Old May 07, 2008, 09:45 PM
I am the robot of pop...
iamtheroboto's Avatar
Lake Chargogagogmanchaugagogchubunagungamaug, Webster, MA
Aerobird3 with onboard Hero3, vids, mods, and ramblings....
Hey everyone!! just wanted to share some fun ive been having with cheap RTF gear.......
high altitude onboard camera...... (6 min 12 sec)
webster lake flying.... (4 min 54 sec)
the bird is the Aerobird3, wich is great to keep in the car (esp. for 109.99 )...... the cameara is the GoPro Hero 3.... wich i cant recomend enough for great onboard video and pics.....
the following pics describe how i mounted the camera for the initial videos....and also how i modified the Aerobird3's body to accomodate some different views..... the first time i tried an "under wing" view i had very poor results, and almost crashed this thing for the first time in 50 flights or sooo..... these new mounting positions should work perfectly, as they will not increase drag, and are right on the CG.....
i will post vids of the new mounts once i get the time (and weather.... )
iamtheroboto is offline Find More Posts by iamtheroboto
Old May 09, 2008, 08:59 PM
nobody, huh.....
well either this is old news, or nobody cares about good clean fun with cheap planes... i fly ALOT more knowing that...
A) i can fly almost anywhere, anytime....
B) i can fly much more aggresively...
C) its not going to bring me to tears when i crash (or submerge ) it.....
anyway.....
a quick question for anyone out there who has flown the Aerobird Challenger, or the Aerobird3.....
i was comparing pics today and noticed that the Challenger's tail was much flatter, I.E. was a much greater angle than 90%..... looks like 110-120%.......
my Aerobird3 is almost exaclty at 90%......
just curious as to the difference in performance/controll......
Old May 09, 2008, 10:14 PM
No Guts, No Glory
flyin C's Avatar
Simi Valley, CA
Joined Feb 2007
way cool man! I have the original aerobird challenger and some pics of it are in my blog. I too love flying it because you figure for what its worth, you might as well experiment and have fun with it. I have gotten a 20min flight with it, when I kinda caught a semi thermal, and once the power cut off for a second i knew it was time to land.
I have dropped all kinds of things from it.
I have brought it camping and everywere.
belly lands on the dirt or not so soft ground is fine.
overall a fun plane.
When you say the tail feathers are at a greater angle, are you referring to were the boom is attached to the main fuse, or the actual tail is angled differently from the boom
flyin C is offline Find More Posts by flyin C
Old May 09, 2008, 10:26 PM
angle between the 2 v-tail segments.....
Old May 11, 2008, 04:15 PM
No Guts, No Glory
flyin C's Avatar
Simi Valley, CA
Joined Feb 2007
a greater angle between the two tail fins would be used to give greater elevator control and less rudder, its usually used for begginer planes so the pilot doesn't over correct themselves too much. And becuase the challenger is a 2ch plane, it used only rudder, so it has a big angle for the purpose of wide turns and not over controlling the plane.
and a small angle like your A3 for tight turns since its more vertical, yet you still have a lot of elevator control
Old May 17, 2008, 09:19 AM
finished up some lose ends.... decided to use a simple rubber band mounting system.... and created access holes for easier button pressing....
i cant wait to fly it with the camera mounted here... last night i finally got the Aerobird3 to roll cant wait to get that on camera.....
Old May 17, 2008, 06:23 PM
Up Up and Away!
lightspeeddud's Avatar
Joined May 2008
I tried attaching a digital camera to my aerobird 3 today but its crash!
lightspeeddud is offline Find More Posts by lightspeeddud
Old May 17, 2008, 06:32 PM
No Guts, No Glory
flyin C's Avatar
Simi Valley, CA
Joined Feb 2007
did you make sure the CG was still exactly the way it was before the camera was attached?
Old May 17, 2008, 06:38 PM
Up Up and Away!
Joined May 2008
what do you mean?
Old May 17, 2008, 06:41 PM
No Guts, No Glory
flyin C's Avatar
Simi Valley, CA
Joined Feb 2007
meaning that attaching the camera is going to put more weight on the plane. And you must balance the plane to make sure that with the added camera, the Center of Gravity is still the same.
CG means Center of Gravity
Old May 18, 2008, 08:04 PM
heres a vid with the new internal mount.... it was a bit windy so its kinda choppy, but it was fun!
on a side note, i tried flying with this setup the day before, hoping to show off my newfound ability to roll the AB3, but the extra weight of the camera combined with high wind was somewhat of a problem....I.E. i folded the wing over!!!! it dropped pretty hard from about 100' with the camera onboard, and because of the sudden impact, i lost the video......
i fixed the wing with bamboo skewers, gorilla glue, and packing tape for todays flight, and picked up a spare for future aggresive flying
Aerobird3 with Hero3 mounted under wing.... (4 min 30 sec)
Old May 26, 2008, 12:56 PM
More fun!
i had a really good crash last week.... with the camera on board (didnt finsh recording, man that would have been cool), and have since repaired all the damage.....
however, im having serious setup problems with the V-tail mixing.... i started a thread in the beginner training forum.... link to the thread is here...
http://www.rcgroups.com/forums/showthread.php?t=867669
anyone who can help me with this please dont hesitate!!! pics of the stock setup would be ideal......
anyway, since the only mode that would function normally was the T-tail mode, i decided to build a modular T-tail, that could be swapped back to V-tail easily if/when i ever get my servo mounts figured out....
heres some pics and descriptions.... feel free to chime in!!!
Old May 26, 2008, 01:22 PM
more T-tail work....
i did a bit more work, still have some issues......
for example.... how to connect the 2 elevator areas..... setting up the rudder hinge.... yadda-yadda..... ive got some ideas, ill have to see what works best.....
Old May 26, 2008, 01:32 PM
It works, don't touch it.
skiesthelimit's Avatar
Joined Dec 2007
You are way ahead of me. Looks good.
skiesthelimit is offline Find More Posts by skiesthelimit
Old May 30, 2008, 09:37 PM
more setup today..... looks almost ready to fly.....
i just made a simple tape hinge for the rudder.... but im still not sure how to connect the 2 new elevators while still keeping the tail modular, so i can swap it back to a v-tail......
id also like to incorporate a steerable tail wheel eventually....
For Sale---Eco 8 with servos all the mods Eco8gator Aircraft - Electric - Airplanes (FS/W) 7 Sep 04, 2002 06:39 PM
Housefly with onboard wireless camera! ls77 Electric Heli Talk 29 May 17, 2002 09:11 AM
FS : Hornet with collective pitch and mods fchristian Aircraft - Electric - Airplanes (FS/W) 3 May 13, 2002 08:10 AM
Cool Added a Tiger Moth page with pics and vids to my site Sloper Mario Parkflyers 22 Mar 12, 2002 10:17 AM
