Old Feb 20, 2013, 11:17 AM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
Gree,
WOW! And all of the other words people have used to describe your work.....well except for maybe Jeff......he's just jealous....
al
rossaer is offline Find More Posts by rossaer
Old Feb 20, 2013, 11:41 AM
Jeff Van Hofwegen is offline
Find More Posts by Jeff Van Hofwegen
Joined Feb 2010
Wow, it really looks fantastic! Good luck with the maiden!
jeff
Jeff Van Hofwegen is offline Find More Posts by Jeff Van Hofwegen
Old Feb 20, 2013, 03:09 PM
Kaikokid is offline
Find More Posts by Kaikokid
New Zealand, Northland, Kaikohe
Joined Aug 2011
Absolutely
Kaikokid is offline Find More Posts by Kaikokid
Reply With Quote  (Disabled)
Old Feb 20, 2013, 04:12 PM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Nice work. I unsubscribed myself somehow before christmas, you've been working hard!
aerophilia is offline Find More Posts by aerophilia
Old Feb 20, 2013, 04:19 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
I am embarrassed to start mine now!!! Very nice Gree!
rcwings is offline Find More Posts by rcwings
Old Feb 20, 2013, 04:56 PM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
I think I will sell my kit after seeing this. I have the tanks, bombs, and full cockpit. Just missing the cowl
CapMike is offline Find More Posts by CapMike
Old Feb 21, 2013, 09:43 AM
Jeff Glasser is offline
Find More Posts by Jeff Glasser
Limey Jeff
Jeff Glasser's Avatar
Glastonbury, Somerset. U.K.
Joined Mar 2009
Originally Posted by rossaer View Post
Gree,
al
So true, but of course I would never admit it.
Pom Jeff
Jeff Glasser is offline Find More Posts by Jeff Glasser
Old Feb 21, 2013, 10:04 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Guns Installed
Thanks very much guys, it's really nice to hear your comments. Keeps the creative juices flowing... Glad to know you're all still out there after so long!
Guns, Guns, Guns, Guns
I found the aluminium tubing I bought for the gun flash tubes a long time ago, and set about measuring up the length of each tube from my trusty 3 view. I used a metal cutting drop saw to cut up the tube to ensure I got square ends. A lot of filing and sanding later (the saw only seemed to melt the aluminium when it cut it leaving massive burs!) and I had 8 flash tubes ready to install. If I had the motivation, or if this was a larger scale model, I would also put smaller tubes inside to simulate the actual guns, but I am in the 'get it done' frame of mind right now.
The jig I made up and used to drill the mounting holes for the guns paid off, as they went in pretty straight. Only a little tweaking was required. As much as it will make transporting the wing a pain in the butt, I roughened up the ends of the tubes with sandpaper, then epoxied them into the holes. They are there for good now, I will just have to be very careful when moving the model.
After all of this I got out the airbrush again and weathered the tubes with Tamiya Smoke, making sure to make the stains heaviest at the ends of the tubes, and then fading it back along the length. I thought that since the guns get progressively closer to the leading edge of the wing, I would reflect this by making the outmost cordite stains a lot darker, and then making them lighter as the guns get longer. I think this would be accurate. Using my imagination here!
One less job to do...
Gree is offline Find More Posts by Gree
Old Feb 22, 2013, 04:31 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
What the hell have they done to the forum again? The images have lost their view counter... I needed that to build my ego!
Old Feb 22, 2013, 10:12 AM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
I see it once I click on the images themselves. But what I really hate is that if you go to the thread gallery, it has like 10 images per page, instead of 250! Ugh!!!
jtaylor996 is offline Find More Posts by jtaylor996
Old Feb 22, 2013, 10:13 AM
Registered Crasher
Joined Feb 2011
Hey, since you paid so much attention to getting the guns "straight" did you remember to point them in a little to converge the fire at the scale distance?
Old Feb 22, 2013, 10:31 AM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Hey Gree,
Been away from the build for a bit. Man you do nice work. You sure you want to fly this thing? Some of the nicest detailing/finishing I have seen on the forums. You have to be chuffed to see it coming together at last.
Regards,
Jeff (#2 or #3, I forget which)
jhspring is offline Find More Posts by jhspring
Old Feb 22, 2013, 02:01 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Wow, absolutely museum quality work man.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 22, 2013, 08:59 PM
Airforce9 is offline
Find More Posts by Airforce9
Joined Dec 2012
Hi Gree,
Just dropping in from RC scale builder. It's great to see that you're almost done. Looks awesome! I still have a looonnngg way to go to catch up.
I have a question for you on your servo hatches. I just did mine with fiberglass similar to what you did. However, since the thickness of the hatch is less than 1/16 inch it ends up resting such that it isn't even with the surface of the wing. On top of that, once I glass the wing it will be even more of a difference. What did you do to deal with that?
Thanks!
Steve
Airforce9 is offline Find More Posts by Airforce9
Old Feb 23, 2013, 03:47 AM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
I found the aluminium tubing I bought for the gun flash tubes a long time ago, and set about measuring up the length of each tube from my trusty 2 view. I used a metal cutting drop saw to cut up the tube to ensure I got square ends. A lot of filling and sanding later (the saw only seemed to melt the aluminium when it cut it leaving massive burs!) and I had 8 flash tubes read y to install. If I had the motivation, or if this was a larger scale model, I would also put smaller tubes inside to simulate the actual guns, but I am in the 'get it done frame of mind' right now.
Nice .50 cals
super kupfer is offline Find More Posts by super kupfer
Question motor battery prop combination for top flite P47 63"? Gree Glow to Electric Conversions 27 Jul 20, 2014 08:42 PM
Discussion Yes another top flite giant P47 build pand9 Fuel Warbirds 5 Jan 07, 2009 06:25 AM
Discussion P47 Top Flite - Making Off rushspbr Fuel Warbirds 18 Dec 07, 2006 09:03 PM
For Sale Top Flite P47 Tom Jennings Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2006 11:51 AM
Top Flite DC-3 Eddie P Scale Kit/Scratch Built 10 Jul 20, 2001 06:11 PM
