Build Off II - Mig-9
Hi all, At the beginning of the second Scale build Off I had great plans. I wanted to participate in both categories with a Dornier Do335 in the multi engine category and a Mig-9 in the EDF category. But a new job combined with putting the house up for sale and designing a new house put an end to my cunning plan. The Do335 is almost ready for cutting, but I just don´t have the time to build it right now. The Mig-9 was constructed as a “Keep-It-Simple-Stupid” design and will be used as a test bed for a future double size Mig-9. I did cut some corners during the design process in order to minimize the construction and build time. I´ll try my best to get the plane done and flown before the deadline, but the level of detail will suffer. I choose the Mikoyan-Gurevich Mig-9 because it looks very agressive with it´s big round fuselage with those big guns and cannon sticking out and it´s a plane you rarely see modelled. Actually I wasn´t able to find a single Mig-9 RC-model when doing an internet search. I´m not saying it hasn´t been done, but it sure is hard to find. Plenty of Mig-15´s out there, but no Mig-9´s. Here´s a bit of info about the real Mig-9: Mikoyan-Gurevich MiG-9 Fargo was a first-generation Soviet turbojet fighter and attack aircraft developed by Mikoyan-Gurevich in the years immediately after World War II. It was an orthodox design with a straight wing and a nose intake. Performance and handling suffered because of the primitive engines, copies of the German BMW 003. The MiG-9 were commonly armed with a single 37 mm cannon and two NS-23 23 mm cannon. The mounting of the three cannon were unusual with the NL-37 being mounted in the centerline engine intake bulkhead, and the two smaller cannon firing out the lower lip of the intake. This unusual location of heavy cannon is suspected to have caused several pilot deaths due to gun gas ingestion and led to restricitons on the heavy cannon use at various altitudes. The Mig-9 reached a speed of 565 mph (910 km/h) during initial tests, and after further refinement, it entered service with the VVS as the MiG-9 during the winter of 1946-47. The jet had many performance- and steering-related problems, however it was put into service mainly because of political considerations. The MiG-9 was deployed largely in the ground-attack role and 610 aircraft were built in different versions by the time production ended in 1948. The specifications of the model are: 600 mm wingspan 650 mm length 55mm No-Name fan with KV 5300 Motor2409H-7T Elevator and ailerons Balsa fuselage and fan tube Depron wings. - Michael Hammer An update to the MIG-9 build can be found in my blog |
Mike,
I actually worked as a camp counselor in Connecticut while MC Hammer was at his highest. Boy did I consider changing my name that summer Thank you for the invitation Well, on with the build: Wings were made from depron using 3mm skins, 5mm ribs and 3mm balsa main spars. The leading edge was done in the Pibros way (belgian designed depron delta plane). Everything was gluede with polyurethane glue. A pair of wings made this way can be fabricated in a couple of hours + a night for the glue to cure. - Michael Hammer |
The ducting was made with 1.5mm balsa. I tried to use one piece of balsa cut from a template generated with Rhino´s powerfull "Unroll developable surface" but it was too difficult to get right. So I ended up strip planking the whole duct. If I decide to build a double size Mig-9 the duct will be redesigned
- Michael Hammer |
I agree that admiring your interior planking job goes beyond building a ship in a bottle! Mike |
Woow, nice build!!! I love those Rhino jobs
Subscribed ![]() Unroll developable surface works only well for wooden parts when they are of simple shape, simple bending and thin regarding there surface. I've tried it too ;-) My Comet's sides are made with this function and they have a perfect fit. But they are of very simple form. I once tried to make a cardboard pylon racer. I drew the fuselage in segments so I could unroll them all with that fucntion. The paper model was finished in no time and looked good. But I never found good cardboard that could make the bends and shapes that I made in paper. After a zillion attempts I gave up. What was I supposed to do with a pylon racer anyway??? Michael, Why are the holes in your formers not circular form but polygonal? Mike, Thanks for the compliment I fear I'll come to late with the Comet. But we'll see ![]() Tom |
| Thread Tools | |
| Discussion Build Off II: 100" Span Spruce Goose/ Hughes Hercules H-4 | scratchnhover | Scale Electric Planes | 942 | Nov 01, 2012 04:56 PM |
| Contest Build Off II - 42" Baron 58 | thomanie | Scale Electric Planes | 307 | Jun 30, 2012 08:40 AM |
| Contest Build Off II - Zeppelin-Staaken XIV “R” Bomber - 92inch | Flying Beagle | Scale Electric Planes | 347 | Dec 11, 2011 12:07 AM |
| Contest Build Off II - 1/6 Scale de Havilland DH. 88 Comet - Design | W@CC0 | Scale Electric Planes | 51 | Nov 06, 2009 11:52 AM |
| Contest Build-Off II - Potez 621 'Dunkerque' | Pat Lynch | Scale Electric Planes | 459 | Aug 15, 2008 08:49 AM |
