Old May 06, 2008, 08:38 AM
rceagle1a is offline
Find More Posts by rceagle1a
Generally R/C Insane!!!
Newton Iowa USA
Joined Oct 2003
Pitot/Static tube install pictures
I got my Pitot/Static tube mounted on my extra 260 last night. I used 1/64 ID tygon tubing to go from the wing tip to the fuselage. I hope this will work. Here are the pictures.
rceagle1a is offline Find More Posts by rceagle1a
Old May 09, 2008, 01:04 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
HI rceagle1a,
This is very professional looking! I think that will be fine. The only concern I have is whether the static port will be affected by having the pitot tube next to it, but I suspect this will work well for you.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old May 10, 2008, 06:48 AM
Newton Iowa USA
Joined Oct 2003
Thanks Bill, I already thought about what you said about them being so close. I plan to fix that issue tonight with some flat brass and more soldering,Lol. I'll post the pics of the mods soon.
Last edited by rceagle1a; May 10, 2008 at 11:12 AM. Reason: added photos of pitot tube mod
Old May 11, 2008, 02:30 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
Full size planes use two concentric tubes, but yours should work just fine. Full size planes also mount the pitot tubes about one cord distance from the tip to avoid probelms induced by the tip vortex. I don't know if that will be a problem here, since I've always mounted pitot tubes mid span.
dhares is offline Find More Posts by dhares
Old May 11, 2008, 10:56 AM
Newton Iowa USA
Joined Oct 2003
Ok,Dhares: Could you post a pic of how you mounted your tubes mid span? I might be tempted to move mine if this install doesn't work out right as I can redo the tip with a piece of scrap covering to cover the current holes.
Old May 12, 2008, 05:11 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Is it better to mount the static air port into the air stream flow with holes drilled and the tube sealed?...or is it better to have an open tube mounted flush to the fuse, perpendicular to the air stream flow?
Does the fuselage affect the the readings?
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old May 12, 2008, 05:48 PM
ardisd is offline
Find More Posts by ardisd
Joined Apr 2007
Take a look at my post
http://www.rcgroups.com/forums/showthread.php?t=830815
I used a similar system and it gave me a lot of problems with height measurement
I have now a small plate with a 2mm hole on the side of the aircraft which appears to have done the trick
Will post pictures tomorrow evening
ardisd is offline Find More Posts by ardisd
Old May 13, 2008, 04:49 AM
turn, turn, turn.
Joined Oct 2005
Thanks.
Pics would be great.
I can include some of my own very unprofessional installation also...as long as rceagle1a doesn't mind his thread becoming a sort of "home base" for this type of thing.
Old May 13, 2008, 06:53 AM
dhares is offline
Saline, MI
Joined Jul 2006
I will post some pics to this thread too. Meanwhile, in an earlier thread on pitot tubes (and Eagle Tree's sensors) I posted links to articles on pitot tube design and placement. This is one of them: http://www.grc.nasa.gov/WWW/K-12/airplane/pitot.html For the equations to work, the static and pressure ports need to be near each other and in stable air ... outside the laminar flow over the wing.
Old May 13, 2008, 05:37 PM
ardisd is offline
Joined Apr 2007
My pictures as discussed the static port is the brass plate on the side of the plane with a 2mm hole
Discussion Pitot Tube Install in plane rceagle1a Eagle Tree Systems 15 Oct 04, 2014 02:09 AM
Destiny 54" Balast Tube Example - Pictures Inside Z06kal Slope 12 Apr 09, 2005 02:59 AM
