Bleeding and trailing edges
Top sheeting attached, time to install the leading edge. Since it is a rather small piece, the borg held it down with a few short bits of double sticky tape to pre-shape. He got the angle at the rib junction first, rounded the top side a dash to help follow the curve of the sheeting, then shaped the bottom. It surprises me sometimes how slowly balsa will sand when you are trying to get it flush to the bottom of the ribs. He didn't want to have to sand it after it was attached, and I agreed. Weighed down and glued with Titebond and a couple drops of CA at the ribs to hold it till the titebond set.
Roger cut the trailing edge pieces ExACTly to length before we pre-glued them together. He is ending the sheeting on 1/2 of the 1/16 thick ribs, 1/32 inch target, because that is what the plan shows. Fat-fingered me will probably add another rib, but the challenge is who can build the lighter plane, the plans give us a 3.8 ounce total weight goal. I don't think either of us will get there. The T.E. was then simply slipped on, weighed down to the flat table [with wax paper between table and probable glue flow] and micro-drop CA'ed to the ribs. Next up: shear webs...........soonish.
Gotta watch it with the Gorilla Glue or any other type of polyurethane. It is 100% solids, which means that no solvents evaporate. The amount you put on is the amount that's there. It will weigh what it weighs in liquid form. I'm very sparing when I use it. It's the very best stuff to use for attaching upper sheeting, because the foaming forces glue into the wood, and it will bridge some gaps... not that I have any to bridge... I hope...
Jack |
Latest blog entry: The BEST!
Don,
I'd use thick CA or PU to attach the sheet to the spar. The only reason I use epoxy there is to attach the CF to the spruce. Spruce and CA don't like each other much. Either CA or PU will be stronger than the balsa, and lighter than the epoxy, if used sparingly. I usually use thick CA there because it anchors the back edge of the sheeting while the rest of the glue between the ribs and sheeting sets up. JW |
Don,
Working time on thick CA is 20 seconds or so... or longer in cooler weather. I stack phone books on the sheeting and usually don't have voids. They conform well to the airfoil curve and give ample pressure. JW |
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
