Old Apr 03, 2011, 11:37 PM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Wonderful build Gree. It's looking great.
I live in Moorabbin, Victoria, do you charge per dot for your rivet service? I have a TF P-40 partially built
aerophilia is offline Find More Posts by aerophilia
Old Apr 04, 2011, 04:31 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Yeah go back a few pages. I have already completely finished the elevators and rudder (including final paint). You'll see more pics there...
Basically though, I use the same technique many people do. A soldering iron with some brass tube. That's it. Just touch the surface enough to burn in the circle on the primer and move on. I keep the rough side of a Velcro strip next to me, and every 10 rivets or so I just rub the tube end on the spiked Velcro and it cleans the tip so it doesn't clog with melted paint. I think I may have invented this cleaning technique, at least I haven't read about it anywhere!
Gree is offline Find More Posts by Gree
Old Apr 04, 2011, 05:09 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Hi aerophilia, didn't see your post there. Thanks for the comments. Greatly appreciated.
Sure I'll rivet your P40 for you. Payment should probably be about 1 P40. In other words if you'd like to donate it I'll rivet the bejesus out of it I've always wanted a P40 in RAAF colours like in my avatar (right before i shot it down hehe).
Actually my rivets can be slightly wobbly since I do them freehand (following the pencil line of course). You may end up wanting your money back!
Old Apr 04, 2011, 05:43 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Hmmmm, might be a bit expensive
If I ever get around to finishing mine, I might try putting rivets on. And I will let everyone know you invented the velcro cleaning method
Old Apr 04, 2011, 06:08 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Damn right! The Velcro thing is my only claim to fame!
Old Apr 04, 2011, 08:36 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Just riveted most of the other side of the top of the wing...
Old Apr 04, 2011, 08:47 AM
Jeff Glasser is offline
Find More Posts by Jeff Glasser
Limey Jeff
Jeff Glasser's Avatar
Glastonbury, Somerset. U.K.
Joined Mar 2009
Excellent as usual Gree. re wobbly rivets...have a close look at some of those old warbirds, they aint that perfect, nor is the panel fit on most.
Hope you're feeling better (I do care really) though if it's something life threatening could you leave a note for your better half to send your P.47 and any other model stuff to me should anything happen to you.
Jeff
Jeff Glasser is offline Find More Posts by Jeff Glasser
Old Apr 04, 2011, 10:38 AM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Originally Posted by Gree View Post
Basically though, I use the same technique many people do. A soldering iron with some brass tube. That's it. Just touch the surface enough to burn in the circle on the primaer and move on. I keep the rough side of a Velcro strip next to me, and every 10 rivets or so I just rub the tube end on the spiked Velcro and it cleans the tip so it doesn't clog with melted paint. I think I may have invented this cleaning technique, at least I haven't read about it anywhere!
Your P-47 looks fantastic Gree and, as I do my flush rivets the same way, I will be stealing your Velcro cleaning idea. Thanks for that! One thing I do slightly different is to burn my rivets into a base coat of paint, usually silver. I have found that paint is generally much harder than primer and allows for more consistent and better defined rivets. That's just my .02 cents of course. Definitely looking forward to seeing your Jug with some paint on it.
Chad Veich is offline Find More Posts by Chad Veich
Old Apr 05, 2011, 03:52 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Thanks Chad. I might try that basecoat idea on my next build. I have found that this silver I am using for my topcoat is a very soft paint, and it doesn't like to be recoated once dry. I am not sure why but the finish goes a bit milky. One coat is fine, so I am burning into the primer, a quick sand to knock down all the high bits and final paint...
Old Apr 06, 2011, 08:00 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
A couple More Pictures of the Riveting So Far
Still riveting when I get an hour or two...
Old Apr 06, 2011, 08:22 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
WOW! Looking great Gree.
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Apr 06, 2011, 02:49 PM
Limey Jeff
Joined Mar 2009
You've got them all going the wrong way Gree, you'll just have to start again!
Jeff
Old Apr 06, 2011, 05:05 PM
Scale Builder
Joined Jul 2002
Jeff
Yeah, and they are 180 degrees out too.
Old Apr 06, 2011, 08:53 PM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
You're a madman, Gree. You must see rivets in your sleep. Jeff
jhspring is offline Find More Posts by jhspring
Old Apr 06, 2011, 10:37 PM
prunner is offline
Find More Posts by prunner
Prunner
prunner's Avatar
Auburn, KS
Joined Oct 2008
T.h.a.n.k.s. ...f.o.r. ... C.l.e.a.r.i.n.g. ...t.h.a.t. ...u.p.
prunner is offline Find More Posts by prunner
Question motor battery prop combination for top flite P47 63"? Gree Glow to Electric Conversions 27 Jul 20, 2014 08:42 PM
Discussion Yes another top flite giant P47 build pand9 Fuel Warbirds 5 Jan 07, 2009 06:25 AM
Discussion P47 Top Flite - Making Off rushspbr Fuel Warbirds 18 Dec 07, 2006 09:03 PM
For Sale Top Flite P47 Tom Jennings Aircraft - Fuel - Airplanes (FS/W) 7 Jan 16, 2006 11:51 AM
Top Flite DC-3 Eddie P Scale Kit/Scratch Built 10 Jul 20, 2001 06:11 PM
