Got it Ray!Now you can sleep tonight without one of those 1:30 AM flashes. ![]() No Don, I didn't get involved in the building of this one. Only the final RC and EP setup. It was built by a local gentleman with a loooong history of modeling accomplishments. I am thinking about building something FF era in the near future though. I would love to tackle a Valkerie at some point. I'll see if I can find some details of that one. I saw one two years ago and have to say that it is one of the most beautiful models I have ever seen in my life. Edit: Well, I'll be darned (or probably worse), here's a link to a build thread of one here on RCG! http://www.rcgroups.com/forums/showthread.php?t=676390 Absolutely amazing. I want you all to look closely at the wing structure. Be prepared to bow down and prostrate yourself in front of anyone that has ever succesfully built one of these. Talk about a woodie project. I would almost hate to cover all that gorgeous balsa...........almost. |
Food for thought
http://www.wdv.com/Writings/StrongestWood/index.htm
Then follow the link to here; http://www.wdv.com/Writings/Stronges...eeStrength.xls Theoretically you can use any wood as long as you reduce the size to the appropriate dimension, etc. I also have a question, or two..... Which way should the grain lines be pointing if you buy yourself a piece of Spruce from here; http://www.aircraftspruce.com/menus/wp/spruce.html to cut up into your own spar stock on a table saw? I bought myself a chunk for about ten bucks so I could cut some spars for a couple years. I think I have two or three years worth. Should the grain run spanwise or vertically? And, I can straighten out the grain direction and run out on the table saw, but how much effort should I put into this effort? |
GD, you may have to draw me a picture of what you're talking about. I thought the spars should be a long run of straight wood running in the one direction they won't cut across any growth rings (i.e., "up and down" as you look at the tree, and cut from a section between growth rings if possible).
I'm just not sure what you're talking about, here. Nightowl |
There are fibers in a tree that run outward from the center like the spokes of a wheel, perpendicular to the rings. These are what make the "speckles" in C-grain wood, and give wood that's cut that way a little more strength and stiffness in that direction. Since on most spars you're in need of more shear strength in the vertical direction, this means that the wood should be cut with the rings horizontal, parallel to the chord.
However, if you have an I-beam or box spar where the spar caps extend to one or both sides of the shear web(s), the problem is carrying the loads across the width of the caps to the shear webs. In that case it's better to orient the rings the other way. In other words, whatever direction you want to have the most shear strength, make the rings perpendicular to that direction. |
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
