May 03, 2008, 05:57 PM
Atlanta, Georgia
Joined Mar 2008
To those who use masts or thinking of it: Can math replace your monitor, pan & tilt?
Let's think about this for a minute.
Let's say you have a fifty-foot pole with your camera on top. Your camera sits on a mount that can be adjusted for tilt, and you use your mast to pan. Also consider that your tilt has measurements that correspond to angle: straight to the horizon is 90 degrees. 180 is straight up. Follow me here.
And let's assume that you spent an afternoon with a tape measure, a notebook, a calculator, and a protractor measuring different houses and using that information to adjust your camera and take pictures.
In other words, you measure a few different scenarios, adjust your camera's height, tilt, etc, check the pictures, and then finalize the results using math and notation.
Couldn't we then conclude that if you went to a house to photograph it, that you would know, depending on the height and width of the house or property, that you could just know exactly where to place your mast, how high to raise it, and at what angle your camera should be before it leaves the ground?
It would eliminate the need for monitoring. You simply measure 100 feet (arbitrary number for the purpose of this post) from the house, set the angle of your camera, press button on camera for continuous shot, raise mast, turn mast side to side occasionally, bring it down, load up the pics. I'm thinking you could really save time that way AND money, because you wouldn't have to buy any equipment other than your camera, pole, mount, and a measuring wheel (much faster than a tape measure).
OF course you would have to already have your computer.
But no pan and tilt, no usb cable, no wireless system with batteries, etc.
Just pole, mount, camera, tape measure.
What do you think?
I am going to run some math using a protractor and graph paper to set it to scale.
Is this smart thinking or just plain dumb?
Let me have it. You won't hurt my feelings.
