Old Feb 27, 2012, 02:14 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Ha! I was thinking 'what the hell is he going on about now?', then zoomed in on the photo. Laughed out loud! I have no idea what that picture is about but I assure you it came out of an ordinary newspaper!
Gree is offline Find More Posts by Gree
Old Feb 28, 2012, 02:08 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Ready for Raised Panel Details
Well It's Done
But I am NOT happy with the results. I had a very bad day at work today - came home very angry and thought I'd work it off by getting stuck into the '47. Well never build when you're angry...
Basically it worked out OK, but the depth is not nearly enough. I only put one coat of the spray putty on. I know better than that. It would need about 3 coats to get the same good depth that my overlapping panels have on the elevators for example.
So the effect is really too subtle to look very good. I am thinking I can salvage it a bit by some careful airbrushing of the line after the final paint to highlight the raised panel more. Funnily enough it is probably close to a scale thickness, but as everyone knows sometimes these details need a little extra emphasis for the effect to work. I am going with it now...
Old Feb 28, 2012, 06:16 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Looks great to me. I think you are right, with a little detail magic at the end it will really pop!
Can you tell me about this "spray putty"? Is it just build up primer or is there really a spray on putty?
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Feb 28, 2012, 10:35 AM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Everybody has a different opinion about what looks good Gree but I think you may be pleasantly surprised with how well those panels stand out under a coat of paint. Particularly so if you give the airplane a dirty wash and allow it to settle into the crevices.
Chad Veich is online now Find More Posts by Chad Veich
Old Feb 28, 2012, 01:40 PM
Jeff Glasser is offline
Find More Posts by Jeff Glasser
Limey Jeff
Jeff Glasser's Avatar
Glastonbury, Somerset. U.K.
Joined Mar 2009
[QUOTE=Pickle72;20881613
Matt[/QUOTE]
Matt,
spray 'putty' is like a very thick primer, used to cover poor under finishes (as in the case of Grees' P.47 )
It can be bought in aerosol form, when sprayed two - three coats (leave to dry inbetween coats). When fully dried, puff it over with some black aerosol and then flat back say with 400 grit wet/dry progressing to 800 w/d untill all the black has gone. As this is done it will show any imperfections in the surface e,g. pinholes or heavey rubbing down marks.
When you're happy, you can reprime with normal primer, ready to flat and add top coats.
Glad to help if I can.
Jeff
Jeff Glasser is offline Find More Posts by Jeff Glasser
Old Feb 28, 2012, 01:48 PM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Awesome! Thanks for the tip!
Matt
Old Feb 28, 2012, 01:50 PM
Limey Jeff
Joined Mar 2009
Gree, if you can get to model shop that sells modelling aids (sure there's a sick joke in there somewhere!) for plastic modelers, they might have some small tools that scribe panel lines into plastic. I'm sure this could be used to re do your panel lines to a slightly greater depth.
(it looks like the sort of nasty thing dentists use, )
Jeff
Old Feb 28, 2012, 01:51 PM
Limey Jeff
Joined Mar 2009
Matt, that was quick!
Anytime.
Jeff
Old Feb 29, 2012, 01:01 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Actually I just worked out why the panels are so flat... Not so much the number of coats actually, butI used a different brand of electrical tape, and when I compared them today, it was much thinner than the tape I used before, giving a much thinner overlap... Bugger!
Check your materials people! Lesson learned. Not the end of the world.
Old Feb 29, 2012, 07:50 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Ready for Final Primer Coat my Butt!
Am working from home today, so had a quick peek at the fuse in the bright daylight in between tasks. Man it still needed more pinholes filled and there were also areas that I had not sanded smooth enough.
Guess it never ends! You'll always find more imperfections the more you look. However this will be my LAST filling and sanding pass over the fuse - no really..... I'm going to stop looking...
I spent about an hour staring very closely at the fuse in the good light, finding every imperfection I could. These were filled or circled for more sanding as appropriate.
Old Mar 02, 2012, 11:49 PM
ihaveahellcat is offline
Find More Posts by ihaveahellcat
ihaveahellcat's Avatar
Joined Sep 2009
This is weird, i was expecting some comment from Jeff about how the whole plane should be covered in pencil or something along those lines.
Looking good though Gree.
ihaveahellcat is offline Find More Posts by ihaveahellcat
Old Mar 03, 2012, 01:30 PM
Limey Jeff
Joined Mar 2009
It was tempting! Though in Grees case it would have to be wax crayons as he's not advanced enough for pencils.. and you know the havoc wax will cause to the top coats
Jeff
Old Mar 03, 2012, 02:27 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
*dignified silence*
Old Mar 03, 2012, 11:21 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Fuse is in primer!
Passed a Big Milestone Today (and no Jeff it doesn't hurt as much as a kidney stone)
Well I feel like I am really moving ahead today. The fuse is finally in primer! There has been a lot of filling and sanding etc to get to this point, and I have really learned a lesson about preparation of surfaces prior to glassing! I'll pay a lot more attention to this in the future to save myself so much work later on. When I glass something again, I'll also definitely use a flow coat. This time I filled the weave with hi fill primer, but it was way slower and you end up with a softer surface. I did say this was my practice plane!
I spent a day measuring and cutting aluminium foil to make all of the removable panels on the plane, and also indented screw heads into them prior to the primer coat.
Disturbingly, I can't find my tail wheel doors! I want to prime them at the same time so I can do all of my riveting at once. I am sure I packed them safely somewhere and have to trust they'll turn up when I unpack everything again when the construction in our apartment is FINALLY complete...
Of course after the flat primer, I can see a couple of areas with (more) pinholes that need attention, but it is not too bad. The surface is smooth but a bit wobbly, but I like that, more realistic! Unfortunately you can definitely still see the 'starved horse' effect on the fuse (ie the skin sagging between the stringers). But I hope when the detail and weathering goes on it won't be too bad (did someone say practice plane!?).
It is starting to come together. Next is riveting! My absolute favourite part!
PS - I hate the small pop up windows this new look site has. Make sure you click the image once it pops up so it opens larger in a new window if you want to see more detail...
Old Mar 04, 2012, 05:09 AM
Limey Jeff
Joined Mar 2009
Excellent mate, I too love your little double door, was'nt he the headmaster at Hogwarts?
Glad you've got this one down as a 'practice' model, next time you can really do it properly.
Clever of you to pre-emt me re the milestone gag! you know I would'nt have been able to resist it.
Jeff
Question motor battery prop combination for top flite P47 63"? Gree Glow to Electric Conversions 27 Jul 20, 2014 08:42 PM
Discussion Yes another top flite giant P47 build pand9 Fuel Warbirds 5 Jan 07, 2009 06:25 AM
Discussion P47 Top Flite - Making Off rushspbr Fuel Warbirds 18 Dec 07, 2006 09:03 PM
For Sale Top Flite P47 Tom Jennings Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2006 11:51 AM
Top Flite DC-3 Eddie P Scale Kit/Scratch Built 10 Jul 20, 2001 06:11 PM
