Old Jan 15, 2003, 06:13 PM
joe_dejesus is offline
Find More Posts by joe_dejesus
HobbyShopWorld.com
Florida
Joined Nov 2002
Lithium Ion Charge Circuit
I have built the charger using a LM350 and can get approx 3 amps on 2 cell setup. I know that the max current the LM350 can do is 3 amps. Can something be done to get more current out of this circuit? maybe double or tripple current?
www.shdesigns.org/lionchg.html
I want to charge large packs 9000mah and would like to charge at 1C AT LEAST.... Anyone?
joe_dejesus is offline Find More Posts by joe_dejesus
Old Jan 15, 2003, 07:03 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Regulator LM338 is good for 5 amps with heat sink.
Using two in parallel would give you 10 amps.
http://www.national.com/pf/LM/LM338.html
DNA is offline Find More Posts by DNA
Old Jan 15, 2003, 07:41 PM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
When you start talking about that kind of serious charge current, the charger circuit usually becomes a little more complicated.....the existing 3 amp circuit can be used to "drive" a high (10, 20 or whatever amps required) output "pass" transistor stage,added to the existing charger combined with really large sink fins.... Typical useful circuits can be found under "high current voltage regulators" searches...... hope this helps...... kw
KillerWatt is offline Find More Posts by KillerWatt
Discussion Lithium Ion charge voltage flierbk Batteries and Chargers 1 Jan 26, 2007 11:11 PM
Question Lithium Ion charge rates? and others. aussie dodge Batteries and Chargers 2 May 04, 2005 09:25 AM
Best Charge rate for Etec 2 cell Lithium Ion 1200's Jamo Micro Helis 13 Nov 16, 2003 04:32 PM
Lithium Ion charge time? mattski GWS (Grand Wing Servo) 1 Sep 02, 2003 03:19 PM
lithium ion prot. circuit iamDerrick Parkflyers 4 Jan 19, 2002 11:26 AM
