Old May 08, 2008, 07:13 PM
flyboy320 is offline
Find More Posts by flyboy320
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
Voltage differance at end of charge OK?
When charging my Polyquest 2S 4000mah lipos, at first the voltage is the same, around 3.80v. At the end of the charge, and just before the Cellpro 4S goes into balance mode, the voltages of the two cell will be different, usually cell 1 will be 4.15v, and cell 2 will be 4.20v.
Is this difference of 0.05v at the end of the cycle something to be concerned about (the Cellpro always finishes them off at 4.20v each)? I also notice after some time, cell 1 will be less then 4.20v, maybe around 4.17v the next day, but the other one usually stays fairly close to 4.20v.
flyboy320 is offline Find More Posts by flyboy320
Old May 08, 2008, 08:09 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
that's becuz the pack is not fully charged , only a slow charge will stabilize the voltage
when the charge current goes down to zero @ 4.2V when using a regulated source and NO, U don't have to use a VOLTAGE CLAMP
hall woo is offline Find More Posts by hall woo
Old May 08, 2008, 08:49 PM
SilverFoxCPF is offline
Find More Posts by SilverFoxCPF
Bellingham WA
Joined Jan 2005
Hello Hall woo,
According to the article in this post, you will loose cycle life if you keep charging until the current drops to zero.
Don't you think it would be better to give up a little capacity in favor of cycle life?
Tom
SilverFoxCPF is offline Find More Posts by SilverFoxCPF
BP gets hot at very end of charge?? lockheed martin Batteries and Chargers 51 Aug 17, 2005 07:21 PM
Will TP ProLite 2000 be charged end up at 4.26V and ok! jetkkman Batteries and Chargers 3 Jul 08, 2005 01:28 PM
APACHE 2500 end of charge Voltage per cell harvey Batteries and Chargers 5 Nov 10, 2004 11:59 AM
Hacker Master 40-3P shutdown at end of pack, voltage cutoff? MikeStammer Electric Heli Talk 2 Jun 11, 2004 09:30 PM
LiPo in Nokia cell phone - end-of-charge voltage? Danny Van Hoecke Batteries and Chargers 0 May 13, 2003 02:35 AM
