Go Back   RC Groups > RC Clubs > International Scale Soaring Association (ISSA)
Old May 07, 2008, 08:29 AM   #1
Retract Servo Powered By Separate Battery
Would like to power a sailplane retract servo with a separate battery. Does the negative terminal of the separate battery have to be wired to the negative of the RX battery so they share a common ground or is this not necessary? (I understand about wiring the signal lead.)
TIA,
Steve
SteveR is offline Find More Posts by SteveR   Reply With Quote
Old May 08, 2008, 10:34 AM   #2
scalebldr
scalebldr's Avatar
TIA,
Steve
Talk to Dennis he has done this before
Rick
scalebldr is offline Find More Posts by scalebldr   Reply With Quote
Old May 18, 2008, 07:55 PM   #3
Electric Airplane Junkie
bhchan's Avatar
Steve,
Do you want to have separate power or just so the retract see the max voltage? What is the main goal behind this exercise?
I had a Futaba retract servo that has a wire to the rx and a female connector to accept a battery pack. I think the power is common.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan   Reply With Quote
Old May 19, 2008, 06:52 AM   #4
Brian, I want to insure that if the retract mechanism ever jams, I didn't want its servo to pull down the main battery pack as it tries to either retract or extend the main wheel. By using a separate battery pack to drive it, any problem is localized to the retract servo only. Sounds like Futaba has this all set up in advance.
I finally finished all the wiring for this new sailplane including the separate pack for the retract servo which shares a common ground with the main pack. Everything works well and it will maiden at JR. Will post some photos shortly.
Steve
Old May 19, 2008, 10:16 AM   #5
bhchan's Avatar
Steve,
If you want to separate the system, you can always run a separate receiver, retract servo and battery just for the retractable LG.
Brian, an EAJ
Old May 19, 2008, 10:47 AM   #6
True enough, but still more complexity. Just the extra pack works great.
Old Dec 26, 2008, 03:32 PM   #7
on a vacation
the interesting this is I just lost a plane to this.... retract jammed and my rambler flew into the ground at full speed.... toast now... I was able to prove it by the fact the servo had a large amount of stripped gears
NitrosharkiiiI is offline Find More Posts by NitrosharkiiiI   Reply With Quote
Discussion Esc and separate battery for rcvr/servo Jack Hyde Electric Sailplanes 13 Feb 03, 2006 09:07 PM
Another power tool powered by Lithium ion battery ptglass Batteries and Chargers 0 Jun 17, 2005 03:58 PM
separate BEC for retract servo? hul DIY Electronics 2 Apr 09, 2005 03:29 AM
Separate battery for a retract servo? How? tim hooper Electric Plane Talk 17 May 05, 2003 07:15 PM
FUNNY PARK CG Battery Mod. Powered by Kokams. LESLIEx317537 Parkflyers 6 Mar 22, 2003 05:51 PM
Bored? Want to fight?
Join the RCGroups clan!
