Old Jan 16, 2003, 05:12 PM
michael
michael
Guest
n/a Posts
Zwarte Zee Setup help
Hi Everyone,
I have purchased the Zwarte Zee (billing kit) and want to convert it
to rc.
I am a flyboy and not a water rat and wish to know what I need to do
to keep the water out, or to a minimum and what I should do to keep
the radio gear dry.
Does anyone have a piccie of their setup that i could use.
Any other hints also welcome (keep it clean...)
Thanks In advance for your help
Blueskies (or in this case smooth sailing)
Old Jan 17, 2003, 05:22 AM
Allan
Allan
Guest
n/a Posts
Re: Zwarte Zee Setup help
Which version?
If it is the ABS version then no problems - just put in a standard prop
shaft etc. The wood version is more difficult - you need to first ensure
thathe hull is waterproof - You can line the inside with skinning epoxy
thinned down - it will then soak in to the wood- once dry (overnight) fill
the hull with water and look for leaks. Fix them before going on.
Graupner used to do a prop shaft assy for this boat but if it's not
available buy one or go to AsTec Models who can supply to order....
www.astecmodels.co.uk . For the rudder it is difficult. I built the rear
most deck fitting (the little gear cover) as a removable piece of deck then
mounted the rudder stock under it with the actuatore on top. The servo motor
etc was all in the main hull.
Allan
,"michael" <seafurymike@hotmail.com> wrote in message
news:a9724f2.0301161505.64472d1@posting.google.com ...
> Hi Everyone,
> to rc.
> the radio gear dry.
> Mike
Logo 10 setup help rcdude Electric Heli Talk 10 Jan 09, 2002 07:46 PM
Crazy Max Setup Help Please ETKing Parkflyers 3 Dec 23, 2001 06:02 PM
Piccolo Setup Help! rcastab Electric Heli Talk 6 Dec 16, 2001 01:39 AM
logo 16 setup help mkurosaka Electric Heli Talk 0 Jul 26, 2001 11:09 PM
9Z and JR Voyager E Setup Help Wanted Please Brett Electric Heli Talk 3 Jul 01, 2001 07:00 PM
