Old Feb 13, 2013, 06:45 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Landing Gear Complete
Gear Doors are all Done
I finished manufacturing the inside of the lower gear doors, riveted, painted, and installed them. I must say it is satisfying to see something you devised years ago fall back together and work first pop.
Next is to hook up and the gear and cycle it properly (after I get the gear door sequencer working correctly), and make any fine tuning required to the fit of the doors.
Not much more to say on this really. I'll let the pictures tell the story...
Brainwave?
It just came to me when I wasn't thinking about it yesterday, that I had not wired up the gear sequencer correctly. Instead of running the receiver to the unit, and which then connects to the air value servo and the two gear door servos, I think I just ran a Y harness to both the unit and the air valve servo. I didn't have time to check this, but this may be the source of the unit not working as it used to... I goes it had been a long time since I used it last. Fingers crossed for that one!
Gree is offline Find More Posts by Gree
Old Feb 13, 2013, 10:07 AM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Looing damn fine Gree
CapMike is offline Find More Posts by CapMike
Old Feb 13, 2013, 01:11 PM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
Eh. I guess that'll work, if that's the best you can do.
denial15 is offline Find More Posts by denial15
Old Feb 13, 2013, 02:24 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Spectacular Gree.
Chad Veich is offline Find More Posts by Chad Veich
Old Feb 13, 2013, 10:16 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
(better than LOL, although Idid)
V2rider is offline Find More Posts by V2rider
Old Feb 14, 2013, 07:03 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Wow! I've always been s sucker for a nice set of legs!
On a side note I am so excited for you that this is almost finished up, but also a bit sad. I've been silently following this from just about the beginning, and am going to miss seeing your updates. I guess you are going to have to start another awesome build to fill the void
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Feb 15, 2013, 01:48 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Thanks guys! And don't worry Matt, there are plenty of places in the queue. The next will most likely be a 190D9.
Just to feel a sense of achievement, I thought I would revisit my 'to do' list...
1. Make the rear canopy attachment and install
2. Glue the canopy on
3. Make the landing light and install
4. Make the wing tip navigation light interiors and install, plus glue on the wingtip lenses
5. Get a new motor shaft adapter from Truturn. I found out mine has the wrong thread!
6. Make insides of lower gear doors
7. Make insides of middle gear doors
8. Attach gear doors to struts
9. Attach inner gear doors
10. Make trim tab actuators for ailerons
11. Final coat of paint for ailerons
12. Attach ailerons and hook up servos
13. Put on cowl checking that motor is centred
14. Paint tips of prop yellow
15. Paint prop hub yellow
16. Make tail navigation light
17. Work out how to open the battery hatch and make solution
18. Weather the wing etc
19. Make and install the guns
20. Get new 6S 5000maH batteries
21. Balance
22. Find a place to actually fly this thing!
23. Pray hard to a god I don't believe in
24. Fly...
GREY = done!
I have to add this to the list too...
25. Fix bloody gear door sequencer! - FIXED!
We are slowly getting there!
Old Feb 15, 2013, 03:51 AM
Mark Derbyshire is offline
Find More Posts by Mark Derbyshire
Mark Derbyshire's Avatar
United Kingdom, England, Salisbury
Joined Jul 2011
If you can't fix it I can highly recommend one of these
http://www.pololu.com/catalog/product/1350
I used them on all my retract birds. They are programmable via USB using a script. If you want it I can send you the script for my mustang and can modify it for timings etc
Plus they are half the price and smaller of the one you have
Oz stockist
http://www.robotgear.com.au/Product.aspx/Details/403
http://australianrobotics.com.au/cat...vo-controllers
Mark
Mark Derbyshire is offline Find More Posts by Mark Derbyshire
Old Feb 15, 2013, 10:30 AM
Jeff Glasser is offline
Find More Posts by Jeff Glasser
Limey Jeff
Jeff Glasser's Avatar
Glastonbury, Somerset. U.K.
Joined Mar 2009
Denial15...you took the words right out of my mouth!!!!
Jeff
Jeff Glasser is offline Find More Posts by Jeff Glasser
Old Feb 16, 2013, 10:07 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Wow man... just perfect
you make me sick
put this thing in a museum or my shop
the lines look perfect on the gear doors..... great work
Ron101 is offline Find More Posts by Ron101
Old Feb 16, 2013, 11:23 AM
1ruffdog is offline
Find More Posts by 1ruffdog
United States, ID, Boise
Joined Apr 2012
Gree. Very nice build. Here is some information for you in interior and primer colors.
Cheers,
1ruffdog is offline Find More Posts by 1ruffdog
Old Feb 16, 2013, 01:25 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
awesome, reminds me of the fiddly gear doors and gear well (same color green!) on a plastic f-84 model I never finished, and yours actually move!
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 18, 2013, 03:38 PM
amxen is offline
Find More Posts by amxen
United Kingdom, England, Keighley
Joined Nov 2009
gree just a quick question . did you offset the motor the same as a glow engine would be. as on the plane ?
amxen is offline Find More Posts by amxen
Old Feb 18, 2013, 10:39 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
A Little Good News
We Have Working Gear Doors
On a thesis writing break, I popped down and had another look at the gear door sequencer. I noticed that the LED was not on sometimes. Turns out it was a simple case of dodgy wiring on the part of the manufacturer. The signal in wire from the receiver is soldered directly to the board. They basically stripped too much insulation from the wires, meaning they could bend about and touch each other, shorting out the unit. Pulling the wires taught and separating them, then hitting the area with hot glue solved the problem...
I will post a video of the final doors working when I get time to assemble the plane again. I am thinking of replacing the door servos with some stronger digital servos to stop the buzzing... I think I have some laying around somewhere.
Thanks very much for all of the great comments guys...
Thanks Mark, luckily I won't need one, but it is good to know that these exist. You could do some really cool stuff with these! Maybe for the next build...
Good to have you back on board man...
you make me sick
Thanks Ron. I tried really hard to get the doors shaped right. They are exact copies from a 3 view scaled up. I am chuffed you've noticed!
Thanks 1ruffdog. Always good to have good references. I won't be repainting anything now though!
They do now! Thanks man...
Hi axmen. Yes I did offset the motor fractionally. Not as much as the plans called for, but my cowl is actually slightly crooked to make the motor look centred. I have some down thrust as well. I think it should be fine. I did the same for my CMP Zero and it flies great.
Old Feb 20, 2013, 06:19 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Retracts Test
Gear Doors
Here is the video I promised of the gear doors in action. I still need to fiddle with the door throws and build a stop for the inner doors so they don't close too far (as you'll see in the video). I will make the doors open a lot more so they are more vertical. A simple adjustment of the sequencer unit when I get some time...
P47 Completed Retract Test (1 min 26 sec)
A Little More Weathering
I also did the exhaust stains on the fuse and inner gear doors, and cordite stains on the wing while I had the plane together. I used Tamiya smoke. A tricky paint. It seems to get a lot darker as it dries. It is semi-clear so you think you have put a lot less on than you actually have. Oh well, it is what it is!
I also put the prop on (with its fancy new yellow tips) for eye candy...
Question motor battery prop combination for top flite P47 63"? Gree Glow to Electric Conversions 27 Jul 20, 2014 08:42 PM
Discussion Yes another top flite giant P47 build pand9 Fuel Warbirds 5 Jan 07, 2009 06:25 AM
Discussion P47 Top Flite - Making Off rushspbr Fuel Warbirds 18 Dec 07, 2006 09:03 PM
For Sale Top Flite P47 Tom Jennings Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2006 11:51 AM
Top Flite DC-3 Eddie P Scale Kit/Scratch Built 10 Jul 20, 2001 06:11 PM
