Old Jan 16, 2013, 02:55 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Oh, and another little by-the-by....
When glassing my flaps and ailerons, I gave them a flow coat of resin (thinned with a little metholated spirits) after the initial coat. You may remember that I only did one coat of resin on the rest of the plane and filled the weave with spray putty.
My god what a difference in terms of ease of finishing when it came time to sand and spray the fill primer. Just sanded the resin, then only one coat of the fill primer needed and some small application of spot putty here and there compared to about three coats of fill primer on the glass with only one coat of resin.
For anyone new to glassing I STRONGLY recommend doing the flow coat!
Gree is offline Find More Posts by Gree
Old Jan 16, 2013, 04:51 AM
Mark Derbyshire is offline
Find More Posts by Mark Derbyshire
Mark Derbyshire's Avatar
United Kingdom, England, Salisbury
Joined Jul 2011
Originally Posted by Gree View Post
As an aside, does anyone else know that pure rage that comes from not being able to find something that you only used a couple of days before?!
Yes but in my case it's usually something I've had in my hand and then placed it somewhere only minutes before!
Mark
Mark Derbyshire is offline Find More Posts by Mark Derbyshire
Old Jan 16, 2013, 06:13 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Oh yeah I've done that too! Once I was working on my car, put a spanner down then reached for it a minute later. It wasn't there and I've never found it! That was the angriest I have ever been in my life I think
Old Jan 16, 2013, 03:03 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Just thought I'd post a short highlight video from the other day of one of the reasons it has taken me so long to get close to finishing this build... FPV flying is certainly addictive!
Cloudy days (4 min 16 sec)
Old Jan 16, 2013, 03:16 PM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Up at the butt crack of dawn there Gree?
CapMike is offline Find More Posts by CapMike
Old Jan 16, 2013, 11:29 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Haha. Actually you're upside down. It was late evening...
Old Jan 17, 2013, 10:48 AM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
Gree,
That is really cool, thanks for sharing. How high were you in the clouds?
Does your system have a "return to launch" feature?
al
rossaer is offline Find More Posts by rossaer
Old Jan 17, 2013, 03:05 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Those clouds were pretty low at 1000m (3300ft). I use a Zephyr II, and have the range video osd with return to home etc etc.
An update to this project - my flaps and ailerons are ready for panel lines. With any luck they should be finished and installed by the end of the weekend.
Old Jan 18, 2013, 11:07 AM
rossaer is offline
Joined Aug 2008
1000 meters!!!!!!!!!!! The field I fly at we are limited to 400 ft agl.
After my P-47 is finished I think I'll try FPV. I'm not sure if it will be by fixed wing or some sort multicopter as a platform but your video sure makes it look fun.
al
Old Jan 18, 2013, 02:39 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
al
You should! Not to derail my own thread but here is one from last weekend
Zephyr! Zephyr! Zephyr! (6 min 37 sec)
OK back to P47 stuff now...
Old Jan 18, 2013, 08:16 PM
rossaer is offline
Joined Aug 2008
oh oh I can hear my charge card complaining already!
al
Old Jan 18, 2013, 08:52 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Nice video! Love that Rangevideo web site, and the RVjet is sweet looking. huh....one day
jk6672 is online now Find More Posts by jk6672
Old Jan 20, 2013, 03:41 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Flaps Ahoy!
Flaps Ready for Installation
Well my prediction of having all of the control surfaces of the wing attached by the end of this weekend didn't quite come true. I was waylaid installing a chandelier today! So a lot of build time turned into home improvement time. Oh well I'll still get there...
The flaps and ailerons were glassed last week, and over the last few days I did the usual filling and sanding, panel lines and riveting (stayed up to 2.30am last night doing them). I detailed this process before so I won't post any photos of that today. The ailerons only need trim tab actuators made and then they can be given their final coat of aluminium. The flaps as mentioned are completed.
I'm looking forward to getting the flaps installed...
Old Jan 21, 2013, 12:22 AM
Chris F is offline
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
WOW! That looks great Gree. Not long now I hope.
Chris F is offline Find More Posts by Chris F
Old Jan 21, 2013, 01:58 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Thanks Chris. In proportion of the time it has taken to get this far, no not long (comparatively!). I installed the flaps after work today, but haven't got the servos hooked up yet. Bloody hell they are finicky buggers to get in the right place. But the epoxy is drying as we speak!
As far as I can work out, I have the following left to do, in no particular order:
1. Make the rear canopy attachment and install
2. Glue the canopy on
3. Make the landing light and install
4. Make the wing tip navigation light interiors and install, plus glue on the wingtip lenses
5. Get a new motor shaft adapter from Truturn. I found out mine has the wrong thread!
6. Make insides of lower gear doors
7. Make insides of middle gear doors
8. Attach gear doors to struts
9. Attach inner gear doors
10. Make trim tab actuators for ailerons
11. Final coat of paint for ailerons
12. Attach ailerons and hook up servos
13. Put on cowl checking that motor is centred
14. Paint tips of prop yellow
15. Paint prop hub yellow
16. Make tail navigation light
17. Work out how to open the battery hatch and make solution
18. Weather the wing etc
19. Make and install the guns
20. Get new 6S 5000maH batteries
21. Balance
22. Find a place to actually fly this thing!
23. Pray hard to a god I don't believe in
24. Fly...
GREY = done!
So maybe a couple of months? But I have heard that before!!
Question motor battery prop combination for top flite P47 63"? Gree Glow to Electric Conversions 27 Jul 20, 2014 08:42 PM
Discussion Yes another top flite giant P47 build pand9 Fuel Warbirds 5 Jan 07, 2009 06:25 AM
Discussion P47 Top Flite - Making Off rushspbr Fuel Warbirds 18 Dec 07, 2006 09:03 PM
For Sale Top Flite P47 Tom Jennings Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2006 11:51 AM
Top Flite DC-3 Eddie P Scale Kit/Scratch Built 10 Jul 20, 2001 06:11 PM
