Old May 04, 2008, 09:54 AM
frankinstint is offline
Find More Posts by frankinstint
frankinstint's Avatar
Devon, England
Joined May 2008
Question
Graupner Jet Propulsion Unit (2340) Motor
Hi
Which Motor would be fast with a Graupner Jet Propulsion Unit (2340) using 7.2v Batteries?
frankinstint is offline Find More Posts by frankinstint
Old May 04, 2008, 11:39 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I believe graupner recommends the Speed 700.
If you run too fast of a motor, you will get a blender rather than a jet pump, due to cavitation.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old May 04, 2008, 07:26 PM
quicksilver is offline
Find More Posts by quicksilver
dry docked
quicksilver's Avatar
Oneonta, NY
Joined Oct 2006
I've found the my boat goes faster no matter what rpm, but it definitely gets to be a matter of efficiency. I run 16 cells on a 775 motor, running about 34,000 rpms max. The difference in speed between 3/4 throttle and full throttle is very small. This would put the max on that drive at around 25,000 rpms. Beyond that, the way to make the boat quicker is by making it light and having the best hull shape. However there are ups and downs for different hulls. Flatter wider hulls, generally appear faster, but aerate a lot and longer narrower hulls tend to be better for rough water.
quicksilver is offline Find More Posts by quicksilver
Graupner Jet Cat chrisc Electric Ducted Fan Jet Talk 7 Apr 02, 2002 10:37 PM
FS: Kyosho EDF unit and motor. twinster2 Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2002 12:39 PM
Graupner Evo One 50 Brushless Motor 7.2v John K Electric Sailplanes 0 Dec 14, 2001 09:01 PM
Graupner Evo One 50 Brushless Motor 7.2v John K Electric Sailplanes 0 Dec 14, 2001 08:40 PM
What is a Graupner Ultra 1300-8 12v motor? Clayton Power Systems 3 Jun 21, 2001 02:57 PM
