Atmosteve..
I have been following your build on the Oly III very closely to pick up any ideas as I build mine. My fuselage is basically finished, and my wings will be next with flaps and ailerons. Some of the others on here had questions or ideas as to the cowlings and hatches.....here are some pix of my solution to them. Looking forward to your next posts. Gerald
Hey Ed,
Yes, actually it's a Spirit 2m ARF. I bought the last two from Tower and is also my first. I like the tail feather mounting on this ARF and will try do something similar on my OlyIII. It has just enough rigidity in it to hold nicely but will give a little if needed so it won't break any bones. Don |
LI, New York, USA
Joined Mar 2003
Couple of tips on the Spirit that may carry over to the OlyIII
Add something to stiffen the bottom of the fuse where the nuts go over the shafts. Otherwise this is very flexible and does not hold properly. Fin may move on rudder inputs and nuts tend to loosen up. Check nuts often or add Jam nut. If you plan to leave the tail on most of the time you can touch the nut with a drop of CA. Easily broken to remove it. |
Gerald:
How does that fully flying stab work? I built one for a Gentle Lady and found that a flat plate stab was VERY touchy - too much so to fly well even with lots of expo dialed in the Tx, so I converted it back to the stock tail. Would building a stab with a NACA 0009 foil shape work better? That would be similar to a RTF Bird of Time and it works very well. What would be the correct size? Larger or smaller than total area of the elevator + stab? I would like to have one on a Oly III that is next up on the bench, but I am not willing to experiment and possibly hurt a plane that flys well with the stock tail. FC |
Hey those Texas weeds sound pretty nasty!
Did you microfill and spray your fuse, or has it had a light glass covering? Looks pretty smooth and clean. Flaps and ailerons- sounds interesting!
With the fastening of the tail feathers, are you guys using metal or nylon bolts?
One thing I found with various planes is that nylon bolts have a safety factor to them in that they tend to shear under impact and can save your wings and fins from some damage. Are those Texas weeds really that nasty? I have this mental picture of a 3 foot high barbed wire tumble weed. |
Foam crusher..
Yes, I have taken into account that this elevator is going to be very touchy. I plan on keeping the movement to a bare minimum. The bellcrank I built does not have a lot of moment in it just for that reason. Steve.. I covered the fuse with 3/4 oz glass with a minimum of epoxy to fill it then sanded it, wet sanded it, sprayed it with 2 coats of John Deere yellow, used 000 steel wool between coats, and plan to rub it all out with rubbing compound in about two weeks. The way I fly I need as much strength as I can get.....EVERYWHERE! Gerald |
=> for froggy.Spammer... SpamChief LOL!!!! Back to business please froggy, a bloke like you has heaps of good stuff to offer a woody thread.
Atmosteve, I was looking at your photos and I want to ask a question. Do you know the name and manufacturer of the glider pictured here:
http://www.rcgroups.com/forums/attac...mentid=2091795 |
| Thread Tools | |
| HELP ME!!!< I think I'm getting addicted to cutting foam!!! | slowflyer | Foamies (Kits) | 7 | Feb 21, 2011 12:58 PM |
| I'm Getting my FiXX | Craig558 | Foamies (Kits) | 6 | Mar 18, 2002 10:40 PM |
| looks like i'm getting a piccolo, any advice? | cheapflyr | Electric Heli Talk | 13 | May 10, 2001 08:34 AM |
| I'm getting worried | SchiessCo | Electric Plane Talk | 1 | Apr 21, 2001 08:11 AM |
