Old May 08, 2008, 09:22 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Mini Pulse XT at 14,240 ft.? Let's find out!
So yeah, I live about an hour and a half from Mt. Evans in Colorado. It currently sports the highest paved road in the world. The road ends at a large parking lot adjacent to an observatory on the peak.
I'm thinking of taking my MP-480 up there and seeing if I can get away with flying it as high as one has possibly ever been flown. Think it'll work?
I'm thinking a 13-7 or 8 prop. On a clear, relatively calm day.
I may try and recruit a videographer to come along and document.
Anyone interested in seeing this?
Evvy
EDIT: It turns out that there is a 16,000 ft paved road somewhere in the Alps... But who's counting, right? Search Mt. Evans, it's very cool.
Wingwrecker is offline Find More Posts by Wingwrecker
Old May 08, 2008, 09:55 PM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Id go with a 13x5.5....need more bite in the thin air.
GoldCraft is offline Find More Posts by GoldCraft
Old May 09, 2008, 06:54 PM
Joined Feb 2008
I'm still a bit unclear about how prop-pitch works in the real world. I keep getting conflicting answers from people.
So you think I should pitch down in thinner air?
I normally fly at around 6000 ft. Most people are using 11x7e's on their 480's, should I be using a lower pitch?
Old May 09, 2008, 07:37 PM
GoldCraft's Avatar
Joined Jan 2007
Its kinda misleading the way the numbers work ...a 5.5 has more pitch ....in a perfect world the plane would move 5.5 in. in one revolution where a 7 would move 7 in.....so a 5.5 has more bite but less top end speed. In very thin air more bite and more prop length would be better to get the plane moving in the thin air. At 6k the 11x7 may be fine .....but 14k is a new game. A 12x6 may work for you as well. I would take a few different ones ....put them on ....hold the plane and hit 3/4 throttle and see if she has strong pull.
Old May 09, 2008, 09:02 PM
Joined Feb 2008
Good call, that's what I'll do. Thanks.
Old May 10, 2008, 09:52 PM
A1966C150F is offline
Find More Posts by A1966C150F
Joined Jul 2007
I fly in Colorado also. I'm not sure what Goldcraft is talking about when he says a 5.5 has more bite. More pitch is more bite. A flat prop has no bite, and a 5.5 is flatter than a 7. I've flown at Fairplay in the summer and you need a little more diameter and a lot more pitch. I normally fly in Grand Junction approx. 5000 ft. elevation. In the summer the density altitude can reach over 8000 ft. Most of my planes require 1" more diameter and 1" to 2" more pitch to perform like sea level. On Mount Evans this summer I would think you would need much more than that.
A1966C150F is offline Find More Posts by A1966C150F
Old May 11, 2008, 08:20 AM
Joined Feb 2008
See what I mean? Arrgh...
Old May 11, 2008, 10:23 AM
F7X is online now
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
Wingwrecker,
When you get to the mountain, add pitch until you reach the same amp draw you have in Parker. That's all you can do. The only other thing to remember is that the stall speed of the aircraft from your point of view will be faster. Make your approach turns shallow, and a little faster than normal. Let us know how it went!
-Joshua
F7X is online now Find More Posts by F7X
Old May 11, 2008, 10:37 AM
GoldCraft's Avatar
Joined Jan 2007
Originally Posted by Joshua Wesley
Wingwrecker,
-Joshua
Good advise....
Old May 11, 2008, 11:16 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
For your consideration...
DIAMETER governs THRUST - larger # = MORE THRUST
PITCH governs SPEED - larger # = MORE SPEED
To double you altitude, (wild donkey guess follows...) +2" Diameter and +3" to +4" on pitch. A "windless" day on top of a peak in the Rocky Mountains is not bloody likely. Good luck - take an amp meter and several LARGE props. Test by holding the plane nose up, by the wingtip and apply throttle. If there is enough power to fly, the plane will come to almost level - if the plane wants to walk all the way around the wingtip that you are holding... then you have good power to weight.
JimNM is offline Find More Posts by JimNM
Old May 11, 2008, 01:34 PM
danstrider is offline
Find More Posts by danstrider
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
I'll double up 1966's post about more pitch. Goldcraft, I think you have it backwards. More pitch for the 7" prop means it'll bite more air each rev than a 5.5". I'm a low-land flier relative to this discussion, but thought I'd chime in. For the same engine, if you wanted more top-end speed, you want to increase pitch and drop diameter so you keep the load roughly the same but have the ability to eat incoming air (versus a flat prop). If you need low-end thrust, up the diameter and drop a pitch because airspeed is slower and with the lower-pitch, the engine can unwind a bit more and the flatter pitch but lower airspeed match up just fine.
I'm sure for a brief moment you'll be the highest model airplane in the world! Whoa!
Nice idea :-)
Dan
danstrider is offline Find More Posts by danstrider
Old May 11, 2008, 02:10 PM
GoldCraft's Avatar
Joined Jan 2007
Nice idea :-)
Dan
Yeah , I agree after rethinking it . I was thinking more low end thrust would be needed. I know my boat is much quicker to accerate with a 17 pitch prop v. a 21 but has less top end....must not work the same in air.
Old May 11, 2008, 02:49 PM
Joined Jul 2007
Gold Craft, you're absolutely right about the pitch and acceleration, but water density is always the same unlike air. Plus, internal combustion engines loose power at higher elevations (unless they are supercharged) and sometimes cannot turn any increase in pitch or diameter. An electric motor performs in either condition and will need to be loaded more when higher.
Old May 11, 2008, 03:19 PM
Joined Feb 2008
Nice idea :-)
Dan
Thanks. I'm hoping the moment is not TOO brief!
Yeah, I'll be checking the wind forecasts and keeping my fingers crossed.. If I can get a day with 15 mph or so winds, I will be fine. That seems to be all we have here in Denver during the spring and I've grown pretty accustomed to it. Whoever named Chicago the 'Windy City' has obviously never been to Denver!
So thanks guys for all the input. I'm definately going with 13" dia. I'll have to check what kind of pitches I can get at that size. I'm thinking that a 13-8 to 13-11 is the range I want to be in. I'm new to EF so I don't own a watt-meter yet, but I will get one, learn how to use it and bring it with me.
Just need to find someone with a video camera or get a 5-in-1 for my hat.
The road doesn't open till the end of this month and I'll give it a week or two for the opening season crowds to subside a bit so that I can have some landing space.
Hope I don't get hassled by a park ranger! The ticket will be worth it, either way...
I'll keep you guys updated, In the mean time all suggestions are very welcome.
Thanks again,
Evvy
Old May 11, 2008, 04:17 PM
GoldCraft's Avatar
Joined Jan 2007
Yeah...plus the big issue for a boat is cavatation....higher pitch props tend to cavatate when you try to accelerate to fast from dead stop in water . A fluid dynamic thing
But I understand the need to load up the motor more for electrics now.
Discussion Mini Pulse XT !!! 800mZero 3D Flying 47 Dec 19, 2008 04:17 PM
Build Log E flite Mini Pulse XT mjljr Parkflyers 21 Jun 04, 2008 08:41 AM
Discussion Mini Pulse XT PNP, Cellpro 4S, 3s2100 Cellpro Rev's ordered: LOOK OUT SKY! berettafan Electric Plane Talk 6 Jul 24, 2007 02:51 PM
Sold E-flite Mini Pulse XT phoneguy Aircraft - Electric - Airplanes (FS/W) 1 Oct 31, 2006 09:39 AM
For Sale NIB - E-Flite Mini Pulse XT ReadyHeli Aircraft - General - Radio Equipment (FS/W) 1 Oct 25, 2006 12:16 PM
