than wood where there are softer portions between harder, darker grains. Again, no argument... just adding to the discussion... ...Jack |
M45, the Pleides- seven sisters is between the constellations Perseus and Taurus. Take a line between Orion and the const Taurus and Pleides will be just to their right for you folks in the northern hemisphere, they are almost eqi-distant apart. For us they are the other way around. here's a pic i stole and annotated from http://spaceweather.com/archive.php?...h=12&year=2009 taken from Ca, US. May its owner forgive me.
Question for Don Stackhouse
Don?
Did I read your post correctly that the "perfect" shear web would be composed of two webs oriented at 45 degree angles? If so, I think I'll try that on the next woodie I build. I haven't broken a wing in years, but I like the extra insurance. Now I just have to get the wife to move all the sewing stuff and extra junk out of my building room. She INSISTS on calling it her spare bedroom and does not realize the danger we are in if I can't sand some balsa! |
Jack, thanks for the input. Sounds like you and I have some common interests and activities in addition to model sailplanes!
Nightowl, we were indeed on different pages, and now that I see where you're coming from, I'll try to respond. However, it requires an involved response, and you might have to wait a bit until I can fit it in. Right now I have three fiddles here getting major structural reconstruction work, a violin needing a complete setup along with a rehair and some repair work on its bow, a 1957 Gretsch guitar here for a complete refret (all five of those projects hopefully done by the end of next week), the design for my new mandolin to finish, a prototype wooden sailplane to finish and designs for several others to work on, and several other projects that need work. I'll have to pace myself on this thread a bit. Hossfly, +/-45 degree orientation is a term from advanced composites. It usually refers to orienting the fibers of woven ("bidirectional") cloth so the fibers run at 45 degrees to either side of the principle direction. When we apply that idea to wooden structures, the best "fit" of the term is with plywood, the wooden equivalent of bidirectional woven cloth. What you describe amounts to making your own plywood from two individual layers of wood. That would work, but the resuting shear web would be "unbalanced", so that when you apply a bending load to that sort of spar assembly, it will want to twist. By going with an "isotropically balanced" arrangement (the plies are layered so that starting from the middle of the stack, the layers to one side of the middle are the mirror image of the plies on the other side) we can eliminate this problem. In the case of your shear web, the typical solution is to make the shear web from plywood with an odd number of plies, and the ply thicknesses varied so that the amount of fibers running one way is the same as the other way (for example, a three-ply, with the middle layer twice as thick as the two outer layers). Orient that so the plies run 45 degrees to the span. This optimizes the shear-carrying ability, but hurts the anti-buckling support function of the shear web. It also is difficult to fit on standard-sized plywood sheets without having a lot of waste. Running the fibers at a 0/90 orientation doesn't lose too much shear capability in comparison to what most models require (the situation on full-scale aircaft might be more critical in this regard), helps the anti-buckling support and makes much more efficient use of the typically available raw materials. |
I am actually very interested in learning more from your perspective on this. In a way, Jack's post pointed out the same thing I said, where his .090 x 9 inch sheet will resist splitting along the grain better than A-grain, but if it was .090 x .180, I just don't see the stresses that would be trying to create a split. Nightowl |
AtmosSteve
http://apod.nasa.gov/apod/ap091217.html This was also the Astronomy Picture Of the Day (APOD) yesterday! That is the webpage that I have my browser, Firefox, set to open to. Thanks to all for this structures discussion, it has helped clarify several things for me http://www.auf.asn.au/scratchbuilder/joints.html Another cool webpage One of the interesting things to note is the wood joint being glued should be FRESH. Lightly sand the surfaces with fine sandpaper before gluing if they have had any appreciable time to oxidize. |
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
